Re: faulty power supply?
Do not use a typical 1000uF, 10V, 8mm caps even if you find them. They'll either be higher ESR or too poorly constructed to last long term (part of why the originals probably failed, off-brand caps with unusually high mF per their voltage and physical size are among the most failure prone).
Decide what brand and model you want to use based on what your preferred vendor sells, and if a 10mm cap will fit, use one. If only 8 mm will fit, choose a 6V cap with the highest uF value (taller size) available. Since it is only a 10V part it can't be on the 12V or -12V rails so with any other voltage under 6V, a 6V (actually I mean 6.3V) cap should do fine.
Yes Rubycon MBZ and MCZ are suited for PSU, but are actually a bit of a luxury in a PSU as even good PSU brands often opt for lower cost caps instead (not junk, just not the extra cost for an ultra-low ESR 'lytic) which have stood the test of time.
If high heat is a factor, any lytic isn't going to do well long term. In that case seek to increase airflow, either increase exhaust rate out of the PSU or case intake on the case it'll be installed in.
