How bad is this phone charger?
  • lti
    • May 2011
    • 2546
    This is a Just Wireless Blackberry/Treo charger that was purchased a few years ago. It produces 5VDC with an unknown maximum current (they put the wrong label on it).
    There is no fuse. The bridge rectifier diodes are 1N4007s. The primary filter cap (C1) is a 4.7uF 400V Fullcon (the logo reminds me of Fujicon), and the small cap next to it (C4) is a Jakec 33uF 50V. The output filter cap is a CA 470uF 16V and is probably not low ESR. The largest cap is 8mm in diameter. It has a very small transformer.
    There is also a current sensing circuit on the output. It is a voltage divider in parallel with a diode. The voltage divider is connected to the base of an S9015 transistor that switches on a yellow LED if the current draw reaches a certain level. The LED is a bicolor yellow/red part, and the red section is powered constantly.
    I tested this charger by connecting it to my cheap computer speakers. The amplifier produced a buzzing noise that sounded like a nest of angry bees. I turned the volume up and turned the charging indicator into a level meter. The charger didn't like that, judging by the smell it produced.
    Is this charger dangerous? Is there anything that needs to be improved? I am not currently using it, but I am keeping it as a spare.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: How bad is this phone charger?
    Looks similar to this one, but no optocoupler?
    https://www.badcaps.net/forum/showthread.php?t=11786
    • lti
      • May 2011
      • 2546
      Should I add a zener diode on the output for protection?
      How much power will it be able to produce? I don't think it could handle a current draw of 500mA. That transformer is too small.
      Should I install a low ESR output filter cap? I have a 1000uF 10V cap that is low ESR and can fit in the case.
      • lti
        • May 2011
        • 2546
        I just opened this charger again and need to make some corrections:
        The primary filter cap is a Fullcap RD series. The brand name is printed in the same font that Fujicon uses. I don't think the two brands are related.
        The Jakec cap is actually 0.33uF.
        This charger produces 5.98V with no load. With my headphone amp connected to the charger, the output voltage is 5.20V. When the charging LED turns on, the voltage is 5.14V. This appears to be an unregulated power supply with no feedback circuit.
        • japlytic
          • Oct 2005
          • 2086
          Some serious corners have been taken in this charger...
          • PlainBill
            • Feb 2009
            • 7034
            And your point is???
            It is apparent the Blackberry / Treo has it's own power regulator that both charges the battery and provides the proper voltages to the electronics. The 1N4007 is a reasonable choice as an input rectifier for a low current power supply. The power supply was not designed to provide power to a headphone amp. Complaining about the high ripple is pointless.
            Is it dangerous? Only in the hands of someone foolish enough to make modifications without understanding it's design.
            PlainBill
            • Toasty
              • Jul 2007
              • 4171
              Ouch!
              veritas odium parit
              • lti
                • May 2011
                • 2546
                I know that it was designed to charge a phone and that the phone has its own regulator inside. I connected it to an amp because it would allow me to measure the output voltage of the charger under load. I realize that the components they used will work fine for this application.
                I was wondering if its output voltage could rise to a level that would damage a phone and how much power it might be capable of producing. It should work fine as a phone charger until something fails. The charging circuit in a phone might not be able to handle nuch more than 5V.
                I actually did connect it to a phone. It didn't get very warm, so it doesn't need upgraded. The charger works well for its intended purpose.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Yes, but phones have protection diodes. Unless corners have been cut in the phone as well...
                  The charger isn't able to supply enough current to melt something if that's what you're asking. Okay, maybe it'll melt itself. But not anything more than that. Instead of a fuse you likely have a fusible resistor somewhere in the primary. It is usually in series with the AC input, before the rectifier, but that isn't always the case.
                  A working TV? How boring!
                  • lti
                    • May 2011
                    • 2546
                    There is a resistor before the bridge rectifier.
                    I never said that the diodes were too small. The DVD recorder I tried to repair used the same diodes in its bridge rectifier. I know that phones have regulators and a charging circuit inside them. As I said in my previous post, the amp simply provided a load that would allow me to measure the output voltage. I don't rememmber saying that I planned on using it for anything other than charging phones.
                    Originally posted by Toasty
                    Ouch!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      The fusible resistor is used to limit the current that the charger can draw from the mains. If you try to draw more, it doesn't allow you to. If you keep trying, it eventually blows. It's the reason why it's not feasible to squeeze more current out of this type of supply (also why it is inherently safe for its intended use - even if the feedback loop goes bonkers, the current draw of the phone will always keep voltage in check).
                      It also allows the use of a really lame switching transistor... If you change the fusible resistor for a regular fuse, the transistor will likely blow to bits before the fuse does.
                      • lti
                        • May 2011
                        • 2546
                        I am not going to upgrade the switching components to try to get more power from it.
                        This will be my emergency replacement charger. I will use it when another 5V charger fails. I might be able to adapt it to use the tips that came with a Philips USB charging cable along with the included tips.
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                        • DanPoka
                          Allview phone charger A248-NB2-501000
                          by DanPoka
                          I've got an old phone charger which cannot hold voltage, it goes from 5V to 4V the fault only seems to happen when charger has been on for a while e.g. when warm. Fault happens when high current or low current is being drawn from charger. I've checked capacitors for capacity and ESR and I think they are still good, I've even replaced a cap to get better ESR. Fault still happens it goes slowly from 5V to 4V then interrupts power and restarts. Because it performs on high current (0.67A) and low current (20 mA) the same way I'm guessing it's not the caps but more likely the switching IC. However...
                          02-22-2024, 04:41 AM
                        • motormayhem
                          Lenovo T460 Only Charges on One Charger
                          by motormayhem
                          Laptop Question
                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                          05-12-2023, 01:46 PM
                        • SluggerB
                          Help with trying to fix phone that is not charging (Pics inside)
                          by SluggerB
                          I have two TCL A30 phones.
                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                          08-12-2024, 08:11 AM
                        • keeney123
                          new OS on a Sonim XP5s phone
                          by keeney123
                          To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                          I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                          05-13-2022, 07:19 PM
