Hello my friends!
I have just started using this:
http://www.xbitlabs.com/articles/cas...roundup_9.html
The Channel Well PSU, it's in a FoxConn Mini ITX bare-bones. Opening it up and having a poke around it looks to be a fairly well made PSU. The caps are SAMXON though, a brand I do not trust. For this reason I intend to recap with some nice Panasonics - and I shall also up the 1000uf secondary output caps to 1500uf.
Also, I notice there is a primary input filtering coil, but also space on the board for a second one afterwards, though there is nothing installed there. I happen to have another coil (from a different PSU) - worth installing here do you think?
Has anyone recapped a PSU like this before? Any caveats, ideas, other things I could do whilst I'm in there with the soldering iron?
I want this PSU to be 'fit and forget' as much as possible.
I will document this process here as I get around to it.
Many thanks!
Chris...
I will document this process here as I get around to it.Many thanks!
Chris...
Half of the computer problems is caused by bad contacts
