Led lamp - won't work in cold enviroment
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Have this led lamp that works perfect fine in room temperature but wont light up outside in cold winter.
    Is this because of the startup capacitor is not made for cold enviroments ? startup cap are su'scon - see picture second last picture.
    Link to manufacturer site - Cob Led 50W
    • 31055
    Re: Led lamp - won't work in cold enviroment
    you probably answered your own question.
    the problem is electrolytics hate cold.
    you may have to increase the value.
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      Thanks for your answer - Are both the 47uF 50V and the 33uF 50V caps considered startup caps ?
        • 31055
        i dont know - your the one with the board!
        i cant see a controller in the foto's - got any foto's of the other side?
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          I got a few pictures of the underside - looks like the 8 pin so on the primary side is marked F52966 but I can't be sure.
            ESR goes up when temperature goes down, and ESR goes down when temperature goes up.
            Caps are cheap, I would just recap it with good caps.
            There are two small caps (start/run caps) in the primary side close to Q1.
              • 31055
              what's your night-time outside temps at the moment?
              • Gabriel
                • Jan 2010
                • 620
                • Norway
                I guess average at -2C to -5C, sometimes around 7.
                One of the lamps was dead at -1C or perhaps -2C.
                  • 31055
                  yea, your gonna have problems i think.
                  maybe you can use something other than electrolytics.
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    How about some insulation in the box?
                      • 31055
                      that only slows temperature differences, it will probably equalise outdoors even with insulation.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        The PSU might produce enought heat that it could be worth a try anyway.
                        • Gabriel
                          • Jan 2010
                          • 620
                          • Norway
                          They are normally stored in cold car or cold storage containers so I guess insulating them wont work.
                          I did have a look at fm datasheet and see they are rated for -40 to +105, I will try to recap one of the laps to see if cold start behavior changes.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            are these new or have they been in use and just started doing this?
                              • 31055
                              you should probably do a FULL recap, because if the others dont work, you could damage the led.
                              • Gabriel
                                • Jan 2010
                                • 620
                                • Norway
                                Me and a friend found 15 lamps in a retailers dump, they all look pretty brand new with almost no scratches or other damages. All these lamps more or less have the same cold start problem but work perfectly fine indoors.
                                Yes, I will do a full recap on one of the lamps to see if it helps - the other lamps are not really in use.
                                Of all laps we found one one of them had a electric failure but it was also the only lamp that had a different revision board and also a different led driver.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Some sort of ceramic capacitor might help with the high ESR at low temp problem.
                                  Muh-soggy-knee
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Those suscons seem like SK, general purpose. Just use quality low-ESR caps, the ESR should be than similar to warm SKs even while being cold.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      if that is like one my neighbor put up last summer the caps are baked.
                                      his is a dim blue now.several rows of leds are out too.it runs too hot to touch.
                                        • 31055
                                        always going to be a problem regulating temps in outdoor equipment.
                                        unless you make cold-weather & hot-weather versions.
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • resistor83
                                          lenovo 330s-15ikb, led num lock key always on and numbers don't work
                                          by resistor83
                                          hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                                          I tried updating the bios but the problem remains
                                          https://s...
                                          05-29-2025, 08:06 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
