Okay I have a small problem here, I was given a creative set by a friend and the power adapter on the decoder seems to be broken. Its
Creative Power brick
PRL: 240V ~50Hz 100mA
SEC: 16V ~ 600mA
16V
I have an old Toshiba adapter rated 15V
Input 100V - 240V ~ 0.95A - 0.55A 50 - 60Hz
Output 15V 3A (it has a Line _____ and dot dot dot --- below the line.
15V
Anyway, I cut opened the broken power brick, is there any way to fix it? or can I swap the Toshiba Brick with it? I did try to power the decoder with it for a few seconds. It works but quickly unplugged it as I dont want to risk it since it says 16V and my toshiba power brick is only 15V so dont know although I am sure the toshiba 15V x 3A should have more then enough power opposed to the 16V x 700mA.
But its a audio decoder, very rare too and the Line and Dots under neath it made me doubt before taking the risk until I am absolutely sure or if I can't fix whats wrong with the existing power brick.
I attached some pictures, as you can see the creative power brick has no caps or anything inside, just the transformer? I checked but its not getting any power.
SEC: 16V ~ 600mA
16V
15V
worked with everything else but not this one
Should I get that or can this be done cheaper?
I have repaired broken PCB and stuff before so if you can help me fix this one it will save me $50 USD (that's how the guy on ebay wants for the 120V replacement shipped) and on top of that I will need to spend another $20 on a step down 120V to 240V step down transformer. haven't heard anything from that UK stores website yet, I emailed them though.
