"POWER PC" ML915 350W power supply
  • Newbie2
    • Sep 2005
    • 885
    I just recently got my hands on a brand new generic "POWER PC" ML915 350W power supply, which cost $20 CAD at a small local computer shop.
    I could not positively identify the manufacturer of this PSU as there was no UL number to look up, and all the markings on the PCB (which were "HY", "HY0011", "ML915", and "ML 908B") turned up nothing informative to this PSU on Google. This PSU does sort of look similar to my Delta Power 450W PSU that I have in an older thread: https://www.badcaps.net/forum/showthread.php?t=7708
    Here are its specifications on the sticker:
    +5V = 20A
    +12V = 14A
    -5V = 0.5A
    -12V = 0.5A
    +3.3V = 16A
    5VSB = 2.0A
    Total = 350W (more modest than the typical 400W+ claims of other generic PSUs)
    Here are some pictures of this PSU:
    Three shots of the power supply.
    Not many connectors coming from this power supply; there's just the 20+4 pin ATX motherboard connector, 4-pin P4 12V connector, four 4-pin peripheral power connectors, and just one SATA power connector (missing the 3.3V wire found on most better power supplies).
    The label of this power supply.
    Two overhead shots of the internals of this power supply.
    The two "KDC" 560uf 200V primary caps in this power supply.
    What consists of the transient filtering stage (nothing really), as well as the four diode treatment consisting of 1N5408 3A diodes.
    The primary side silicon, consisting of a C5027 3A NPN transistor and two Fairchild-branded 13009 fast-switching NPN transistors, all in the familar TO-220 package size.
    The three transformers in this power supply.
    Another shot of part of the primary side of this power supply.
    The secondary side capacitors; they are all "BH" brand, and the four blue 10mm caps are rated at 1000uf 10V while the two brown ones of the same size between them are 1000uf 16V.
    The secondary side silicon, consisting of one MOSPEC F16C20C 16A power rectifier and two MOSPEC S20C45C 20A Schottky rectifiers, all in the TO-220 package size.
    The "CG8010DX16" PWM chip in this power supply on the secondary side.
    The single 80mm exhaust fan in this power supply is a "Legend" DF0802512SEMN, which I could not find any information on.
    A view of the 80mm exhaust fan of this power supply.
    Two pictures of the PCB underside of this power supply.
    Regarding what might be the true wattage of this power supply, the 3A 1N5408 diodes on the primary side would mean that this power supply would only be able to pull in a maximum of 360W on a 120V AC line, which would actually be 252W assuming 70% efficiency (typical of cheaper PSUs). The silkscreen on the PCB states "F5AL/250VAC 230W" on it (visible in one of my pictures), and the fuse used in this power supply is indeed a 5A 250VAC fuse. Both these factors I found could indicate that a more honest rating of this PSU from the manufacturer would be around 230W, which seems reasonable considering the maximum amount of power this PSU could pull in from a 120V AC outlet judging from the diodes.
    I do not plan on rebuilding or upgrading this PSU, as the cost for capacitors and other parts would be equal to that of a decently made higher-quality power supply. I purchased this PSU to put into my basic Athlon 64 X2 3800+ build if I ever sell it or give it away, as I have my rebuilt Delta Power 450W currently powering that and I want to keep that rebuilt PSU. I have not yet plugged in and turned on this "POWER PC" PSU, and do not plan to in the near future as I currently have no need for it.
    Any comments on this "POWER PC" 350W PSU?
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
  • c_hegge
    • Sep 2009
    • 5221
    Re: "POWER PC" ML915 350W power supply
    I had an identical-looking Sky 550W-P4. The Switching transistors exploded when I asked for 280W load
    https://www.badcaps.net/forum/showpo...&postcount=110
    • Newbie2
      • Sep 2005
      • 885
      Interesting, other than the primary capacitors on my PSU being "KDC" 560uf vs. yours with BH 470uf, and my generic fan being branded "Legend" instead of your "HongGu" everything else is the exact same. I like how the basic label style is the same (funny how your Sky 550W claims to have two +12V rails).
      Now I wonder which manufacturer is behind these cheap power supplies...
      My gaming PC:
      • c_hegge
        • Sep 2009
        • 5221
        HongKongFlyApart company, LLC
        • Newbie2
          • Sep 2005
          • 885
          c_hegge would you happen to have any pictures of your Sky 550W PSU after you made it explode?
          My gaming PC:
          • PeteS in CA
            • Aug 2005
            • 3589
            • USA, Unsure of Planet
            • Reading, Education, History, Christianity
            With those wimpy heatsinks, I/P and O/P rectifiers, I wouldn't use it higher than 200 watts, if that. It's a half bridge design (the two 13009s - originally Motorola's MJE13009, specifically designed for switching P/Ss), the smallest transformer is probably the base drive (maybe proportional drive, which can be self-oscillatory at power-off if not done right). The 2SC5027 is probably for the Stby O/P, probably a self-oscillating discontinuous flyback (aka "ring choke"), the medium-sized transformer being for that O/P.
            PeteS in CA
            • c_hegge
              • Sep 2009
              • 5221
              https://www.badcaps.net/forum/showpo...&postcount=113
                master hoarder
                • May 2008
                • 12185
                • Fixing stuff
                If you add the input filters and bigger output caps, I think this might be a better unit than your Delta Power.
