Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.
In the vicinity of this capacitor(16v 470uf), There is ka431az regulator,I desoldered it and tested it by following below youtube guide.
https://www.youtube.com/watch?v=_BYSsQ4ODEU
I noticed that the result of diode test mode is not the same with youtube guide.So I purchased ka431az regulator which has the correct result of diode test mode, and replaced abnormal ka431az regulator with it.
But It is still fluctuating output DC voltage between 11.5V-12.2V and I still heard constant tik tik sound.
So I desoldered optocoupler and tested it with analogue multimeter by following below youtube tutorial and I also tested all of its diode with diode test mode, but It seems that there is no abnormality,
https://www.youtube.com/shorts/mDwkd3PD4sQ
I want to test PWM DM0365R which is located just above the largest capacitor(400v 10uf) But How can I test PWM DM0365R?
