EnerMax Galaxy 1000Watt DxX
  • Philly Cheese Steak
    • Mar 2011
    • 114
    Hello all!
    I use this one on my stuff so if its not feasible to use it again please do say so!!! EnerMax had warranted it like three times already. I did test the rails before I disassembled it only rail to far out of wake was the red wire 5v rail. It was reading 4.1v, this was only a fan and hard drive on it. If need be I can go back and re test again.........
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    Gskill 16GBRip JAWS@2400
    SSD'S
    Corsair AX1200
    Re: EnerMax Galaxy 1000Watt DxX
    It looks like this PSU uses a DC-DC design to drop the 12V down to 5V and 3.3V.
    It would therefore seem that the 5V DC-DC converter is faulty. Potentially bad caps could be the issue, but I see mostly Rubycons which are very high quality capacitors.
      • Mar 2011
      • 114
      So if no bad caps then toss it? There are a bunch of Caps under the wire harness, I gonna examine them carefully. I think this has been acting up for quit sometime, like since the last time I RMA'D it.
      Thank you for your help Tom66!
      X99 5930K
      X99-gaming 9
      EVGA 1080 Vanilla
      SSD'S
      Corsair AX1200
        If you're about to toss it - give me a PM and I'll buy it off you. Would be a shame to see a nice PSU like that to go to waste.
          • Mar 2011
          • 114
          I didn't post the thread cause I wanted to sell it, I need help fixing it.
          Thanks Tom66!
          Can you point me to the DC-DC converter so I could trouble shoot it and make a decision. Also What to test(the version for dummies) as I can use a meter but usually the big words elude me....................
          Thank you!
          X99 5930K
          X99-gaming 9
          EVGA 1080 Vanilla
          SSD'S
          Corsair AX1200
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Hmm, looks like the secondaries have Y shaped vents, so must not be rubycon. I bet some of them are bad.
            -Ben
            Muh-soggy-knee
              • Mar 2011
              • 114
              -Ben
              Hi Ben,
              Can you help me, PLEASE! Secondary caps you mean? I assume primary would be the power side, secondary being the out side to computer(correct)? So if I post some photo's of them you can tell me what I'm looking for................
              Thank you!
              X99 5930K
              X99-gaming 9
              EVGA 1080 Vanilla
              SSD'S
              Corsair AX1200
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Hi Ben,
                Thank you!
                okokok,
                Well start out taking pics of the secondary (low voltage) side caps, and don't forget to take some shots of the DC-DC converters too.
                -Ben
                Muh-soggy-knee
                  • Mar 2011
                  • 114
                  okokok,
                  -Ben
                  The DC-DC converter is the big round thing in the middle of the PSU? Will post up soon,
                  Again Thank you!
                  X99 5930K
                  X99-gaming 9
                  EVGA 1080 Vanilla
                  SSD'S
                  Corsair AX1200
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Nope, yours doesn't seem to have separate DC-DC converters. Either the parts are bolted to the secondary heatsink or are on the reverse-side of the PCB. A DC-DC board usually looks like this:
                    Your PSU seems to have them as part of the main PCB.
                      • Mar 2011
                      • 114
                      Cool Hegge Thank you!
                      I took some of the CAPS on the secondary side there not RubyCons, the two big black caps are Rubycon's but the rest are these. None looks leaky, I got a couple of them big round things like you posted Hegge. But there covered in rubber shrink wrap stuff, I assume just cut it off? Also noticed a couple of heavy gauge wires on the end of the PSU looking like they were touching the heat sink, there sheathing is torn(circled in red).
                      Thanks guys!
                      X99 5930K
                      X99-gaming 9
                      EVGA 1080 Vanilla
                      SSD'S
                      Corsair AX1200
                      • c_hegge
                        • Sep 2009
                        • 5219
                        and I thought you had Chemi-con capacitors (That's what they look like from on top)
                        I think you can leave the primary side alone. The problem is almost definately with the secondary side. Can you get a good, clear picture of the solder side of the PCB?
                        I doubt that the damage to the wire is responsible. It's on the 12V. You can put some tape around it if you care to.
