Leadman LP-6100E problems
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    A friend got this psu out from his parts chest. He would have used it to power some p4 desktop, except the psu won't do anything. All secondary and primary caps were bad. There is definately some heat damage, both fans are stuck. I started to replace the bad caps and test other parts when I noticed that the 5vsb circuit is completely dead. The Fet and it driver transistor and a resistor for sure, Q7; Q3; R4.
    The main fet test good (irfpc60 maybe), not shorted at least. Secondary diodes and fuse are good. But I'm not sure about the 3842 pwm.
    I bartered a 300W Fsp for this. Maybe I can learn something from this psu.
  • everell
    • Jan 2009
    • 1514
    Re: Leadman LP-6100E problems
    What brand were the primary and secondary capacitors that were bad?
    Please post some pictures showing the entire top side of the power supply.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • 999999999
      • Sep 2006
      • 774
      I don't bother trying to repair PSU that had the fans seize then the whole thing baked... too much chance of more than just caps failed and that something else will still fail prematurely.
      What they teach me is don't run PSU with low quality fans unless you can constantly monitor them and relube them on a schedule.
      • pdavid
        • Jan 2011
        • 279
        • Hungary
        Original caps were Jee and Kosin. The primary cap's capacitance were droped to near zero, maybe one even got arced to the heatsink...
        One 100pf film cap has burned glue, measures good but I replaced that too.
        Also replaced a filter choke in the emi stage since the original got too much crap burned into it and when I was trying to remove it the enamel got damaged.
        You can see I sort of recapped this one. I guess wasting some Teapo caps is okay
        If I can't fix it it's still good for some parts.
        The second fan actually had a third sense wire but is stuck anyway.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Looks much better! Now it isn't a typical Leadman eye-sore. Those 4 diodes on the primary look pretty good sized but I'd still put a bridge rectifier there instead. I like how Jee tried to copy Rubycon's vent stamp.... Have you tested to see if it's working yet?
          • 999999999
            • Sep 2006
            • 774
            Are there any (consumer/PC grade) ATX PSU that can sense fan seizure? I've never owned any, though I had a LiteOn server PSU that could do it with only the two power leads. The fan didn't seize but if you stuck a straw in to stop it then the PSU shut off.
            • pdavid
              • Jan 2011
              • 279
              • Hungary
              I think some older Chieftec psus like Gps series or Channel Well's psh shuts of if the fan isn't running or if not connected... maybe Forton pnf too but I'm not soo sure.
              I'm still looking for problems in this psu. Those Jee caps werent holding up good for sure. All the 2200uF ones measured like 300uF max.
              Small transistors and diodes test ok. I'm replacing the fet and 3843 pwm chip.
              • pdavid
                • Jan 2011
                • 279
                • Hungary
                I replaced the 3843 pwm and main fet but somehow it keeps shorting the 5vsb fet There is about 340Vdc after the bridge rectifier and that's all. Resistors check up small caps too... I'm probably missing something here.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Check everything connected to the 5VSB circuit - both on the primary and secondary side.
                  On the primary side, the Auxiliary winding of the 5VSB transformer generates power for the 3843 PWM chip. IIRC, before this aux rail reaches the 3843 controller, it is first rectified by diode D2 and filtered by a 47uF 25V cap. This is actually the critical cap for the 5VSB so make sure to replace it with a known good one. Also make sure to check diode D2. After that, the aux rail goes through a transistor which is controlled by an optocoupler and then to the 3843 (this is the on-off function of the PSU. There may be a few other diodes in the circuit - make sure they're not shorted either. More particularly, check the snubber diode, D4.
                  On the secondary side, make sure the 431 shunt regulator is good. If you have a spare one, replace it anyways. They rarely go bad, but they can. Make sure the output diode and filter cap(s) are good as well.
                  If the transistor still keeps blowing, the 5VSB traffo may be toast.
                  I would suggest to use a 25W or 40W incadescent light bulb in series with the line input of the PSU - this will minimize (if not eliminate) the damage to the new components you put in the 5VSB. It will also stop your new fuses from blowing each time.
                  OR
                  If you want to check the power supply without the 5VSB circuit, first provide a 5V supply to the supervisory chip with an external power supply, and only then provide 18V to 25V to the input pin on the 3843 PWM IC. The external power supply for the 3843 PWM IC MUST BE isolated (i.e. not grounded), or you'll run into big big problems. The output ground wire on the external power supply for the 3843 PWM IC should be connected to hot ground (i.e. the (-) side of the bridge rectifier).
                  • pdavid
                    • Jan 2011
                    • 279
                    • Hungary
                    Thanks momaka! Now that you mention it I haven't checked the trafo and opto. I'm going to be away for a few days, but when I get back I'll give it a try.
                    • hkqq2010
                      • Sep 2012
                      • 39
                      • CHINA
                      This really is a very good practice.
                      In the past, when I first to repair PSU, it burn me so many fuse. Besides of fuse, it is also full of scare caused it always accompanied with some flash and a little flame. With a light bulb, it is safer.
                      I would use a 40W light bulb rather than 25W, caused it provides sufficient current to drive the PSU 12V fan when testing.
                      • pdavid
                        • Jan 2011
                        • 279
                        • Hungary
                        Thankfuly I have a stock of 60W bulbs. Now I can "legaly" buy only 20W in the EU. No more incadescent bulbs, cuz it's not good for the enviroment and wastes power... too bad.
                        The psu is working now. Turns out one opto was open on the primary side no matter what. Voltage regulation isn't great. I'm only going to keep this unit for parts and reference.
                        Thanks for the help everyone!
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          The most common failure mode of an opto is open. You're lucky it didn't go open on the secondary - it would have caused complete loss of regulation and definitely some smoke.
                          A working TV? How boring!
                          • pdavid
                            • Jan 2011
                            • 279
                            • Hungary
                            Somehow I always expect the least that an optocoupler or trafo going bad. Only seen some really lame psus fail catastrophically, with obvious signs.
                            • emil_t
                              RTX3090 working fine but fans not spinning
                              by emil_t
                              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                              04-12-2024, 06:54 AM
                            • b-slayer
                              Asus Strix-G15-G513RM fans don't work
                              by b-slayer
                              I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                              The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                              (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                              (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                              ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                              09-04-2025, 04:58 AM
                            • jean luc ferre
                              laptop hp g72 b52sf screen problems
                              by jean luc ferre
                              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                              06-07-2025, 03:27 PM
                            • JayPoorJay
                              Hot Water Rad - A Few ECU Fans and a Timer Switch
                              by JayPoorJay
                              Good Afternoon, Good People.
                              I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                              I REALLY would appreciate y'alls help.
                              This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                              10-29-2024, 12:54 PM
                            • Hondaman
                              USB problems?
                              by Hondaman
                              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                              08-12-2024, 03:26 PM
