neutral vs ground
  • xformer
    • Jun 2011
    • 16
    neutral vs ground
    what is the difference of neutral and ground?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: neutral vs ground
    Ground is there in case neutral fails, so you don't get electrocuted by the appliance you are using. For all intents and purposes they (should) have equal potential so the ground lead could as well be connected to neutral, but in case that fails then the case of the equipment would be at line potential. Also the EU for example doesn't use polarized plugs - so if case ground were tied to line neutral you could well end up with a live case if you plugged it in the other way round.
    Ground and neutral are actually tied together at the distribution panel of the building. The reason why they come thru separate wires in your house i have explained above. http://www.electro-tech-online.com/g...vs-ground.html
    A working TV? How boring!
    • Hondaman
      • Sep 2008
      • 1087
      Electricity comes from the "hot" side of the outlet, goes through the load and then goes back to the "neutral" side of the outlet (and back to the fuse box).
      What if the thing you are using is metal and has a problem -- and it only has a 2-prong plug? You could get a shock, because the electricity will go through you to get back to the outlet (or the fuse box).
      If the electrical item has a 3-prong plug and breaks, electricity will go through the third wire with nearly zero ohms of resistance to get back to the fuse box.
      Electricity takes the easiest path, so it prefers the third ("ground") wire to going through your body, because you have more resistance.
      If you are outdoors, the path THROUGH YOU back to the fuse box can be easier if you are standing in a puddle or something. So outdoors you really must use a 3-wire plug. That third wire always offers a path back to the fuse box that has practically NO resistance, so electricity will choose that path.
      And keep in mind -- in the US, 220-240 volts AC have two wires, but BOTH act as "hot", so safety is even more important. This is probably true in other countries but I do not know.
        No, neutral and ground are NOT interchangeable. Neutral wire carries current. Wire has resistance. So neutral is at a potential, sometimes 10's of volts, relative to ground. At the substation or pole, neutral and ground are connected. If you interchange neutral and ground, you will most likely trip the RCD/GFCI.
        • Hondaman
          • Sep 2008
          • 1087
          Let me change one paragraph to read as follows:
          What if the thing you are using is metal and has a problem -- and it only has a 2-prong plug? You could get a shock, because the electricity will go through you to get back to the fuse box (not the outlet -- because the third wire is not there in this example).
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            let me re-word that:
            What if the thing you are using is metal and has a problem -- and it only has a 2-prong plug? You could get a shock, because the electricity will go through you to get back to earth (thats where the ground spike/water ground ultimately ends up) (not the outlet -- because the third wire is not there in this example).
            sigpic
            (Insert witty quote here)
              1. Appliances with exposed metal cases must be earthed when there is a possibility of a wire touching the case.
              2. An RCD should protect you against a live/earth or neutral/earth shock, but not always.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Not unless you have a fault.
                In the US neutral and ground are also connected together in the breaker box on the building.
                In large buildings that will also be the case in the major sub panels.
                If you have volts on neutral then you have an open or high resistance somewhere in neutral.
                The difference is current.
                Neutral has it.
                The ground shouldn't have any.
                Mann-Made Global Warming.
                - Dr Seuss
                • delaware74b
                  • Apr 2009
                  • 628
                  Actually, in the US, the neutrals and grounds are tied together in first panel with overcurrent protection (fuses or breakers). All subpanels beyond the first the neutral busbars are separated and isolated from the grounds per NEC.
                  In steel buildings, the frame is also bonded to ground along with any gas lines (propane or natural gas) and water lines (copper).
                  Stupidity should be a crime, especially for drivers. I have NO patience for them.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    water ground is a dying term... a lot of new builds use PEX instead of copper for the water pipes... so water grounds are generally unreliable, as many repairs are also being done in PEX. Even if the whole run is copper now, in 5 years there may be a pex repair downstream...
                    sigpic
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5016
                      • New Zealand
                      American 220V electricity consists of 2-phase 110V while, European electricity is single phase 220V.
