Thermaltake TR2-500 Primary cap bad?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Thermaltake TR2-500 Primary cap bad?
    Originally posted by goodpsusearch
    This psu doesn't have active pfc. As far as I know passive PFC doesn't boost voltage neither stresses the cap.
    Ohhh yeah, you're right. Good catch.
      The cap will still be under stress from the AC input ripple. If anything, active PFC is *kinder* as the current is typically sinusoidal, and the actual RMS current is lower than a non-PFC supply. Though in active-PFC designs, the cap is usually smaller, so its ripple current rating is lesser...
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Power up the PSU with good caps and see if the voltage across them is [roughly] the same. If they are not, then that is what caused the cap to bulge.
        You live in greece, so I beileve your power is 220v. That gets rectified and put across the two capacitors in series. If the voltage across them is uneven, one could possibly blow up (worst case would be about 300v across a 200v cap)
        Muh-soggy-knee
        • dmill89
          • Dec 2011
          • 2534
          It doesn't boost voltage but the PFC coil can get rather hot and since this PSU (like most CWTs) has the coil right next to the primary caps this adds additional stress. Of course the primary heatsink on the other side of the caps gets hot when the PSU is loaded and the airflow is somewhat restricted in this area which is somewhat narrow with relatively large objects on both sides that block airflow, the PFC coil being a solid object isn't exactly good for airflow.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            I took out the Capxon primary caps and took more photos of that power supply trying to figure out why the primary capacitor in that specific spot keeps failing.
            There is some burnt glue on that bleeding resistor if I am correct. I don't remember those resistors to get hot.
            I also consider the possibility of the MOV getting hot, but is that possible?
            My last suspect is PPFC placed near the primaries. Do they get hot usually? Is it normal or a sign of failure?
            Meanwhile I had a look at the other parts of that power supply.
            The bridge rectifier is a 10A KBU10J.
            The PWM IC is UC3845B.
            The power supply uses C5353 NPN transistor on 5vsb and 2x W14NK50Z power mosfets rated for 14A continuous at 25°C and 7.6A continuous at 100°C.
            Now let's move to the secondary section:
            -5vsb: 1x 1N582 3A, 2x 1000uF 10V Teapo SC 8x20mm, ripple 1080, esr 0.065
            -3.3V: 1x STPS3045 30A,
            1x 3300uF 10V Teapo SEK general purpose 10x25mm, ripple 950 and 1x2200uF 6.3V Teapo SC 10x20mm, ripple 1220, esr 0.051
            -5V: 2x STPS3045 30A(60A total),
            -12V: 1x STPS3045 30A, 2x 2200uF 16V Teapo SC 10x30mm, ripple 1780, esr 0.032
            - -12V: 1x 470uF 16V Teapo SEK general purpose 8mm
            Teapo SEK datasheet
            Teapo SC datasheet
            The fact that they used GP caps explains the relatively high ripple those Thermaltake psus show when high loaded.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Teapo SEK datasheet
              Teapo SC datasheet
              Put two good caps in there for a moment, and power it on. Take note of the voltage across each primary cap. Occasionally, if there is a problem with the PSU, one cap will have a higher voltage across it that the other, sometimes enough (greater than 200v) to cause it to fail.
              Muh-soggy-knee
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                open bleeder resistor.replace both.
                i see this often in the plate supply in large linears.open bleeder means blown cap.BANG!!!
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #28
                  By the way, I don't know if anyone else noticed the 5vsb critical cap is a Teapo SK 47uF 35V 85°C. Yes, it's true. They chose to put an 85°C capacitor on 2 transistor 5vsb circuit.
                  One would expect that CWT, responsible for the Antec psus killing motherboards back in the 00s, would take a lesson and implement an IC (for example DM311) based 5vsb circuit or at least choose a cap less prone to failure.
                  We are talking about the same psu maker that uses Capxon caps on 5vsb output filter on the Corsair CX power supplies.
