Now is it really 680W as it says on the label - I would not say, rather, it is somewhere around 400-450W ... The company is "Echostar", nice "golden" cover even the quite heavy, with two fans. The interior is very simple - on the secondary side of a single LL(TL)494 and 10 TO-92 transistors plus TL431... Anyway, what happens: after applying voltage to 220V power, the computer starts up immediately, and works normally. Power supply tester shows 590ms PG and it blinks and beeps... Power good signal is 0V... Suspicious electrolytes are replaced, and replaced TL494 too... I have no idea what it might be ...?
Echostar 680W power good 0V
Re: Echostar 680W power good 0V
Are all the other voltages in spec?
Also, do you have any other pictures of its internals? Ideally, one from the top down, and another of the solder side of the PCB. This will allow us to get a better idea of exactly what kind of circuit we are dealing with.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
TL494 has nothing to do with power good signal. If it doesn't have a LM393 or LM339 then it must be generated by some of those TO-92 transistors. Test them, or just replace them all and call it a day, as you can pull them from any dead cheap PSU.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Voltages:
5.13V
3.37V
12.03V
Pictures:Attached Filesif you find these attachements useful please consider making a small donation to the site
I guess this PSU not for 220V mains, 200V primary caps? But surprisely you have voltages, except PG voltage. That Gold Shiny Case is Beautiful !!Last edited by senz_90; 12-13-2013, 10:53 AM."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
I don't mean to be rude... but it's an echo star... one of the most "gutless" brands. There's a thread around here by Kc8adu about a particular "480W" echo star PSU that was so gutless they put lead dummy weights in it to make it feel better built.
I'm all for experimentation but keep in mind that you'd probably have to redo 80% of the PSU to make it decent...sigpic
(Insert witty quote here)Comment
That was a Powmax though, this looks like a different OEM, and much better built.I don't mean to be rude... but it's an echo star... one of the most "gutless" brands. There's a thread around here by Kc8adu about a particular "480W" echo star PSU that was so gutless they put lead dummy weights in it to make it feel better built.
Like Th3_uN1Qu3 said, test the switchers. Also, I would replace all the caps on the 5VSB, the two next to the switchers, and see if it works. And look for bad/cold solder joints.Comment
Whaaaaat? They are connected in series on 220/230V mains, so the maximum voltage is 400V. It's extremely rare to see primary caps rated for more than 200V, even in countries with 230V mains.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
It looks good with that gold case. I wouldn't give it 400W, though. I doubt it would manage much more than 250W before blowing the switchers.Last edited by c_hegge; 12-14-2013, 04:40 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
forget my reply. I just wake up very late and makes a ridiculous reply yesterday. I am just realized after read it again. LOL
I am forget that ATX have 2 series primary caps.
Yesterday I am just try to fix my friend TV and think the smps on TV same as ATX."There is no shortcut to be successful. No pain, no gain."
Best Regards
Rudi
Thank You
When you Shut down the PC from Windows, then PSU remains Off ?
I got a such kind of PSU which starts immediately after Plugging in . It is such kind of design .Comment
^EscortEagle, some motherboards are like that. They will power on as soon as they get 5V stby. It isn't the PSU, it is the motherboard that tells the PSU to turn on.
Uh ... are those 85 degrees C rated 'SWCON' caps?! Those are TRASH! Let alone 85C!Muh-soggy-kneeComment
Assuming...7 Photos -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
