Thermaltake TR2-500 Primary cap bad?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    This power supply powered a c2d 6400, 2x512MB DDR2, Sapphire X1650 PCIE, WD SATA 200GB 7200, DVD-ROM, DVD-RW, Hybrid PCI TV Card and 2 led fans without a problem for 5 years.
    My friend brought it to me to upgrade the RAM and take a look at it. I checked the voltages and they were all ok. It passed every test that I did to it. There are no bad caps on mobo.
    So, I opened the psu to take a look inside, being confident that everything would be ok.... I was wrong. There are 2 TEAPO 820uF 200V primary caps and 1 of them is bulging. I pushed the top of the cap with my finger but it doesn't get flat like the other...
    Why that cap failed?? There is no APFC, neither high frequency ripple, the input filtering is great and the capacitor is a Teapo, not some fuhjyyu or Capxon...
  • c_hegge
    • Sep 2009
    • 5219
    Re: Thermaltake TR2-500 Primary cap bad?
    I hate teapo.
    Also check the caps near the PFC Coil plug. They have two very hot resistors near them and can also go bad.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Originally posted by c_hegge
      I hate teapo.
      The good thing about those small caps is that, if I am correct, they are part of a circuit that acts like a voltage booster for the main primary caps. Those caps always fail and when they fail nothing happens, the voltage booster circuit just stops working! In fact I take them out from the Jou Jye psus that I recap. More info here:
      https://www.badcaps.net/forum/showpo...&postcount=109
      some pics and diagrams:
      https://www.badcaps.net/forum/attach...1&d=1268336235
      https://www.badcaps.net/forum/attach...2&d=1268336235
      https://www.badcaps.net/forum/attach...9&d=1268165068
      https://www.badcaps.net/forum/attach...0&d=1268166583
      • Shocker
        Banned
        • Dec 2011
        • 635
        So Teapo really is just another of the many Taiwanese manufacturers of crapacitors.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Oh yes there is high frequency ripple. Doesn't the SMPS draw power in high frequency pulses? You forgot about that one.
          A working TV? How boring!
          • c_hegge
            • Sep 2009
            • 5219
            Yup. They aren't as bad as Fuhjyyu and GSC/Sacon, but they are still to be avoided. They are about on par with OST and CapXon.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              They used 85C caps in a psu
              2x 47uF Teapo SK 85C
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Just measured the Teapo 820uF 200V Primary caps:
                non bulging: esr: 0.05 capacity: 812uF
                bulging: esr: 0.64 capacity: 772uF
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  Can I replace the Teapo primary caps with Capxon? Those caps are really expensive and I thought that the primary caps don't fail often...
                  Going up from 820uF to 1000uF, will it hurt?
                  • mariushm
                    • May 2011
                    • 3799
                    Yes, you can replace them with 1000uF, won't be any problems.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      I have recapped the power supply and it is now working, but.. the plastic holder of the fan is touching the top of the caps.. I managed to close the case and didn't tighten the screws too much... I hope it's ok.
                      Some photos attached
                      • dmill89
                        • Dec 2011
                        • 2534
                        So long as the blades are not obstructed and it spins freely you should be ok. I have a TR2-550w (not currently in a computer, kept as a spare), it has Rubycons on the primary but JunFu (rebranded Fuhjyyu) on the secondary. I'd probably rather have it all Teapo like the one you have since Teapos tend to be more reliable than JunFus, of course 100% Japanese Caps would be even better. What is it with CWT, so many of their PSUs are good designs but are let down by the crap caps they use.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          Here it is, powering again my friend's PC. Thank you for your help
                            I had a similar PSU (I think 480W, I gave it to my friend). It was even worse, because there's a secondary board crammed with an active PFC stage. Almost no space in it for airflow.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              Impossible... My friend called me complaining that his computer would not start. I went there only to find that the psu acted weirdly and when I opened it I had a deja-vu. One of the 2 primary caps bulged again and drained to the point that it measures completely open at the ESR micro meter...
                              This is very strange, primary caps rarely fail, especially without APFC. All I can think is that something in the power supply makes that primary capacitor bulge.
                              Sorry, didn't take pics of it yet.
                                It IS a CapXon. They can fail with no apparent cause...
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  I wish you were right but I think it's the power supply, not the cap.
                                  Same brand, series and uF-V caps are running in Jou Jye power supplies without a problem for years.
                                  • dmill89
                                    • Dec 2011
                                    • 2534
                                    It could be an underlying issue with the psu but those caps are in a bad location between the primary heatsink and PPFC coil. CapXons are not very durable so it wouldn't be unreasonable for them to have failed again after 5mos. especially if it was heavily loaded and/or poorly cooled. High quality japanese caps could posibly solve the issue.
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      I wouldn't use CapXon caps as primaries in a PSU with PFC
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        This psu doesn't have active pfc. As far as I know passive PFC doesn't boost voltage neither stresses the cap.
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • iMic
                                          IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                          by iMic
                                          Hi folks,
                                          I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                          The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                          11-29-2023, 06:44 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • dicky96
                                          Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
                                          by dicky96
                                          Hi guys
                                          I have a faulty Xilence ATX PSU here
                                          The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
                                          There is another smaller transistor on the primary side C3866 which tests ok
                                          The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
                                          There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
                                          05-11-2021, 07:55 AM
                                          ThermalTake Smart M Series M850W – blown primary cap and fuse
                                          by momaka
                                          I recently acquired a ThermalTake Smart M Series M850W (model SP-850AH3CCB) power supply. It has a blown primary cap, blown fuse, and shorted 5VSB MOSFET. Now, if the primary cap was a cheap Chinese or Taiwanese brand, I wouldn’t have been surprised. But the primary cap is a Panasonic HD 400V, 470 uF cap and the rest of the PSU also has quality caps (mostly Chemicon KY and KZE). The PSU barely has any dust in it as well. It looks almost new, actually.
                                          So, has anyone seen this type of failure before? Did the APFC overshoot and cause the 5VSB FET and fuse to blow? Or was...
                                          06-17-2017, 11:56 AM
