"POWER PC" ML915 350W power supply
  • mockingbird
    • Dec 2008
    • 5484
    #61
    Re: "POWER PC" ML915 350W power supply
    How does bloating affect primaries? Can you measure a lack of uF flowing through it? I ask because I ordered a brand-new primary cap from a well-known "good-brand" cap manufacturer that came bloated.
    I emailed them, but any effort on my behalf to get them to admit to their lack of QC was met with their disclaim.
    So you're saying the KDC primaries fail in droves
    I can confirm seeing a KDC primary with its guts spewing out the bottom.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Originally posted by Shocker
      Scenic: I would use bigger than 680uF for a 550W PSU - probably 1000uF or 1200uF.
      Tell that to Antec, not me :p
      Then again, it's an active PFC PSU (even though it's botch-jobbed with a piggyback PCB.. Antec style), so it probably doesn't need THAT much bulk capacitance on the primary (?)
      2x 680uF in series = 340uF compared to your 500-600uF suggestion. And this is an old unit too (not much beef on 12V yet)
      • Shocker
        Banned
        • Dec 2011
        • 635
        #63
        Originally posted by Scenic
        Why did they make a no-PFC design so recently??? Tacking on the PFC is just...wrong. Although, with their use of those Fuhjyyu craps, this is merely adding insult to fatality.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          "recently" is a bit of an overstatement..
          Searching for that PSU on google, the first result is a post on tomshardware from may 2004 lol
          It's just a Truepower .. not Truepower New or Truepower 2.0, so it's pretty damn ancient.
          • Shocker
            Banned
            • Dec 2011
            • 635
            #65
            I know. I was using the word "recent" in a relative sense.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #66
              I did.. in an Antec of couse
              out of a Truepower 550 EPS
              http://bambooz.pytalhost.net/badcaps...0/fuhkyoo2.jpg
              http://bambooz.pytalhost.net/badcaps...0/fuhkyoo3.jpg
              one was noticeably lighter than the other and the innards were flopping around loosely..
              Me too. None can blow Fuhjyyu better than Antec.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                #67
                Antec still makes PSUs with Teapo and Capxon.
                A working TV? How boring!
                • Newbie2
                  • Sep 2005
                  • 885
                  Originally posted by c_hegge
                  When I see them after only 3 years or so, they are VERY bloated, looking like they are about to explode. In one case, not only was there a major bulge from the top, but the rubber seal was so bulged out that it had pushed the cap off the PCB.
                  I might make the $20 investment into buying two new primary caps on my next paycheck if the KDC caps are THAT bad. If I do that, I might also spend a couple dollars more and get three each of 47uf, 10uf, and 4.7uf 50V Panasonic FC caps to make this PSU have purely all Japanese capacitors, like my Delta Power 450W.
                  I've seen Ltec in an Antec Basiq BP430 430W PSU, however I think Antec's pretty bright these days to have all Japanese capacitors in their High Current Gamer and High Current Pro lines of power supplies.
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #69
                    Yes, but not in entry level. http://www.hardwaresecrets.com/artic...ly-Review/1487
                    • Newbie2
                      • Sep 2005
                      • 885
                      I did not mention Antec's other product lines having good caps, just their higher end HCG and HCP lines. I do know that Antec still has Taiwanese caps in their other power supplies.
                      My gaming PC:
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #71
                        $20!? No way. Don't pay more than $5~ a piece.
                        Yes... I just came across several HCG-400 PSUs. I shined my flashlight in one of them and saw Rubycons on the secondary (One other I checked had UCC)!!!
                        • Newbie2
                          • Sep 2005
                          • 885
                          By unit price alone the primary caps I want are just under $5 a piece, however with the $8 CAD flat rate shipping that Digikey.ca charges for orders under $200, and the high sales tax of the Canadian province I live in (15%) the total comes to just over $19 if I were to order two new primary caps.
                          My dream came true...
                          My gaming PC:
                          • Shocker
                            Banned
                            • Dec 2011
                            • 635
                            #73
                            It's probably worth the price paid, considering how appallingly unreliable those KDCs are.
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              To be honest, I'm not too worried about Teapos in PSUs as long as they're at least halfway decently ventilated, but CapXon? No way..
                              Every single flaky or dead FSP based PSU I come across has bad Capxon KM/KF all over the place
                              The batch of dead be-quiet! E5 series PSUs I got recently all had a single non-bulging Teapo surrounded by Capxons puking their guts out lol
                              edit: the be-quiet! E5 series as well as many other BQ's are FSP OEM, but custom made (not quite like any regular FSP series)
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #75
                                Buy new old stock ones. You can get them shipped free from China.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  All the FSPs around here get bulging teapo and good capxon
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #77
                                    I can confirm that in psus that used both Teapo and Fuhjyuu caps the Teapos survived.
                                    Same with psus that use Teapo and Capxon...
                                    JunFu caps used in identical psus with ones that used Capxon KM/KF didn't bulge, while the Capxons always did...
                                    • Shocker
                                      Banned
                                      • Dec 2011
                                      • 635
                                      #78
                                      CapXon KM is General Purpose, so it's zero surprise that they failed.
                                      If you're talking about the 2200uF 6.3V 8mm KFs, maybe it's just that those caps are especially bad. For replacing them:
                                      • Nichicon HM or Panasonic FJ are overkill, but have a 2200uF 6.3V 8x20mm.
                                      • Or you can attempt to squeeze in a typical 2200uF 6.3V 10mm (not easy).
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        #79
                                        I forgot to mention that the psu maker used either Capxon KM or JunFu WG (10mm 3300uF 16V for 12V and 10V for 3.3 and 5V). Just out of curiosity, is Junfu WG a lower esr series compared to Capxon KM?
                                        • Shocker
                                          Banned
                                          • Dec 2011
                                          • 635
                                          #80
                                          Yes it is. Jun Fu WG is a low ESR series with identical specifications to Fuhjyyu TM . CapXon KM is general purpose as mentioned above.
