Thermaltake TR2-500 Primary cap bad?
    master hoarder
    • May 2008
    • 12175
    #41
    Re: Thermaltake TR2-500 Primary cap bad?
    Originally posted by c_hegge
    I doubt if the boost circuit would have caused the bleed resistors to fail, though.
    Yeah, I doubt it too. I didn't even notice the bit about the failed bleed/balance resistors, though. Yes, if they fail, they may cause the voltage across the caps to shift from one cap to the other, thus possibly over-volting one of the caps slightly.
    Not sure why they failed, either. I've seen high resistance resistors like that fail for no reason before, though.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #42
      That voltage boost circuit is the definition of crap. The caps are going to drain even if they put Rubycon 105°C in there. Too much heat. Why spend money on that circuit (resistors, diodes and capacitors) when it is not going to last more than a couple of months? My theory is that they do this to trick reviews about efficiency.
      Removing the caps was the first thing to do to disable that circuit. The caps were Teapo, completely dead as expected.
      Where were the failed resistors?
      Out of curiosity I checked the bleeding resistors of more than 15 power supplies (fortunately I take pictures of every psu I open) and they all had values ranging from 150kohm to 250kohm. A Konig power supply had 1000kohm resistors! The only exception was the Jou Jye psus, that had 65kohm resistors. But those resistors were clearly of higher watts than the others, 1/2watt probably.
      I assume that the 100kohm 1/4watt bleeding resistors of that Thermaltake were quite on the low side.
      240AC*1.41=339V
      339V/2=170V
      (170^2)/100000 = 0.289W
      0.289W is more than the maximum allowed 0.25W those resistors are rated. The voltage boost circuit might have made things even worse.
      I hope the problem is solved with the 180kohm resistors I put.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #43
        I got the replacement caps I ordered!
        2x1000uF 200V Panasonic UQ
        With the new primary caps installed I get 162.5V across each capacitor.
        I modded the fan controller circuit to make the psu run cooler.
        I put a 9.1kohm resistor in parallel with the thermistor, as you can see in the last picture. The psu has not been tested yet with a PC, so I cannot be sure about its impact on the fan controller.
        I want to thank everyone for your help and support.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Good job as always!
          Cheerz
          Muh-soggy-knee
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #45
            The fan mod failed.
            The 9.1kohm resistor made the fan run full speed after some minutes of normal PC use. I tried 10Kohm but it was pretty much the same.
            Since I don't have bigger resistors laying around and the psu doesn't run very hot I let the fan controller unchanged.
            • c_hegge
              • Sep 2009
              • 5219
              I found a similar thing with the CWT branded version that now power's my brother's PC. I left the can controller unmodified, and it still doesn't run that hot.
              • bauto601
                KDM 480W PSU upgrade succes! (opinions?)
                by bauto601
                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                A "nice" YoungYear unit? - Badcaps
                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                12-26-2023, 03:05 PM
              • iMic
                IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                by iMic
                Hi folks,
                I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                11-29-2023, 06:44 AM
                by momaka
                03-15-2023, 10:17 PM
              • dicky96
                Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
                by dicky96
                Hi guys
                I have a faulty Xilence ATX PSU here
                The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
                There is another smaller transistor on the primary side C3866 which tests ok
                The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
                There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
                05-11-2021, 07:55 AM
                ThermalTake Smart M Series M850W – blown primary cap and fuse
                by momaka
                I recently acquired a ThermalTake Smart M Series M850W (model SP-850AH3CCB) power supply. It has a blown primary cap, blown fuse, and shorted 5VSB MOSFET. Now, if the primary cap was a cheap Chinese or Taiwanese brand, I wouldn’t have been surprised. But the primary cap is a Panasonic HD 400V, 470 uF cap and the rest of the PSU also has quality caps (mostly Chemicon KY and KZE). The PSU barely has any dust in it as well. It looks almost new, actually.
                So, has anyone seen this type of failure before? Did the APFC overshoot and cause the 5VSB FET and fuse to blow? Or was...
                06-17-2017, 11:56 AM