                      (http://buyersguide.bargainoffers.com...ge_guide.shtml)
                      -David VanHorn
                      • jamesbo
                        • Aug 2011
                        • 36
                        Actually US 220V is single phase with the neutral center-tapped to create 2-110V feeds.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          In older documentation it's referred to as 2-phase.
                          Never was technically correct but that was still the common name for a very long time.
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            That's not the way I read it.
                            What I see is 'not required' which is fundamentally different than 'not allowed'.
                            -- If you see something different in the NEC then please give me the article number because I don't want to search the entire 800 or 900 pages to find it.
                            It's also not how I've seen industrial buildings wired.
                            - Talking buildings with load centers up into the MW range and sometimes the size of a 2-car garage.
                            - The load centers contain 'the first' neutral busbars in that configuration because they start counting after ownership changes from the utility company to the site's ownership.
                            - There, the sub-panels feed by the load centers have their own grounding rods driven in below the floor slab and the sub-panels are wired as if they were residential Service Entrances in that inside the sub-panel they have isolation breakers on the input to the panel [not just on OP branch circuits]. The input breakers often break both line and neutral and such panels do have the neutral tied to ground via the busbar and the ground rod sticking out of the floor underneath them.
                            - In other words those sub-panels are electrically identical to a residential or office building Service Entrance configuration in every way - but they are fully inside the building. The input side to them is not owned or maintained by the utility company so they are not classified as the service entrance [the load center is] and thus they are not 'the first' neutral busbars after the Service Entrance.
                            See, even the NEC is full of politics.
                            'Service Entrance' is an ownership thing, not a physical hardware thing.
                            - Dr Seuss
                            • severach
                              • Aug 2007
                              • 1055
                              Subpanel neutral and ground must be separated and you don't need the code book to know why. Connecting ground and neutral in a subpanel causes the supply ground to take half the neutral current. Ground becomes a current carrying wire making any ground supplied by that subpanel unsafe. Panels with ground rods are the only ones where neutral and ground can be safely interconnected.
                              Subpanels are also not allowed to be grounded. Multiple grounds creates ground loops. Only one ground per service entrance though this turns out to be impossible because many things act as grounds like water pumps and equipment set on concrete floors.
                              Once ground loops are ignored then grounding every panel mostly eliminates the problem of the ground sharing the current.
                              sig files are for morons
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                That's what I said.
                                And contrary to popular belief Service Panels aren't the only panels that can have their own Ground Rods.
                                Sub-Panels with their own Ground Rods are in fact very common in large and industrial buildings.
                                Anyone that thinks not should look around the next time they're in one.
                                - Dr Seuss
                                • corrize
                                  A funny fuse story – Lumix LX100 II
                                  by corrize
                                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                  10-19-2023, 09:58 AM
                                • triplefour
                                  Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                  by triplefour
                                  Samsung UN55ES7003
                                  made house call.
                                  red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                  psu has self test feature.
                                  disconnected from mainboard.
                                  determined PSU ok BL ok.
                                  suspect mainboard.
                                  disconnecting tcon has no change on operation.
                                  markings on mainboard:
                                  BN97-06531P 0151
                                  BN94-06123R
                                  found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                  for 54$
                                  second house call:
                                  with replacement mainboard, tv turns on, has sound,...
                                  07-13-2022, 03:53 PM
                                • matk
                                  Question about electricity
                                  by matk
                                  Hello, I have a question about electricity. Suppose I'm well insulated from ground and neutral, and the live wire of mains comes in touch with a wound in my finger, will this potential interfere with body voltages, hearth for example, or it will only go to its circuit return path ?
                                  Thanks!
                                  05-23-2024, 02:12 PM
                                • jesterace
                                  Samsung UE46ES8000 Blown fuse but no other signs of short
                                  by jesterace
                                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                  09-11-2024, 03:14 PM
                                • jshhh
                                  Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                  by jshhh
                                  Hi guys,
                                  I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                  How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                  Anybody know how to remove this type of fuse?
                                  (The fuse is toward the bottom of the image labeled F2)...
                                  06-17-2025, 01:35 AM
