voltage rails from speedfan
  • hkivan
    • Mar 2006
    • 122
    Hi guys,
    I checked the 3 rails from my PSU by a DMM.
    They were OK. I ran 3Dmark 05 & saw the values
    from the chart of speedfan.
    The voltages varied between :
    Vcore : 1.62 to 1.57
    +3.3v : 3.26 to 3.21
    +5v : 4.92 to 4.89
    +12v : 11.5 to 11.37 .
    The voltage fluctuations are 50mv, 50mv, 30mv and 130mv
    respectively.
    The 12v rail was at 12.4V from a DMM reading while it
    shown by speedfan was 11.4v .
    I know software readings are not accurate
    but can you guys tell me if the voltage chart of speedfan
    can be trusted ?
    From some PSU sites, I saw they quote their PSUs
    have ripple & noise on different rails, e.g.,
    50mv ripple on 3.3v & 5v and 120mv
    on 12v , 100mv noise on 3.3v & 5v and 200mv on 12v.
    In my case, what are the ripple voltages and noise on
    different rails?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: voltage rails from speedfan
    can be trusted ?
    nope trust in dmm readings under load. a clamp meter is useful.
    • hkivan
      • Mar 2006
      • 122
      Willawake, You mean the fluctuations shown on
      speedfan were not reliable?
      I just want to see the ripple & noise of the rails under load.
      I wish I could have a CRO to see them clearly!
      Can u show me a picture of the clamp meter you mentioned?
      • tiresias
        • Feb 2006
        • 489
        Heh... this is where I'm allowed to step in and brag about my Fluke 337
        It's just perfect for measuring current draw on your various rails - or the AC input for that matter. For assessing ripple or noise, of course, you will need an oscilloscope.
        As for speedfan - it's a very useful piece of software, particularly for PWM/fan regulation, but any voltage measurements are going to be entirely dependent on your motherboard's sensors - which are rarely reliable enough to give anything more than a very rough indication of input voltage.
        • Spacedye69
          • Nov 2005
          • 698
          • US
          Speedfan is WAY off one one of my ASUS boards, but close on others, so even same mfrs can not be accurate.
          • Instafixx
            Macbook A2179 820-01958
            by Instafixx
            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
            I checked the Power Sequences below and found this -
            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
            05-20-2023, 05:19 AM
          • harp
            Low voltage very high current rails distribution
            by harp
            Low voltage very high current rail distribution
            I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
            Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
            output on half E-F
            output on C-B
            connect A-B and C-D, output on A-F
            otherwise?...
            10-27-2023, 02:45 PM
          • rddube
            Lenovo L490 Ram voltage circuit malfunction
            by rddube
            Hello friends,
            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
            07-15-2025, 04:41 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
