How Can I test PWM DM0365R?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    Hello
    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.
    In the vicinity of this capacitor(16v 470uf), There is ka431az regulator,I desoldered it and tested it by following below youtube guide.
    https://www.youtube.com/watch?v=_BYSsQ4ODEU
    I noticed that the result of diode test mode is not the same with youtube guide.So I purchased ka431az regulator which has the correct result of diode test mode, and replaced abnormal ka431az regulator with it.
    But It is still fluctuating output DC voltage between 11.5V-12.2V and I still heard constant tik tik sound.
    So I desoldered optocoupler and tested it with analogue multimeter by following below youtube tutorial and I also tested all of its diode with diode test mode, but It seems that there is no abnormality,
    https://www.youtube.com/shorts/mDwkd3PD4sQ
    I want to test PWM DM0365R which is located just above the largest capacitor(400v 10uf) But How can I test PWM DM0365R?
  • R_J
    • 9535
    What are you using as a load on thge power supply output? if it is left open you will likely be in burst mode so the power supply is working normally, read the datasheet on the dm0365. Try using an automotive incandescent lamp similar to a 1156 as a load
    6. Burst Operation : In order to minimize power dissipation
    in standby mode, the FPS enters burst mode operation. As
    the load decreases, the feedback voltage decreases. As
    shown in Figure 8, the device automatically enters burst
    mode when the feedback voltage drops below
    VBURH(500mV). Switching still continues but the current
    limit is set to a fixed limit internally to minimize flux density
    in the transformer. The fixed current limit is larger than that
    defined by VFB = VBURH and therefore, VFB is driven
    down further. Switching continues until the feedback voltage
    drops below VBURL(350mV). At this point switching stops
    and the output voltages start to drop at a rate dependent on
    the standby current load. This causes the feedback voltage to
    rise. Once it passes VBURH, switching resumes. The feedback
    voltage then falls and the process repeats. Burst mode
    operation alternately enables and disables switching of the
    Sense FET and reduces switching loss in Standby mode.
    • CapLeaker
      Leaking Member
      • 8088
      I would suggest you do check the whole feedback circuit first. There should be more than the optocoupler and the KA431 as the later is programmable with shunt resistors. Maybe these resistors are bad or the optocoupler.
      If you power up the PSU, put the negative probe of your DMM on the secondary negative and probe with the positive lead on the two legs on the optocoupler secondary side. What DC voltages do you measure?
      Check out the voltage Vcc pin on the PWM and recheck the main filter capacitor and the little capacitor next to it. Check the resistor on Vstr pin.
      If all capacitors are good, all components on the feedback are good, the fast recovery diode on the secondary is good, then download the spec sheet of the PWM and check the suggested voltages around its pins. If that doesn't yield any results maybe the PWM is bad, but usually they don't fail like that. What happens if you put a load on the power supply like a small 12 V light bulb?
      Look at page 14. That example is very close to your PSU.
      Be careful working on the primary side of the PSU. Your ground point for measuring anything after the bridge rectifier on the primary is the negative of the 400V main capacitor.
        • 30977
        replace the yellow electrolytics with low esr like panasonic FR or rubycon ZL
        • chth96
          • Nov 2022
          • 118
          • indonesia
          Thank very much for all of reply!
          I measured DC voltage between each legs on the optocoupler secondary side and negative pin of capacitor(16v 470uf) in the secondary side.
          It fluctuated between 11.2V and 0V, 10.5V and 0V like below dropbox links.
          https://www.dropbox.com/scl/fi/jyfv2...=xdhx48j4&dl=0
          https://www.dropbox.com/scl/fi/t1rrf...=yr7vnlo0&dl=0
          I measured DC voltage between pin1(Ground) and pin2(Vcc) of PWM DM0365R and also measured DC voltage between pin1(Ground) and pin3(Vfb)
          It fluctuated between 10.6V and 0V, 0.22V and 0V like below dropbox links.
          https://www.dropbox.com/scl/fi/k0grn47uh7fgr2s11mj62/20250619_164149.mp4?rlkey=vhpgbut5sgc8jx2ppq2okaf4r&e=1&st=dd2b7vmu&dl=0
          https://www.dropbox.com/scl/fi/0vef5...=m7w4uz9a&dl=0
          I measured DC voltage between positive and negative of main filter capacitor(400v 10uf) and that of the little capacitor next to it.
          voltage of little capacitor fluctuated between 10.7V and 0V, But filter voltage of capacitor was constant 309V like below dropbox links.
          https://www.dropbox.com/scl/fi/hldem...=wkmqu8we&dl=0
          https://www.dropbox.com/scl/fi/pa1o3...=8xrrexe5&dl=0
          And I don't have any load like 12 V light bulb.So currently it is impossible to do load test.But Sooner or later, It would be possible to purchase MR16 12V 5w led for load.