                • Evil Lurker
                  Warranty Voider
                  • Feb 2011
                  • 454
                  Not too bad really. I mean yeah it is an ancient voltage mode controlled piece of shit but it can be significantly improved. First off he 13009 switchers are at least in a TO-220 package, that should help with maximum wattage. And the board appears to have been drilled and silkscreened for an actual bridge rectifier. I'd prolly upgrade the rectifier diodes (not a big fan of mospec) to something from ST and add on some sort of input filtering and replace the primary caps with something a tad bigger.. Just go to a PC shop and get a few old junk PSUs for parts.
                  • Newbie2
                    • Sep 2005
                    • 885
                    I am now planning a slight rebuild of this PSU, but nothing too drastic like my Delta Power 450W. I am thinking of adding in the transient filtering stage components (two more Y caps, an X cap, and a coil), replacing the BH capacitors with better capacitors in for the secondary side, replacing the MOSPEC F16C20C 16A rectifier on the +12V rail with a new STTH2002CT (a small improvement) that I have leftover from a previous PSU rebuild, and replacing the 80mm exhaust fan with something better that I have in my collection of fans.
                    All the parts to be used will be either from what I already have laying around or salvaged from two dead PSUs I own, which are an Enermax EG301P-VE 300W and the infamous Bestec ATX-250-12E 250W (before you ask, yes it had a 5VSB meltdown). I will not invest any more of my hard-earned money into this cheap $20 power supply.
                    Does this sound good?
                    My gaming PC:
                    • c_hegge
                      • Sep 2009
                      • 5221
                      If you're just using parts you have laying around, then I'd say go for it. That's what I did (other than a rectifier and the caps) when I re-built my Rexpower PL-400
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • electronics and DJing/producing music
                        Hardware Secrets has been pushing this myth for years, even though they never had the primary diodes die in any of those cheapies. Neither have i. Not even the wimpy 2A ones. 95% of the time the primary switching transistors blow up due to overheating and then take out the fuse, then there's the occasional failed secondary diode when the power supply shuts down gracefully.
                        The reality is that 3A is the typical rating of this type diode in its typical operating position, ie sitting flush to the board and with natural convection cooling. In this case they sit upright and are in the fan's path. They will do almost double their rating without failing.
                        A working TV? How boring!
                        • Newbie2
                          • Sep 2005
                          • 885
                          If this is the case, then I have a reason not to replace those four 3A diodes with a new GBU6J 6A bridge rectifier that I have. I don't want to waste a good new component if the 3A diodes are adequate for that $20 PSU, since it probably won't take advantage of the higher rating of the GBU6J. My father, an electronic engineer, does agree with what Hardware Secrets says about that.
                          I might pull a proper bridge rectifier from one of the dead PSUs that I have.
                          My gaming PC:
                          • c_hegge
                            • Sep 2009
                            • 5221
                            If you have a better rectifier you can scavenge from a dead PSU, then by all means use it, but if not, don't sweat too much over it.
                            • Newbie2
                              • Sep 2005
                              • 885
                              Agreed.
                              I have a question for you guys here, how come these generic manufacturers like to solder the L and N wires from the power plug (that also happened on my Delta Power 450W), and in this power supply even the thermistor into the vacant spot where the coil for the transient filtering stage belongs. There are proper locations for those two wires and thermistor on the PCB and marked on the silkscreen, so why do they solder those two things into a different location?
                              My gaming PC:
                              • c_hegge
                                • Sep 2009
                                • 5221
                                It saves 1c
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  It saves 1c
                                  How does solder location save them money?
                                    master hoarder
                                    • May 2008
                                    • 12185
                                    • Fixing stuff
                                    If they install the wires at their proper locations, then they would have to install additional jumpers where the coil is and maybe a few other places. This takes time and money (even if it's not much, it adds up when you make 1000 of these PSUs).
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      If you're really rigurous then yes, the 3A diodes can be considered inadequate for the job. However, the reality is that they do just fine. I've tested some of them with a current source and they perform exactly like i said they do - almost double the rating.
                                      Same goes for the "diodes-on-a-bracket" on 12v. They are 3A each so in theory the 12v rail would only do 6A, but they do 10A for years. What going with oversized rectifiers does improve is efficiency (lower voltage drop), but if you got the heatsink to cool them the marginal rectifiers they put in will work just fine. I do however recommend replacing them with better ones, as higher efficiency also means the primary transistors are stressed less and you get higher maximum power. 400W is possible from a pair of TO-220 13009s if you can get efficiency above 80%.
                                      • Newbie2
                                        • Sep 2005
                                        • 885
                                        I've just rebuilt the PSU, however when jump-starting it with no load the +12V rail is too high at 13.50V, along with the +5V rail at 5.73V. The 3.3V rail is fine at 3.35V. I unfortunately forgot to get pre-rebuild voltage values, so I cannot compare these no-load voltages to what the power supply would've originally had.
                                        I know that switching power supplies should not be run without a load and may not function properly without a load, so I want to ask would the voltages go down to within ATX specification (maximum 12.60V for +12V and 5.25V for +5V) if it were properly loaded?
                                        My gaming PC:
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          03-31-2024, 02:12 PM
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • Amardillo
                                          Lecroy Power Supply PS1724 What is this Component?
                                          by Amardillo
                                          Lecroy power supply - this power supply is prone to failures. I have repaired mine a couple of times before. The problems with this power supply range from shorted out power mosfet, the green module pwm driver, aging EMI filter, shorted snubber etc.
                                          I once dismantled a custom component that I cannot identify, no way of knowing if it was the cause, and thus I have no way of checking it. However the power supply can still power up and supply properly without this component.
                                          This Component is not shown in the Schematic but apparently it is side piggy back mounted on the EMI filter as...
                                          12-22-2025, 01:15 PM
