converting 110v to 220v 4x9w
  • Amraks
    • Nov 2011
    • 725
    I ordered a lcd separator from the US with built in UV light
    It has a rex-c100 that has 110v to 220v in it the heater part works.
    The only drama is the psu for the lighting, it took 30 seconds for a 250v capacitor to blow.
    I am looking at converting it to 220v to make the lights work what would I need to change?
    Re: converting 110v to 220v 4x9w
    @240V input, the rectified output voltage will be about 340V way beyond the 250V cap can handle and I hope it did not damage other circuits on the board with that much votage feeding for that long. 120V US will give 165V on the caps.
    Can you provide better pictures with straight shot of the board, both sides?
    Safe way to power up will be using AUTO transformer made from transformer with dual 120V windings on the primary side.
    • Amraks
      • Nov 2011
      • 725
      Here is some better photos
        It looks like the trace for the L (LINE) is blown up!, I have a feeling the board is badly damaged.
        • Amraks
          • Nov 2011
          • 725
          Know what kinda board I will need to buy? can't find these any where.
          I know if I got one out of a UV light nail cure it would work just the same.
            I have no idea what the output voltages are and if there is any control signals feeding this board or not, it looks like two transistor switching power supply.
            • Amraks
              • Nov 2011
              • 725
              its just straight hooked up to mains power only isolated by a push in switch.
              Nothing is controlling it.
              • Amraks
                • Nov 2011
                • 725
                http://www.ebay.com.au/itm/AU-36W-UV...item51c3f3383f
                I reckon I will get one of these just get the power supply board out and wire it all to my machine.
                not much effort and its cheap.
                I will be curing phones in no time.
                You reckon it would be easy to over ride the timer switch?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5016
                  • New Zealand
                  Should work as long as it uses the same lamps. I doubt the timer is an integral part of the PSU, probably just disconnect it, should be fine.
                  -David VanHorn
                  • Amraks
                    • Nov 2011
                    • 725
                    cheers hopefully it all fits.
                    I am looking for a alternative though, I got until pay day anyway.
                    I am wondering if you can order these boards else where not knowing what to call them is difficult
                    • Amraks
                      • Nov 2011
                      • 725
                      I think I have found out what to call them DC ballast.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5016
                        • New Zealand
                        They are generally called electronic ballasts, I believe.
                        Looking at this http://commons.wikimedia.org/wiki/Fi...st_for_G23.jpg it may be possible to use an old CFL lamp circuit.
                        http://translate.google.co.nz/transl...D5&prev=search
                        Or use product such as http://www.ebay.com/itm/SCHWABE-Ball...-/361109484165
                        Disclaimer, I am not an expert with CFLs\fluorescents etc.
                        -David VanHorn
                          • 31163
                          if you need a mains to cfl ballast,
                          just get a dirt cheap cfl and bust it open to use the board.
                          while your at it, put a decent cap in it like a panasonic NHG instead of the crap they come with.
                          maybe you should tell us about the lamp(s) you need to drive.
                          • Amraks
                            • Nov 2011
                            • 725
                            The lamps are 2 pin, 9w uv lamps.
                            I have spoken to a electrician he has told me to use a 36w ballast and connect them in series.
                            • Amraks
                              • Nov 2011
                              • 725
                              Well I have connected the UV lamps in series just waiting on ballast
                              I am also going to add a fuse to this machine as it wouldn't hurt to have some protection.
                              My Scotle IR-Pro-SC v4 has a RCD but in this device there is no room to go to that extreme
                                • 31163
                                got a foto or part number for those lamps?
                                they may be 4 pin tubes with a starter hidden in the base.
                                if they are, putting them in series probably wont work.
                                • t4796
                                  Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
                                  by t4796
                                  I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
                                  Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
                                  From the FAQ I learnt that for 110v the power...
                                  10-25-2024, 06:59 PM
                                • maleksa
                                  Yamaha SY85 power board 220v or 110v?
                                  by maleksa
                                  I need help to ascertain if the power supply on my Yamaha SY85 keyboard is 110v or 220v or both.
                                  I have attached the schematics below....
                                  07-01-2023, 08:49 PM
                                • caphair
                                  Can I convert the head of a 250v plug to 110v?
                                  by caphair
                                  Purchased a heating platform for repairing iPhone X models. It’s compatible with both 110/250v but they sent me the 250v plug and won’t respond to my messages to have the correct plug sent.
                                  The plug isn’t built into it, just plugs in with special connector which is how it’s compatible with both systems. Could I simply cut the 250v head and splice in a 110v plug or simply use an adapter like this? European Adapter, Fosmon Type C EU to USA & Canada Travel Adapter Plug, 2 Prong Universal Power Converter (Black) https://www.amazon.com/dp/B072F91W38...pi_i_LSIFDbA1D...
                                  09-15-2019, 04:50 AM
                                • adelage
                                  220v Led strip flickering
                                  by adelage
                                  Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                                  I know that the best solution would be to get a voltage...
                                  11-03-2024, 09:49 AM
                                • Gadjet
                                  Looking for a Fuse T4AL/250V
                                  by Gadjet
                                  I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
                                  06-15-2025, 09:16 AM