          MR 16 (12 volt) - Led verlichting shop, noodverlichting
            • 30977
            the transformer generates the output that gets rectified by the diode and smoothed by the 2 yellow caps and the inductor between them.
            that is then fed back via the optocoupler to the control chip using the tl431 as a reference.
            those are the parts that need to be checked if it's unstable.
            incidentally, tl431 is very difficult to actually test - it's best if you suspect one to just swap in a fresh one and see if it changes anything.
            optocouplers can slowly degrade too, but that usually causes voltages to be high or low, not unstable.
            the ticking sound is disturbing,
            i would desolder the transformer and examine where the windings are soldered to the legs - it could be a bad transformer connection
            • chth96
              • Nov 2022
              • 118
              • indonesia
              I finally measured resistance of carbon resistor..
              resistance of R9 resistor is 0.99kohm and R8 is 3.904kohm
              Click image for larger version  Name:	20250617_080707.jpg Views:	0 Size:	2.76 MB ID:	3662685
              below carbon resistor is the biggest(1w) resistor in this PCB
              resistance is 47.12kohm
              Click image for larger version  Name:	20250617_080827.jpg Views:	0 Size:	3.57 MB ID:	3662687
              R2 resistor is 55.06kohm and this resistor is directly connected to Vstr pin of PWM DM0365R
              Click image for larger version  Name:	20250619_214645.jpg Views:	0 Size:	1.27 MB ID:	3662689
              From the top resistor,resistance is 675.2 ohm, 0.996kohm, 6.91kohm
              Click image for larger version  Name:	20250619_215555.jpg Views:	0 Size:	1.10 MB ID:	3662688
              biggest(1w) resistor is 47.12kohm and a resistor which stands vertically is 10.6 ohm
              Click image for larger version  Name:	20250619_215854.jpg Views:	0 Size:	1,010.3 KB ID:	3662699
              A resistor which placed in a row direction is 1.399kohm and other resistor which placed in a column direction is 33.7ohm.
              Click image for larger version  Name:	20250619_220405.jpg Views:	0 Size:	966.1 KB ID:	3662700
              • CapLeaker
                Leaking Member
                • 8088
                You found your problem. VCC on pin 2 on the PWM appears then disappears. That shouldn’t be. Vcc need’s to be at least 12v for the PWM to work. If it is below a certain voltage, the PWM goes into UVLO. Read the spec sheet I posted earlier.
                • chth96
                  • Nov 2022
                  • 118
                  • indonesia
                  I connected 10w 1k ohm ceramic resistor to negative and positive output connector of power adaptor for output load test. I noticed that Its output voltage is less than 0.1V and Its fuse(sr5 1a 250v) was blown as soon as I measured voltage of main filter capacitor.
                  So Yesterday, I purchased bussman sr5 1a 250v fuse and 20w 12 ohm ceramic resistor, and I replaced blown fuse with it, And connected 12 ohm ceramic resistor to negative and positive output connector of power adaptor.
                  When I measured its output voltage with DMM, Finally It displayed stable 12.15V instead of fluctuating 11.5-12.2V.
                  But I noticed that Whenever I switched on power adpator,It start to fastly heat up 20w 12 ohm ceramic resistor and this ceramic resistor became too hot to touch with bare hand.
                  I wonder Why ceramic resistor became too hot whenever I switched on power adaptor.
                  • CapLeaker
                    Leaking Member
                    • 8088
                    Put a different load on it like incandecent car light bulbs. After all you were trying to heatsink 1A on the secondary. Did you replace the fuse with a resistor? Makes the power supply work much harder.
                    • chth96
                      • Nov 2022
                      • 118
                      • indonesia
                      Of course,I replaced blown fuse with new fuse(bussman sr5 1a 250v) which has the same voltage and ampere specification of blown fuse.It seems that It takes quite long time to receive incandecent car light bulbs from aliexpress,So I purchased fuse and ceremic resistor from local shop.I also connected 20w 24 ohm ceremic resistor to negative and positive output connector of power adaptor for output load test, It also displayed stable 12.15V as with 20w 12 ohm ceremic resistor did.
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • dj8452000
                        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                        by dj8452000
                        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                        02-18-2025, 08:28 AM
                      • asr
                        Finding replacement diode iPad Pro 3rd gen A1701
                        by asr
                        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                        07-09-2024, 06:24 PM
                      • khelane
                        test active pfc power with lamp test
                        by khelane
                        Hello
                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                        Is there a way...
                        06-03-2025, 01:00 AM
                      • chronic519
                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                        by chronic519
                        Hello.
                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                        Found issue with a RAM block
                        Replaced, green lines gone.
                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                        Used a good card to test and same results low errors 32+.
                        I am just search for some form of command to do a full test on the GPU.
                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                        The repaired one, ran...
                        05-20-2025, 07:56 PM
