Weird issue with HEC Orion PSU
  • c_hegge
    • Sep 2009
    • 5219
    Re: Weird issue with HEC Orion PSU
    I wonder if the output caps could be faked too. Wouldn't surprise me if HEC sourced them from the same supplier as the primaries.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I will check all of those caps after I pull them. They look pretty genuine but then again, so do those primaries
      • lti
        • May 2011
        • 2557
        Those caps were unusually small.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Yeah, pretty small. And they're very light!
          • domas
            News Hater
            • May 2013
            • 323
            • Denmark
            after you fixed the transistor, is the primary heatsink getting as hot as before?
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              ^ No, it is not as hot as before, but still pretty warm
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                It looks so much better now added 2 X caps (Both 0.47uF), 2 Y caps, and 2 coils for the input filtering.
                Added a much larger 6A bridge rectifier, replaced those Teapo caps with those 680uF OST caps
                Replaced all of the secondary caps. The 12V only had a single 2200uF cap and no inductor (But it has one on all the other rails....) so I put in a 3300uF KY cap, I'm hoping that will lower the ripple a little bit. The 3300uF KY cap has 1,100 more rated ripple current than the 2200uF Teapo SC. All the voltages look good, and it's been powering a hungry P4 system for a while now
                Edit: All the Teapo secondary caps were in spec, but there was one SEK (GP) which had pretty high ESR
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  #28
                  Didn't it originally have an 8A bridge without a heatsink? The one in the review did (GBU806 by Lite-on semiconductor).
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Not mine, it had a wimpy GBL406
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #30
                      Looks nice and beefy now. Good job!
                      Only that minimum load resistor on the 5VSB bugs me a little bit, but it looks like a 47 Ohm one, so it shouldn't be that bad. It's dissipating about 0.5W of power. If it was any higher, I would have changed it.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Thanks man! Oh that one next to the 5VSB transistor? Can't believe I checked for those on the secondary but not for the 5VSB...I will remove it
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          Wait, is yours 27 or 47 Ohms? I just opened my Thermaltake TR 430W for the first time yesterday, and mine has a 27 Ohm load resistor for the 5VSB.
                          If it's 47 Ohms, it's dissipating about 0.53W, which isn't too terrible and you can probably leave it there. But mine is dissipating nearly 1W of power in Stand by - that's quite a bit too much. Enough to cook caps for sure.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            I believe it was 47. Not to worry though, I put it in my Linux server so it's been running 24/7 since the first week of June Since the standby is so inefficient I figured it would be good to throw it in something that would be running 24/7. Although man it is already pretty dusty because we have pets in the house and those two 80mm fans sure move a lot of air
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #34
                              Sounds good. Just keep an eye on that 5VSB voltage every now and then. This design DOES have a critical cap that can make the 5VSB sky-rocket. If it's still the original Su'scon (or whatever other crap HEC decided to use), it's only a matter of when it will fail, not IF.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                momaka you should know me by now, I don't let those stay I replaced the critical cap with a Panny FC. All the caps are Japanese except the OST on the input
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #36
                                  You know, it crossed my mind that you did, and you probably posted about it as well. I just didn't feel like reading over the last page again . So I thought I better mention it and be safe anyways .
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    Thanks for that I plan on testing its ripple soon as well
                                    • SuperJames
                                      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                      by SuperJames
                                      This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                      Specs
                                      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                      Backstory
                                      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                      10-23-2023, 04:09 PM
                                    • ugamazing
                                      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                      by ugamazing
                                      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                      04-10-2024, 08:06 AM
                                    • lukkihapsi
                                      Asus Vivobook X515JA Weird Boot Issue
                                      by lukkihapsi
                                      Asus Vivobook X515JA Laptop
                                      Issue :
                                      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                      Tried :
                                      Cleaned inside for dust, applied fresh thermal paste. No Change!
                                      Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                      Removed Internal SSD. No Change!
                                      Updated BIOS to latest version. No Change!
                                      Removed battery and pressing power button for 1 minute. No Change!
                                      Weird Part :
                                      Upon turning laptop ON, screen lights up - stays black,
                                      I...
                                      07-07-2025, 12:07 PM
                                    • tommygun26
                                      Hp 6510b weird issue
                                      by tommygun26
                                      Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                                      02-26-2023, 06:00 AM
                                    • Spider1211
                                      Weird but interesting issue with DELL 3542 (intel mb 13269-1)
                                      by Spider1211
                                      Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
                                      Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
                                      Backstory:
                                      Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
                                      Power supply draw:
                                      Voltage: 19.40V
                                      Amp draw: 0.006 - 0.007A
                                      Amp draw...
                                      04-07-2021, 03:21 PM
