Channel Well DSI250P
  • turbozutek
    • Jan 2009
    • 71
    Hello my friends!
    I have just started using this:
    http://www.xbitlabs.com/articles/cas...roundup_9.html
    The Channel Well PSU, it's in a FoxConn Mini ITX bare-bones. Opening it up and having a poke around it looks to be a fairly well made PSU. The caps are SAMXON though, a brand I do not trust. For this reason I intend to recap with some nice Panasonics - and I shall also up the 1000uf secondary output caps to 1500uf.
    Also, I notice there is a primary input filtering coil, but also space on the board for a second one afterwards, though there is nothing installed there. I happen to have another coil (from a different PSU) - worth installing here do you think?
    Has anyone recapped a PSU like this before? Any caveats, ideas, other things I could do whilst I'm in there with the soldering iron?
    I want this PSU to be 'fit and forget' as much as possible. I will document this process here as I get around to it.
    Many thanks!
    Chris...
  • Behemot
    • 4845
    • CZ
    Re: Channel Well DSI250P
    Them being green seem to be Samxon GF, bad line. Other lines are actually good, at least the ones I have experience with: RS, RT, GA, GC, GD, GP, EP.
    You can increase capacity, just there us usually not much space inside these small units, friend of mine tends to recap them all the time and I never got caps squeezable there, maybe some NCC KY 1500 uF in D10x20 at most.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      What brand and series of capacitors are you planning to use for the output? Hopefully not motherboard grade, otherwise you may run into some instability issues.
      It won't make the PSU perform any better, but it will reduce the noise it puts back in the AC line. So if you have the space and a spare coil, then you might as well add it.
      Other than that, I don't see what else to add. Heat sinks look a bit small for a 250W PSU, but probably not worth the effort to change them. Overall, it looks like a decent power supply.
      • turbozutek
        • Jan 2009
        • 71
        Yep, I spent MONTHS recapping lots of things with those shh!ty green Samxons in them; it's why I don't trust the brand as a whole now. I gather they have improved greatly, but with plenty of other options for similar money, I shant be testing the theory!
        Oh? Tell me about that?
        I have Panasonic FR's that I can get very cheaply. Here's an example:
        http://www.newark.com/panasonic/eeuf...10v/dp/74R3405
        Is this OK for use in a PSU? If there's something better I could use, let me know what you reckon!
        I did use these caps (FR) for a different MiniITX recap a few months ago and it's been all stable since.
        Yeah, I have some amps and speakers on the same branch circuit so it can't hurt, hey?
        Yeah, I was impressed. As for the heatsinks, I won't be pulling anything like 250 watts from it. Single HD, Sandy Bridge CPU and integrated graphics should make for a very small power signature.
        I will be looking at the fan, however... Not sure but it seems to blow backwards; drawing heat from the PSU and dumping it INTO the case. That don't seem right! Could be it's just blow back in such a tight enclosure, but when I have the PSU open I'll double check.
        Thanks for the input guys!
        Chris...
        • Behemot
          • 4845
          • CZ
          I cannot speak for others but the lines I have personally tested are know to be good for like 6+ years, I have RS in PSUs working for 4+ years now. As for the GF, take is as Chemi-Con's KZG. Cheapest of the so-so quality on the market, hence what it's "quality" looks like. GF do what they have in datasheet. Nothing over that. Now we make not to like it, but it's CWT deciding to use these, and not RS, NCC KY or whatever else.
          As for Panny FR, most likely it will do fine, even though it is a bit on the high side of ripple/low side of ESR for my taste
          • c_hegge
            • Sep 2009
            • 5219
            FR will work fine. They offer some smaller sizes which many other reliable brands don't, so sometimes, they can be your only option.
            • turbozutek
              • Jan 2009
              • 71
              Well, the greater the ripple current rating the better, no? :-/
              Yeah, these were the best option for 8mm caps I could find. I think a 1cm cap might JUST fit in there, but it's going to look a bit like a bunch of mushrooms standing proud from the board, which I don't like the looks of!
              Chris...
              • Behemot
                • 4845
                • CZ
                Not really, compensation, sometimes even transformer and filtering chokes are designed for some ESR values. It is usually not good to go too far from this designed values.
                • turbozutek
                  • Jan 2009
                  • 71
                  Hmmm, yeah that makes sense. Once I tear this PSU apart I'll try and find specs for the caps it currently has and compare with the new ones going in. I'll post findings of course.
                  That said, once I've recapped this 'un I reckon a few weeks of testing could be the way to go before I consider it fully stable enough to load on all my porn, uhm, I mean important business documents on!
                  Wish I had a load tester / ripple meter.
                  Chris...
                  • turbozutek
                    • Jan 2009
                    • 71
                    Quick update: it's dead.
                    PC would only 'blip' on for a half second today. Opened PSU and all looks well. Removed every SAMXON cap and replaced with some Rubycons I had lying around. PSU now 'starts', actually it starts the moment it's plugged in, which ain't right.
                    Put PSU tester on it and the -12v line is perfect the rest are high and low. 12v @ 7v and 5v at 6.15! 3.3 dials up 1.4v.
                    Looking around the web I see the consensus is these PSU's are total dogs**t. Not going to cry for too long over this one and I'm glad I didn't waste any money putting decent caps in there.
                    Chris...
                    • eccerr0r
                      old X58 triple channel board... memtest86 memory speed?
                      by eccerr0r
                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                      06-28-2025, 09:06 AM
                    • spleenharvester
                      Reverse engineering of 18650 4-channel tester
                      by spleenharvester
                      Hi friends
                      I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                      05-04-2025, 02:43 AM
                    • mikey5791
                      Help on car amplifier only one channel works
                      by mikey5791
                      Hi all forum members,
                      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                      08-06-2025, 10:36 PM
                    • dicky96
                      American Audio VLP1500 Distorting on one channel
                      by dicky96
                      Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                      Protection and Clip LED are off
                      There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                      I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                      The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                      07-13-2022, 05:25 AM
                    • dicky96
                      Hitachi V19B01922 Channel Tune problem
                      by dicky96
                      Hi Guys
                      I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                      He also has an LG TV, so three screens in the bar
                      I installed three Satlink ST-6503 DVB-T Modulators
                      This model https://www.aliexpress.com/item/32916553905.html
                      These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                      02-09-2023, 09:20 AM
