Antec SP-500 Burned Resistor and Big Bulging Caps
  • Jonny Accelerant
    Banned
    • Aug 2014
    • 205
    There are several other threads on the Antec SP-xxx series that can be found using the "Search" function, for anyone looking for help on their Antec PSU's (besides this thread).
    This PSU was installed in 2006 on a small business server that has been running 24/7 for the last 7 years before the Server would no longer power on. Replaced the Antec and the Server operates normally.
    Visual inspection shows 2 things. 1) There's a small resistor that seems to connect the ground & hot of the 120VAC, that is burnt, and one of the large, (what other threads have called) "filter capacitors", is bulging (but not leaking). I assume both of these will need to be replaced. I have an OCZ that I've gone "maximum" on, and have desoldered every single cap and plan on replacing each of them, but on this Antec I'd like to go "minimum" in order be able to compare the difference between "good enough" and "best possible", so if there's any way to avoid replacing any capacitors that do not need immediate replacement, I'd like to do it that way and see how long the repair lasts.
    Questions:
    What is the purpose of the burnt resistor? Could it alone cause the problem of the Server failing to start on "power on"? (No fans spin, no clicks, no bios beeps, no HD spin, no nothing).
    Could the bulging capacitor cause the no-start problem?
    If no to both of these, what is the most likely explanation for the problem?
    Is the big yellow rectangle next to the burnt resistor a "start" capacitor? Or what?
    Thanks in advance, and any help appreciated.
  • c_hegge
    • Sep 2009
    • 5219
    Re: Antec SP-500 Burned Resistor and Big Bulging Caps
    That resistor is there to discharge the yellow X Cap (which is for EMI filtering) to make sure you can't electrocute yourself by touching the pins on the AC receptacle after you unplug the power cable. It has no effect, however, on how the unit functions and is not the cause of your problem. It could be the bad primary caps, but chances are, just about every cap in that PSU has failed. It's very rare than one of these lasts longer than 3 years without bad caps. Do NOT do a minimal repair on it. Give it a complete recap now, or you will have to keep doing it.
    Another good idea on these is to put a 2.5K resistor in parallel with the fan control thermistor. The fact that the fans run so slow on these units is a big part of the problem.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yeah, most caps in those fail, even the 1uF ones. These can be a pain to work on too, they're cramped, and the solder side will be pretty messy. Good units though.
      • Escort Eagle
        • Jul 2012
        • 110
        Yellow X Cap looks OK . Use 1M ohms instead of 560K . Your one of the filter capacitor is bulged . You have to change that filter capacitor (changing both capacitor will be better) . There are two resistors value may be 150K or 220K or 330K parallel connected with those filter capacitors . This Filter capacitor bulged due to damage of one of the resistor . You have to check those resistor and replace them also .
        By the way - Is there +5VSB present on the PSU ??
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Likely a faulty fan controller that caused Kentucky-fried caps!!
          (My SmartPower 500 W) (Even when this looks like an earlier revision) had a faulty fan controller it just randomly stopped turning on one of the fans.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Ahhh. So this is how SmartPowers find a way to kill Panasonic primaries
            • Behemot
              • 4845
              • CZ
              Yeah basically if you loose the ability to balance the caps, one may get higher voltage than 200 V and in time it will fail. If the difference gets too high, it can be pretty fast…
              • mockingbird
                • Dec 2008
                • 5484
                Interesting... Antec put Panasonic primaries in the SP-500 but Fuhjyyus in the SP-450 IIRC.
                  • 31046
                  that must be very old, i'v never seen an antec without PFC
                  • dmill89
                    • Dec 2011
                    • 2534
                    It is, one of the old CWT built Antecs loaded with Fuhjyyus. I think they were discontinued around 2005-2006 when Antec stopped using CWT and an OEM. I'm almost amazed that there are still any of them around that haven't already been re-capped.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      I have a Smart Power made by CWT, date code on the transformer is early 2007, still loaded with Fuhjyyu
                      • c_hegge
                        • Sep 2009
                        • 5219
                        http://hardwareinsights.com/wp/antec...supply-review/
                        Antec continues to use CWT as an OEM and use Fuhjyyu caps (or at least Jun Fool branded versions of them) down to this day in the PSUs they bundle with cases.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          ^ It's lame that they're still using them but I bet they last a lot longer in that PSU, without the 2 transistor 5VSB, and more room for airflow on the secondary side.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            True. The fan controller is also far more aggressive on the VPA500P than it was on the SP-500.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              If I recall, I think you were the one who had a problem with primary caps failing on a PSU. It was because of an open-circuited resistor (As Escort Eagle said)
                              I also seem to recall, someone else on here had a similar looking PSU that cooked the panasonic primary capacitors too.
                              Muh-soggy-knee
                              • mikey5791
                                Need help to replace burned resistor in 350w atx psu
                                by mikey5791
                                Hi to all forum members,
                                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                12-26-2024, 04:55 AM
                              • jinu_j
                                by jinu_j
                                Hi
                                05-03-2025, 10:51 PM
                              • MidnightRoller
                                Can a resistor lose resistance after hot air?
                                by MidnightRoller
                                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                02-02-2022, 11:46 PM
                              • artvandalai
                                What resistor ohm will work better to repair this waterpik?
                                by artvandalai
                                The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                01-05-2025, 04:10 PM
                              • SluggerB
                                Help diagnosing Pyle Receiver PTA66BT with burned resistors
                                by SluggerB
                                Spoiler alert: I am a total noob at this, just getting into the hobby
                                My buddy has an audio receiver that stopped worked, everything turns on and functions but no sound comes out of any output (Speaker, AV, or Headphone) So I said I would take a look at it. I popped the cover off, and saw an obvious issue: One of the resistors on the board had burned up.
                                Photos:
                                08-03-2020, 07:50 PM