                          • Mar 2011
                          • 114
                          I'm not sure why but been having a hard time with good picture's up close, but I can use a magnifying lens. I'll post back,
                          Thank you!
                          Update: see if these will work, that one cap says "CE TUL" on it then the next big one over to the right is mark "VENT" and the back side secondary side.
                          X99 5930K
                          X99-gaming 9
                          EVGA 1080 Vanilla
                          SSD'S
                          Corsair AX1200
                          • c_hegge
                            • Sep 2009
                            • 5219
                            OK. Unlike tom66 said, this PSU doesn't use DC-DC conversion, so there is no DC-DC converter to speak of. That means that the problem could be with the transformer (perhaps a partially shorted winding). If so, you'll have to either re-wind or replace the transformer.
                              Are there three transformers on the PCB, I can see two large one but on the right side of the middle transformer it looks like a small transformer for the 5V standby?
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                We call those caps Pce-Turd for a reason!
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  I doubt it. Big transformers like these never go bad (or at least not before the schottky rectifiers and the switching transistors on the primary blow up).
                                  One thing that caught my attention in post #1 is that this PSU was tested with only a hard drive and a fan. For a 1 KW PSU, that's a very very light load, so it is possible that it just needs a bigger load.
                                  @ Philly Cheese Steak: If you have a spare Pentium 4 computer (or something equivalent - i.e. a motherboard with a 4-pin CPU connector), use that to test the PSU. If the 5V rail is still bad, all I can think of is this:
                                  1) In the past, Enermax used to use a tan glue to hold down components on the PSU board during manufacturing. As this glue ages, though, it turns brown and becomes conductive, thus making it possible for short circuits to appear inside the PSU. I can already see there is some of this glue used in your PSU.
                                  2) If #1 doesn't apply above, then perhaps those PCE-TUR/TUL caps are starting to go bad and thus causing the regulation of the PSU to go amok.
                                  But again, I think you should test the PSU first with a much heavier load - possibly something that pulls more power from the 12V rail than from the 5V rail since this is a modern PSU.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Yes they do. It's not common, but I've known it to happen before (although it made the voltage on the 12V jump to something like 25V). The PSU was OK with a new transformer and new caps.
                                    I forgot about the conductive glue issue. That's probably a more likely scenario.
                                      • Mar 2011
                                      • 114
                                      Hello Mom AKA!
                                      I had been using it to bench with, so far I've lost three cpu's to it. I can pick up an $5 pentium of flee bay to test with? You see that is my real issue as the PSU is sporadic some time's it works fine, other time's its like I'm not getting enough voltage from the wall. I don't wanna lose any more hardware to it but a $5 cpu I don't mind..........
                                      I can't test the caps in the board, thinking of replacing the secondary side caps. The only other caps are the huge one's on the other side of the PSU an pretty sure those are the least likely to go plus the most expensive too.
                                      Thank you All for your input!
                                      Keep the ideas coming!
                                      X99 5930K
                                      X99-gaming 9
                                      EVGA 1080 Vanilla
                                      SSD'S
                                      Corsair AX1200
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        haha, I thought exactly the same, and I didn't know PCE-TUR now uses Y shaped vents! The way the shrink wrap is on them, they look similar to Fuhjyyus actually!
                                        Cheese Steak, I think you should start out by replacing those PCE-TUR capacitors.
                                        Also like momaka said, try using a larger load for testing the power supply.
                                        Low-voltage (i.e. 12v) halogen lamps are good for loading down the outputs.
                                        -Ben
                                        Muh-soggy-knee
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                          Samsung Galaxy Book2 Pro Galaxy Book2 Pro Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book2 Pro Galaxy Book2 Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book2 Pro boardview and Galaxy Book2 Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
                                          Samsung Galaxy Book2 Pro 360 GALAXY BOOK2 PRO 360 15.6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book2 Pro 360 GALAXY BOOK2 PRO 360 15.6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GALAXY BOOK2 PRO 360 15.6 boardview and GALAXY BOOK2 PRO 360 15.6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          Samsung Galaxy Book2 Pro 360 Galaxy Book2 Pro 360 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book2 Pro 360 Galaxy Book2 Pro 360 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book2 Pro 360 boardview and Galaxy Book2 Pro 360 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
