Voltage doubler? Which component(s) is it?
  • yanz
    • Nov 2004
    • 910
    so that i read this interesting article: Anatomy of Switching PSU (page 2)
    but i think the diagram is wrong. what makes the voltage doubler, is it the primary bulk caps? or the bridge rectifier? or is it just a trick in path arrangement?
    i live in the country where 220v is used. so i think my (non apfc) psu wont need the voltage doubler . what is the dc voltage applied to the primary bulk caps then? 240v-260v-300v?
    shouldn't the right scheme on that diagram is:
    Transient Filtering (AC Filter) -> Switch/Voltage selector/Voltage Doubler -> Rectification -> Filtering -> Switcher -> etc...
    days are so short when you actually do something..
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Voltage doubler? Which component(s) is it?
    The voltage doubler is existent in most non A PFC PSU`s circuit. it basically consist of the two caps and the corect wirering provided by the 110/220v switch. If the PSU is only sold in 220v locations, the mfk can take only one input cap with 400v rating and halfed capacitance. the other cap would be replaced by a jumper wire.
    This is IMHO typicall for ultra cheap psu`s, most branded p PFC psu´s don`t alter that.
    The diagram is IMHO correct.
    Function: both caps would be independently charged with 110v and then, if they are acting like a power source they would discharged in series, thus there is roughly the doubled voltage.
    Therefore it is obviousely, that the voltage doubler can`t be before the rectification.....elektrolytics don`t like AC mutch.
    • PeteS in CA
      • Aug 2005
      • 3579
      • USA, Unsure of Planet
      In the schematic on the page you posted, yanz, it's the switch shown right above the four 1N5406 rectifiers. On P/Ss, it's the voltage selector switch usually located right near the inlet. The voltage doubler is the reason plugging a P/S set for 115VAC into 220VAC results in a loud noise and an unpleasant odor.
      PeteS in CA
      • davmax
        • Dec 2005
        • 899
        Yanz. I tend to agree the block diagram you supplied is not good . Showing the doubler and rectifier seperate. In the circuit diagram you can see that the rectification takes place as part of the doubler. Doubling only occurs with 115v operation, for 230V the rectifier functions as a normal bridge circuit.
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • yanz
          • Nov 2004
          • 910
          that is what i'm talking about, gonzo. i think the writer was getting confused with the twin caps of Cy capacitor that he assumed as the main lytics. like you said, it's unlogical to put DC caps in front of bridge rectifier (in this case they are four Diode 1N5406, like Petes has mentioned).
          those 470uF 200V lytics that are paired in series would produce 400V (right or wrong?), but that within theirself. i do a real measurement on polarity of bridge rect, it's 268V (between + and -). i measure the voltage after those caps, they are still 268V.
          well tell me if im wrong. but imo the 268V comes as a result of conversion of ~270VAC at peak (average/rms 220V) by the bridge rectification diode(s).
          the series configuration of main caps aren't intended as voltage doubler, i guess. they are for filtering. on 220v country, a non apfc psu don't have a voltage doubler if it has no switch selector (the red 110v - 220v switch).
          so like davemax said, the block diagram on that page is wrong. but not because of the position of voltage doubler, but because it's missing the filtering section.
          im not really sure either, i think i have messed something in my understanding....
          so far i know, that the voltage doubler is the red switch, but how it works?
          • Spyke
            • Aug 2006
            • 13
            Each lytic gets hit with juice alternately as the AC waveform cycles. The power then from both lytic's in series is the doubled voltage. The bridge rectifier's output is still wired to the main lytics just as if it was set to 220V, but the center common connection between the 2 main lytics is connected to one of the AC mains wires. What the switch does is either connect or disconnect this mains wire connection. It's the simplest of voltage doublers.
            Yes, the series configuration of the main lytics is crucial for the voltage doubling.
            +160V+(C)-com+(C)-160V = 320V
            So yes, the pic is somewhat misleading, you can say the doubling comes after rectification, but a direct AC connection to the main lytics is still required to the circuit after rectification takes place.
            • yanz
              • Nov 2004
              • 910
              thanks, guys. please don't give up on me yet ok, im starting to see things a bit more clearly now. i have some idea for this thread so we can discuss this matter in more imaginative way. spyke, thanks bro for the explanation
              • PeteS in CA
                • Aug 2005
                • 3579
                Yer hopeless yanz. Just don't let me near a computer motherboard, .
                When the input voltage selector switch is set for 115VAC, it connects one side of the AC line to the center connection between the two lytics. Thus one of the lytics gets charged during the positive half-cycle of the sine wave input voltage and the other lytic gets charged during the negative half cycle of the sine wave input voltage.
                PeteS in CA
                • arneson
                  • Sep 2005
                  • 1267
                  First chapter text book quote on the subject.
                  Jim
                  • gs3
                    • Sep 2006
                    • 15
                    Sometimes I find that redrawing the circuit I can understand it better and that is what I have done here. Both circuits are equivalent. Now look at the lower one. open the switch and you have a normal four diode bridge with a capacitor (formed by two capacitors in series). Close the switch and you have a voltage doubler circuit where the two diodes to the right are not working. ´hope this helps.
                    • Sam Scarbo
                      Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                      by Sam Scarbo
                      My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                      I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                      If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                      See the attached two pictures of the small...
                      09-18-2024, 08:29 AM
                    • rddube
                      Lenovo L490 Ram voltage circuit malfunction
                      by rddube
                      Hello friends,
                      Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                      I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                      07-15-2025, 04:41 PM
                    • Fernon@Repair
                      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                      by Fernon@Repair
                      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                      VCCIO voltage ok
                      VCCSA Voltage OK
                      VCCPLL Voltage OK
                      Ram Voltage ok
                      RamVTT OK
                      VPP 2.5 OK
                      But No Core Voltage
                      and i want to this vrm ic datasheet or pinout (ISL69269)
                      anyone have this ic pinout voltages?...
                      06-25-2025, 07:19 AM
                    • t4796
                      Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
                      by t4796
                      I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
                      Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
                      From the FAQ I learnt that for 110v the power...
                      10-25-2024, 06:59 PM
                      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                      by sam_sam_sam
                      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                      Now...
                      06-09-2024, 10:57 AM