                  Shame on you CWT!!!
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #29
                    Bingo!
                    I followed your advice and checked the bleeding resistors.
                    They should be 100kohm according to the color code and that's what I got from one of them. The other resistor, the one connected in parallel to the capacitor that failed, is open.
                    I put 220uF 200V primary caps and plugged it on AC. The cap with the open resistor gets 235V across its legs and the other only 85v. The total rectified voltage is 320V.
                    Thank you very much for the insight! I am going to replace both of them. How many kohm I should put? Should I stick to the original value?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      https://www.badcaps.net/forum/showth...eeder+resistor
                      See post #6. Anywhere between 100 and 200K should be fine, but both should have the same value.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        I would just use the same value (100K). BUT, use a higher wattage one too - hopefully it won't burnout anymore!
                        -Ben
                        Muh-soggy-knee
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #32
                          Thank you!
                          -Ben
                          Higher wattage wont fit there.
                          Btw I removed the resistors and plugged it in again. Every cap now has 161-165V across its legs.
                            (160^2)/100000 = 0.256W
                            That is 1/4W. Using a 1/4W resistor should be fine up to 70°C or so. I'd prefer a 1/2W or 1W for long term reliability though.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #34
                              If I use 200kohm resistors wouldn't that improve efficiency and help the power supply generate less heat?
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Yes it would. But I think the resistors even out the voltage better if they are at a lower value. (more current can flow - but also more heat is dissipated)
                                Is it possible to put larger 100K resistors on the underside of the board?
                                Muh-soggy-knee
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  #36
                                  I have seen 65kohm, 100kohm, 150kohm, 200kohm and 250kohm resistors on psus. I hope they will be ok. I try not to put parts on the underside for safety reasons.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Safety reasons? There usually is plastic under the circuit board to isolate the bottom connections. If it does short to ground, then the fuse should blow. If there is no ground in the wall socket, then it's not your fault.
                                    Muh-soggy-knee
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      #38
                                      I placed 180kohm resistors rated for 1/4watt.
                                      The voltage of each cap is 158V. That gives 0.139 watt, so the new resistors hopefully wont burn up.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #39
                                        I *think* I found your problem...
                                        See the resistors and diodes next to that PFC connector (one of the resistors is labeled R88) in this picture?
                                        Well, does that circuit look familiar?
                                        Hint: *Jou-Jye primary boosting circuit*
                                        I think you have the same problem here. I don't see the boosting caps, though. So maybe it isn't the same circuit. Any chance you can draw it out?
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          I think he removed the boost caps, which disables the boost circuit. I often do this to CWT PSUs. It's not needed and gets too hot. I doubt if the boost circuit would have caused the bleed resistors to fail, though.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • iMic
                                            IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                            by iMic
                                            Hi folks,
                                            I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                            The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                            11-29-2023, 06:44 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • dicky96
                                            Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
                                            by dicky96
                                            Hi guys
                                            I have a faulty Xilence ATX PSU here
                                            The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
                                            There is another smaller transistor on the primary side C3866 which tests ok
                                            The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
                                            There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
                                            05-11-2021, 07:55 AM
                                            ThermalTake Smart M Series M850W – blown primary cap and fuse
                                            by momaka
                                            I recently acquired a ThermalTake Smart M Series M850W (model SP-850AH3CCB) power supply. It has a blown primary cap, blown fuse, and shorted 5VSB MOSFET. Now, if the primary cap was a cheap Chinese or Taiwanese brand, I wouldn’t have been surprised. But the primary cap is a Panasonic HD 400V, 470 uF cap and the rest of the PSU also has quality caps (mostly Chemicon KY and KZE). The PSU barely has any dust in it as well. It looks almost new, actually.
                                            So, has anyone seen this type of failure before? Did the APFC overshoot and cause the 5VSB FET and fuse to blow? Or was...
                                            06-17-2017, 11:56 AM
