Re: IMAC 24 PSU Bad Caps replacement
The mosfet is the original one, the pulse driver are right also. (I will have to check with osciloscope, and post the value)
I feed the optocoupler with some aditional voltage, from one of the windings, to make sure that no overvoltage is generated by the psu. (an is the only way I have found to keep the controler IC sending pulses to the mosfet)
I have in mind some other test, I will post.
Regards.
Regards.
