Enermax Liberty ELT500AWT fails to turn on
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    #41
    Re: Enermax Liberty ELT500AWT fails to turn on
    Originally posted by ChaosLegionnaire
    yea just to clarify, i also have this unit and afaik, the liberty dxx series seem to use some kind of a relay for the automatic ac voltage detection or sumthing. so when powered on, the unit will make a clack, crack or tick sound when powering up. this is normal. the superflower leadex series also uses a relay and makes a similar sound when powering up.
    Many PSUs used in desktops use a switch to set it up for 115VAC or 240VAC. This switch can be replace with a (safety agency rated) relay, driven by a circuit that senses the input voltage and sets the relay accordingly. A nice feature, especially in 240VAC countries where forgetting to set the switch to 240VAC results in a loud noise and a dead PSU.
    Another use of a relay that I've seen is to short out the inrush limiting thermistors after the PSU has been on for a few 10s or 100s of milliseconds. This allows use of higher cold resistance thermistors that are not hugenormous.
    PeteS in CA
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      #42
      you are hearing a soft start relay.
      i have an antec 750 with one.
      i add them to big hf amps to prevent killing the now unobtainium power switches from inrush.
      even more important now that much larger,lower esr caps were used in the plate supply rebuilds.
      i use an icl rather than a resistor.the relay bypasses it ensuring if the power flicks for whatever reason it will be ready again.
      • vwtcxqdh
        • Dec 2017
        • 14
        • internet
        #43
        Have someone find out what capacitor makes is the typical one that makes this does-not-power-on problems? I understand that i makes sense to replace all caps after that many years but because the PSU works fine when it turns on once, it would make more sense to me to just replace this one or two caps that make those power-on problems.
        Seems like the whole fist enermax liberty series have exactly this one power-on problem after time.
        • pdavid
          • Jan 2011
          • 279
          • Hungary
          #44
          Originally posted by Mad Professor
          Good day all.
          This week while using my workshop computer, I had a BSOD and the computer restarted, it got into windows and the computer locked up, So I then pressed and held in the power button.
          Since then I have not been able to get this PSU to turn back on again.
          When the mains power is on, I get the 5volt standby fine, but you press the power button you hear a click, and then a high pitch wissle/buzzing.
          The power supply in question is a Enermax Liberty ELT500AWT.
          I have removed the lid/cover, and I can not see any burnt/damged parts.
          I have read that some early Enermax psu's had glue that would short out, but this psu does not look like it has any of this glue near the high voltage parts.
          I haved tried this power supply in a computer, and on the test bench, but it still fails to switch on.
          When I get some free time I am going to strip this psu down more, and go hunting for the problem.
          I have now ordered a new psu to replace this one with, but I would like to try and find out what had failed in this psu.
          Can anyone please give me some pointers on where to look?
          Best Regards.
          I had two of these units with the symptom you described! Turned out to be a shorted npn smd transistor on the secondary. I don't remember it's location... but it had 6F marking on it. I hope this helps.
          • Behemot
            • 4845
            • CZ
            #45
            Yeah but it could be random SMD diode, transistor, capacitor - can you test all of them?
            • LeKowalsky
              Enermax Platimax EPM1500EGT random turn on
              by LeKowalsky
              I'm novice in smps repairs and lurker here also in addition to my preparation I have read Jestine Yong's Troubleshooting & Repairing Switch Mode Power Supplies many times and I cautiously proceeded in small steps a time.
              What's on the table?
              Enermax Platimax 1500W (EPM1500EGT)
              Symptom
              A fault is a little tricky here. When plugged into the wall for a first time (i.e. after proper discharge) PSU starts on power button (PS_ON) as expected, runs smoothly with all the voltages in tolerance also shows quite stable operation...
              04-14-2020, 08:05 AM
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
              Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
              by momaka
              Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
              First shown is the label below, so anyone reading can see what PSU we're dealing with here.
              02-15-2021, 01:05 AM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
            • robante15
              Acer Aspire 4520 won't turn on after reboot
              by robante15
              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
              If I remove the...
              04-06-2024, 06:50 PM
