Good evening
I am trying to relearn some of the basic electronics that I have long forgotten, and would appreciate some help understanding how the attached reverse engineered circuit from a broken no-name PS is supposed to work!
This should supply 12v DC at 1.2 amp from 230VAC (the circuit may not be correct but I have checked it several times)
The supply does not work and I suspect the LM358 is at fault (the 370 ohm resistor to the inverted input is clearly overheating). The cap is bad.
I think (!) that this is a dual rail supply, and am clear on the functioning of the +ve rail.
I am unclear as to the design of the -ve rail, as this appears at best to provide half wave rectification through the SCR. I am also unclear as to how it is referenced to the +ve rail, unless through Vs+ and Vs- (?) of the LM358
I do not remember what this was used to power, and it may be that the device smoothed the DC at input, but as it stands, I see only that the op amp is used as a comparator to check for the presence of a load, and to then activate the SCR to complete the circuit.
I also do not understand why the two windings are used on the transformer (rather than a single winding).
Any help in explaining how this circuit is intended to work would be greatly appreciated
, notably:
