No name/brand diode split in half/exploded cap
  • retiredcaps
    • Apr 2010
    • 9271
    This is literally a no name/brand power supply. I got this power supply as "it should work". Good thing I check everything before I use it.
    Notice the blown in half diode and 47uF 50V cap that unravelled itself.
    I might repair it just to learn something, but the only parts I'll save are the fan screws and maybe a few resistors.
    All caps are JEE brand.
    --- begin sig file ---
    --- end sig file ---
  • c_hegge
    • Sep 2009
    • 5219
    Re: No name/brand diode split in half/exploded cap
    It's a Sun Pro. I can see some heat damage on the PCB around that area, although it may still be repairable
    • mockingbird
      • Dec 2008
      • 5488
      Does anyone know where to get an ID of CSA markings? It's sort of the equivalent of the UL (Underwriters Laboratory) marking. UL has an online database, I couldn't find anything of the sort for CSA.
      • b700029
        Banned
        • Sep 2010
        • 640
        http://directories.csa-international.org/
        No results for 181613 so it's probably faked.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Seen this platform before, i have one lying around somewhere. It's fairly solid if you put in good caps and good secondary diodes, it'll do 400W as the transformer and inductor are big enough. Just check that the primary transistors are 13009s.
          A working TV? How boring!
          • retiredcaps
            • Apr 2010
            • 9271
            I see 13007-2 (x2) and 10401 (with a F symbol - probably Fairchild).
            400W is 200W more than I will ever need for my purposes.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              13007s will give about 300W given that the output diodes are adequate (efficiency is kept high). Use at least 30A rectifiers on all rails and it should do well.
              • mockingbird
                • Dec 2008
                • 5488
                Either that or the directory is incomplete. I couldn't find 224353 (My PSU).
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Confirmed.
                  The 7700 on the transformers gives it away.
                  I have a Raidmax RX-380K (Sun Pro KY-480ATX) that looks almost exactly the same as yours but with even more undersized components. Many of the caps in it are cooked, which shouldn't be surprising as there's heat damage on almost the entire area of the PCB. Blame the tinfoil heatsinks for that.
                  IMO this PSU is a complete piece of junk not worth fixing. That aside, mine does have a few resistors and coils in it that may come handy for other PSU repairs, so I'm still keeping it. At least yours has input filtering.
                  By the way, it looks like the 5vsb circuit committed suicide in yours. Probably went overvoltage and that's why you see that small exploded cap.
                  • japlytic
                    • Oct 2005
                    • 2086
                    On the split rectifier are the letters "FR" for Fast Rectifier, and it appears to be a 1A unit, and hopefully, the number at the end (e.g. 107) is still readable.
                    If this number cannot be read, you can safely use a FR107.
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      I have a logitech brand psu for fiddling around with electronics when I need a higher current. It seems to have a similar board, I will go take a look at what the model of it is, incase you need me to read parts
                      -Ben
                      Muh-soggy-knee
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Ok it appears that mine has a smaller primary heatsink on it, but its rated for "500w"
                        Anyways, the 5vsb circuit looks to be identical, so I will take a look at it and reply what stuff I find.
                        -Ben
                        EDIT: sorry i forgot, its a logitech PS500AC
                        Muh-soggy-knee
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Don't think Logitech ever made computer PSU. Maybe Logisys.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Ok, the diode that blew up is actually a FR107 on mine. Also note that in the 4th picture he gave us, the 100 ohm resistor next to the middle transformer is toasted a bit.
                            Two interesting things are, one, his psu has two 470uF input caps when mine has two 680uF ones. Second, his bridge rectifier is made of an assortment of diodes, mine is just 4 of the same type(large barrel).
                            -Ben
                            Muh-soggy-knee
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Heh, your right, sorry my mistake, its a logisys
                              -Ben
                              Muh-soggy-knee
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3113
                                In that case it's a keerda built unit. This one is a sunpro. They use similar designs, as do most small, cheap chinese manufacturers.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Heh, thats strange, cause the circuit boards are almost exactly the same, but a few of the components are different.
                                  -Ben
                                  Muh-soggy-knee
