First off, great site. I hope i picked the right section to post in.
Anyway I have a PSU 500W Antec ATX (about 4 years old) that started playing up. The +5V rail was down to 4.3-4.5V so I opened it up and had a look around. I noticed that 2 caps had gone, so i replaced them with Suntan 105c 10V 1000uf (See
which I got at my local electronics store.
After the re-cap, the +5V was at 4.9-5.1V, so I was over the moon.
1 Month later, over the last 2 weeks, the voltage has been getting lower and lower day by day. It currently around 4.6-4.7V and droping 0.1 per week.
I have not opened it back up, but I will do soon. I did by spare caps if I need to recap it again.
The question is, are these caps i used 10V 1000uf Suntan's () any good? I have been told to get Low ESR, or inpedance, but I can not compelety comprenhend the PDF.
I am thinking of re-capping with
They are the Panasonic FM series.
Side Note: I am in the process of repairing a Mobo, and need a 8mm 6.3V 1000uf, but the Panasonic don't do 8mm in FM, but they do in NHG (see:https://cdn.badcaps-static.com/pdfs/...26cc6762b4.pdf)
My other alternative is to just use Suntan CD263 10V 1000uf (which might work)..but are they a good cap)
So to finish up:
Are these caps good for mobo and PSU usage?
If no, what in the pdf told you that?
Would this be better: https://cdn.badcaps-static.com/pdfs/...26cc6762b4.pdf
If yes, why?
Can I use this for my 8mm 6.3V 1000uf mobo re-cap, or will the suntan CD263 do ?
Why did my PSU voltage go to +5V after the recap (suntan CD263 10V 1000uf x 2), only to drop to 4.6-4.7 1 month later?
So many Q's thanks for reading and hopefully answering..
P.S: I did no spellcheck..
opernsys
So to finish up:
If yes, why?
opernsys
