Recap of "The Best Power" MT-500P 500W PSU
  • Newbie2
    • Sep 2005
    • 885
    After my L&C PSU recapping, I decided to recap another PSU. This time, it's a PSU that is more worthy of a pre-emptive recapping. It's called "The Best Power" MT-500P, and it looks better than the L&C. Better heatsinks, more caps on the secondary side, and 470uf 200V caps on the primary side than 330uf 200V caps in the L&C.
    Here is the list of cap replacements:
    2 TEAPO 680uf 10V SC series 8MM caps - replaced with 2 Nichicon 1000uf 6.3V HE series 8MM caps.
    2 TEAPO 1000uf 10V SEK series general-purpose 10MM caps - replaced with 2 SAMYOUNG 1500uf 10V LXV series 10MM caps.
    1 TEAPO 2200uf 6.3V SEK series general purpose 10MM cap - replaced with United-Chemicon 2200uf 6.3V SXE series 10MM cap
    1 TEAPO 470uf 10V SEK series general purpose 8MM cap - replaced with SANYO 470uf 10V WX series 8MM cap
    1 TEAPO 1000uf 16V SEK series general purpose 10MM cap - replaced with United-Chemicon 1200uf 16V (don't know which series, will look later) 10MM cap
    2 Fuhjyyu 220uf 16V (don't know which series, will look later) 8MM caps - replaced with 2 CapXon 220uf 16V KM series 8MM general purpose caps
    2 Fuhjyyu 470uf 200V LP series primary caps - replaced with 2 TEAPO 470uf 200V primary caps (at least TEAPO caps fail less than Fuhjyyu caps)
    Also, I refanned the PSU. It's a dual-fan PSU with 2 80x25MM fans, so I refanned it with suitable replacements.
    1 Rulian Science 80x25MM sleeve-bearing fan (exhaust fan) - replaced with EVERCOOL EC8025H12B 80x25MM dual ball-bearing fan
    1 Rulian Science 80x25MM sleeve-bearing fan (top intake fan) - replaced with StarTech Mutant Mods 80x25MM RED-LED dual ball-bearing fan (looks awesome when the PSU is on)
    Will post pictures later.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
  • linuxguru
    • Apr 2005
    • 1564
    Re: Recap of "The Best Power" MT-500P 500W PSU
    I'm curious about the Samyoung LXVs. I've got inexpensive Korea Chemicon LXVs (with a dot in the shield logo) sourced locally, and I'm convinced that they're actually Samyoung OEM based on the finish on the cap top, the indentation on the vent pattern, the 'S' lettering in the bottom rubber bung, and the printed font.
    I'll update the thread if I see any premature failures within a year. What do your Samyoungs look like?
    • Newbie2
      • Sep 2005
      • 885
      My SAMYOUNG caps are UCC cap look-alikes. The shield logo on them has the dot in it. The bung has a V on it, and it's the exact same style as a UCC cap I have. The vent is almost identical.
      I got two pictures to compare between my SAMYOUNG cap and the UCC cap.
      My gaming PC:
      • Newbie2
        • Sep 2005
        • 885
        I now got the pictures of the "The Best Power" 500W PSU.
        My gaming PC:
        • Harvey
          • Apr 2007
          • 264
          It seems to be running a little warm if the second image is anything to go by
          • linuxguru
            • Apr 2005
            • 1564
            The Korea-Chemicon LXVs that I sourced are nearly identical in appearance to your Samyoung, including the deeper indentations in the vent, font, etc. This seems to suggests that Samyoung and Korea-Chemicon caps are produced in the same plant and only differ in branding.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              its missing the line choke,x,and y caps.
              looks as if its running way too hot .
              • Newbie2
                • Sep 2005
                • 885
                I would like to add those x and y caps on that PSU. I just don't know which caps to use though. I'm thinking ceramic disc or flim.
                This PSU is a Macron PSU, according to a search of its UL number (E199529). I heard Macron power supplies are good in build-quality.
                I want to make this PSU better to replace that POS L&C 450W PSU that is currently still alive in my backup PC.
                My gaming PC:
                • Robin21
                  Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
                  by Robin21
                  I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
                  I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
                  All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
                  I've replaces both buck regulators already (AOZ1212)...
                  09-25-2025, 03:24 AM
                • ChanHa
                  Help me Resistor on FSP Hexa ATX 500w
                  by ChanHa
                  My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
                  06-04-2025, 08:44 PM
                • iMic
                  IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                  by iMic
                  Hi folks,
                  I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                  The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                  11-29-2023, 06:44 AM
                • anikin73
                  Cooler Master 500W atx psu repair. Total cannot start at all
                  by anikin73
                  I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
                  5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
                  What other pin should I check such that it will result in no start up at all ?
                  07-07-2024, 07:06 AM
                • em132
                  Okay to use 6.3V caps on 3.3V line of PC PSU?
                  by em132
                  I'm currently in the process of re-capping a NOS (new old stock) Sparkle ATX-400PN (from the late-2000s), which was chock-full of Teapos and CapXons . Am looking to put a yummy mix of NCCs, Panos and Rubys in their place.
                  Here's the problem I ran into: The 3.3V rail is filtered by a single 4,700uF/10V Teapo... The problem? This thing is only 10mm wide, and a wider (12mm) cap will not fit! I've searched the "big three" shops (Mouser, Digikey, Newark/Farnell) and all the 4,700uF/10V I found were at least 12mm wide. The closests matches I could...
                  05-30-2023, 03:41 PM
