Now is it really 680W as it says on the label - I would not say, rather, it is somewhere around 400-450W ... The company is "Echostar", nice "golden" cover even the quite heavy, with two fans. The interior is very simple - on the secondary side of a single LL(TL)494 and 10 TO-92 transistors plus TL431... Anyway, what happens: after applying voltage to 220V power, the computer starts up immediately, and works normally. Power supply tester shows 590ms PG and it blinks and beeps... Power good signal is 0V... Suspicious electrolytes are replaced, and replaced TL494 too... I have no idea what it might be ...?
Echostar 680W power good 0V
Re: Echostar 680W power good 0V
Are all the other voltages in spec?
Also, do you have any other pictures of its internals? Ideally, one from the top down, and another of the solder side of the PCB. This will allow us to get a better idea of exactly what kind of circuit we are dealing with.I love putting bad caps and flat batteries in fire and watching them explode!!
TL494 has nothing to do with power good signal. If it doesn't have a LM393 or LM339 then it must be generated by some of those TO-92 transistors. Test them, or just replace them all and call it a day, as you can pull them from any dead cheap PSU.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
5.13V
3.37V
12.03V
Pictures:
I guess this PSU not for 220V mains, 200V primary caps? But surprisely you have voltages, except PG voltage. That Gold Shiny Case is Beautiful !!Last edited by senz_90; 12-13-2013, 10:53 AM."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
I don't mean to be rude... but it's an echo star... one of the most "gutless" brands. There's a thread around here by Kc8adu about a particular "480W" echo star PSU that was so gutless they put lead dummy weights in it to make it feel better built.
I'm all for experimentation but keep in mind that you'd probably have to redo 80% of the PSU to make it decent...sigpic
(Insert witty quote here)
Originally posted by ratdude747 View PostI don't mean to be rude... but it's an echo star... one of the most "gutless" brands. There's a thread around here by Kc8adu about a particular "480W" echo star PSU that was so gutless they put lead dummy weights in it to make it feel better built.
Like Th3_uN1Qu3 said, test the switchers. Also, I would replace all the caps on the 5VSB, the two next to the switchers, and see if it works. And look for bad/cold solder joints.
Originally posted by senz_90 View PostI guess this PSU not for 220V mains, 200V primary caps? But surprisely you have voltages, except PG voltage. That Gold Shiny Case is Beautiful !!I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by senz_90 View PostI guess this PSU not for 220V mains, 200V primary caps? But surprisely you have voltages, except PG voltage. That Gold Shiny Case is Beautiful !!Last edited by miligor; 12-14-2013, 02:56 AM.
It looks good with that gold case. I wouldn't give it 400W, though. I doubt it would manage much more than 250W before blowing the switchers.Last edited by c_hegge; 12-14-2013, 04:40 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
forget my reply. I just wake up very late and makes a ridiculous reply yesterday. I am just realized after read it again. LOLI am forget that ATX have 2 series primary caps.
Yesterday I am just try to fix my friend TV and think the smps on TV same as ATX."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
^EscortEagle, some motherboards are like that. They will power on as soon as they get 5V stby. It isn't the PSU, it is the motherboard that tells the PSU to turn on.
Uh ... are those 85 degrees C rated 'SWCON' caps?! Those are TRASH! Let alone 85C!Muh-soggy-knee
