"POWER PC" ML915 350W power supply
Re: "POWER PC" ML915 350W power supply
Those "PCE-TUR" caps (the actual company is CEC) are not a good brand. I'd save up for good caps. It's not the same Enermax you recapped, is it??? If so, try new primary caps and see if they fix the problem.I do have two old PCE-TUR 680uf 200V caps in a dead Enermax EG301P-VE PSU that I have, however I'm afraid that I might damage the solder pads on the POWER PC PSU PCB if I try to enlarge them for radial snap-in caps. I don't know if the PCE-TUR caps would be too good, with that dead Enermax being almost a decade old plus the PCE-TUR brand.
Yes, I understood the risk of damaging the solder pads. But it's your choice: waste $$$ on the aforementioned Chemi-cons or take the risk.Comment
This was the Enermax that I had recapped the secondary side in the past. I recapped that PSU because the issue was able to power on but it somehow could no longer reliably power a P4 3.2GHz Prescott PC that I had, since that PC kept freezing when a game (like Call of Duty 4) or anything intensive was run on it. Unfortunately replacing all the secondary side caps did not fix that issue, and I soon took it out of service. It was replaced by my (then newly) rebuilt Delta Power 450W, which solved all the issues with the PC, and the Delta Power 450W reliably powered that PC until I gave the PC's parts to my relatives (I kept my PSU).
I used the Enermax for scrap parts, and it was where I got the two Y caps for this POWER PC PSU. I also took the 2700uf 16V Panasonic FM caps I used out of the Enermax for this cheap PSU as well, since I had none leftover and those caps weren't used for very long.
I will not try to fix that old Enermax, as it is ancient and only has a 20-pin ATX connector. All the PCs in my house right now need the 20+4-pin ATX connector for their 24-pin motherboards, so this Enermax is of no use to me if it worked.
Well if I took the risk and the solder pads came out damaged, I would lose a $23 CAD PSU plus the work I put into it to upgrade its internal components. Wasting almost $20 CAD on new primary caps seems like the better option if I had to pick either one.Last edited by Newbie2; 02-13-2012, 02:46 PM.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bitComment
It would be interesting to find out the problem with the Enermax. But, still, if you're dead set on the PSU in the thread, I don't care.This was the Enermax that I had recapped the secondary side in the past. I recapped that PSU because the issue was able to power on but it somehow could no longer reliably power a P4 3.2GHz Prescott PC that I had, since that PC kept freezing when a game (like Call of Duty 4) or anything intensive was run on it. Unfortunately replacing all the secondary side caps did not fix that issue, and I soon took it out of service. It was replaced by my (then newly) rebuilt Delta Power 450W, which solved all the issues with the PC, and the Delta Power 450W reliably powered that PC until I gave the PC's parts to my relatives (I kept my PSU).
They are only 85°C caps, mind you. Chemi-con also has a PAG series which is 105°C and includes a 560uF 200V 18mm. It also has a higher ripple rating and lower dissipation factor, so if you can get it at a reasonable price, go for it. If the PCB doesn't have 7.5mm hole spacing, you can always bend the capacitor leads outwards and mount them a few mm off the board.Well if I took the risk and the solder pads came out damaged, I would lose a $23 CAD PSU plus the work I put into it to upgrade its internal components. Wasting almost $20 CAD on new primary caps seems like the better option if I had to pick either one.Comment
It's hard to see how you could damage the pads for the primary caps since you have successfully replaced the 12v secondary rectifier which is in TO-220 and far more difficult to solder than those big primary caps.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
He means damaging them by drilling them out to fit snap-in caps. It's very hard to damage those when soldering.Comment
It's very hard to damage them with drilling as well. Drill from the side with the traces and everything will be fine.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Th3_uN1Qu3 is right. I have done it with a Linkworld. I used a screwdriver to widen the holes.Comment
I see. Still, even though snap-ins rated at 560uf 200V are slightly cheaper than the regular Chemicons on Digikey.ca, for me after shipping and taxes it'll still cost around $16-$17. If I had the money to waste, I'd rather spend the extra $2 and get the Chemicons with regular leads so I don't have to touch the PCB.
I'm not going to use my old dead Enermax's PCE-TUR caps. They're pretty old so I doubt they're in good shape.Last edited by Newbie2; 02-13-2012, 04:00 PM.My gaming PC:
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Yes I'm sure for mine; when I was rebuilding it I was reflowing some of the solder joints on it and did the primary caps, and their leads didn't feel like the ones that snap-in caps have (felt like regular leads).
If you look at the PCB underside photos I posted on the first page of this thread, at the primary cap section you can see a hole that the solder did not cover and it is of normal lead size, not snap-in.My gaming PC:
The open holes are for caps with 7.5mm lead spacing. All snap-in caps have 10mm spacing. Remove the original primary caps and look at the top of the board.Yes I'm sure for mine; when I was rebuilding it I was reflowing some of the solder joints on it and did the primary caps, and their leads didn't feel like the ones that snap-in caps have (felt like regular leads).
If you look at the PCB underside photos I posted on the first page of this thread, at the primary cap section you can see a hole that the solder did not cover and it is of normal lead size, not snap-in.Comment
I guess I'll go against the flow and say just leave the big caps on the primary side alone (at least for now). This PSU doesn't have an APFC circuit, so it doesn't really stress them that much at all. I have 10+ -year old L&C PSU with CapXon KMs on the primary - still works fine. Those large caps just don't fail that often (APFC circuits aside, of course). If the voltages are stable when the PSU is under high load, just leave them.Last edited by momaka; 02-13-2012, 10:20 PM.Comment
KDC are even worse on the primary side than Fuhjyyu. Every single time I see them, they are bloated, even on PSUs without APFC.I love putting bad caps and flat batteries in fire and watching them explode!!
Mind you, I haven't yet seen a bloated Fuhjyyu primary cap in person. So I guess KDC are as bad as SWCON.Comment
Or maybe even worse.
When I see them after only 3 years or so, they are VERY bloated, looking like they are about to explode. In one case, not only was there a major bulge from the top, but the rubber seal was so bulged out that it had pushed the cap off the PCB.I love putting bad caps and flat batteries in fire and watching them explode!!
I did.. in an Antec of couse
out of a Truepower 550 EPS
http://bambooz.pytalhost.net/badcaps...0/fuhkyoo2.jpg
http://bambooz.pytalhost.net/badcaps...0/fuhkyoo3.jpg
one was noticeably lighter than the other and the innards were flopping around loosely..
Scenic: I would use bigger than 680uF for a 550W PSU - probably 1000uF or 1200uF.
c_hegge: So you're saying the KDC primaries fail in droves??? All the Fuhjyyu primaries I have look fine and are at least five years old, so that's super appalling.
KDC
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
