Deceptively simple USB charger
  • Badcappy
    Banned
    • Aug 2007
    • 52
    I have a tiny USB charger that decided to stop working completely, so I opened it up and found and fixed a loose supply wire and it works now, but one thing that caught my attention was how simple the SMPS circuit looked --- no ICs at all, only common discretes. I decided to trace the PCB to see if I could figure out how it worked, but the circuit (attached) was a little too difficult for me, someone with moderate electronics knowledge, to understand; I can see the basic parts like the primary rectifier, reservoir cap, transformer/feedback optocoupler, and secondary rectifier (half-bridge only, but not too surprising as the supply is only rated for 300mA), but how the oscillator/feedback actually works is totally not obvious. Noticing how small the reservoir is (2.2uF), does it somehow cleverly use the ripple current to start the oscillation? It sure starts up and gives a pretty clean and steady 5V at the output.
    Can anyone here give their thoughts on this circuit, especially the primary oscillator? The secondary side is rather straightforward. Here's what I've figured out so far:
    Q1 is the switching transistor; the top coil on the primary is the main switching coil, the second coil on the primary provides a low voltage (<25V) rectified through D8 and filtered by C4 to power the feedback loop
    Q2 somehow regulates the oscillator via the feedback loop to control the output voltage
    C2, R3, and D6 are the transient suppressor
    C3 might be the oscillator cap
    DZ1, a 4.3V(?) zener, sets the output voltage
    Q3 and Q4 control the charging status LEDs
  • POM_MJ
    • Aug 2009
    • 228
    Re: Deceptively simple USB charger
    look like 2-transistors 5VSB circuit in ATX PSU.
    Q1 Base-Emitter might be swap to circuit below, I guess.
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
    • everell
      • Jan 2009
      • 1514
      I agree. Looks like a typical 2 transistor 5vsb circuit. Capacitor C4 is most likely the "critical capacitor". If it goes bad with age, the output voltage will probably increase beyond spec and maybe damage your equipment. It may be a cheap solution, but I prefer circuits that use a pwm chip for voltage regulation.
      By the way, you did a great job on making the schematic, and your analysis was also good. Keep up the great work.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        It has an opto and a voltage reference. It's quite unlikely that a dried up C4 will make the voltage go up. Or am i missing something?
        A working TV? How boring!
        • everell
          • Jan 2009
          • 1514
          High ESR on C4 means fluctuating voltage (not good DC) feeding the opto and the two transistors. This is what causes the two transistors to drive the transformer harder. It is popularly called "getting Bestec'ed"
          • everell
            • Jan 2009
            • 1514
            Here is my analysis of the problem
            https://www.badcaps.net/forum/showthread.php?t=10301
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Thanks, i get it now.
              • Badcappy
                Banned
                • Aug 2007
                • 52
                Thanks for the analysis, and the circuit does make a lot more sense with Q1 connected as POM_MJ showed, but unless the pinout on Fairchild's site for the E13003 is wrong (http://www.fairchildsemi.com/pf/KS/KSE13003.html), it really is connected as shown. I've attached the actual PCB layout with the components identified.
                • everell
                  • Jan 2009
                  • 1514
                  Check that Q1 one more time - I would have to agree with pom-mj correction. The R1 is a startup resistor. I don't think it would work properly the way you originally drew the schematic.
                  • Badcappy
                    Banned
                    • Aug 2007
                    • 52
                    Finally found the time to check Q1 more thoroughly, and indeed their datasheet was wrong on the pinout.
                    Also replaced the "critical capacitor" with a new bigger one (Nichicon 63uF/50V), just in case. Output voltage didn't change, but this PSU doesn't seem to regulate well with no load --- at less than ~2mA the voltage hovers around 5.5V, but with just a little bit more current draw, around 2.5mA, the output drops to 4.98 and stays there almost perfectly all the way to 300mA. Is this normal for simple switchmode supplies like this?
                    • POM_MJ
                      • Aug 2009
                      • 228
                      because of this circuit isn't just 5V power supply, it's output has config to current source for charging purpose.
                      D8.2,R8.2 and Q4 are current sense.
                      Q4 turn ON, LED11 lit while charging.
                      generic SMPS always need a load resister to maintain voltage regulation.
                      • motormayhem
                        Lenovo T460 Only Charges on One Charger
                        by motormayhem
                        Laptop Question
                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                        05-12-2023, 01:46 PM
                        ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                        The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                        configurable for operating as either a Hybrid Power Boost (HPB)
                        charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                        4-cell batteries. Both configurations allow the battery to work with
                        the adapter together to supply the system load when it exceeds
                        the adapter capability, referred to as system Turbo mode. HPB
                        charger configuration reverse-boosts battery energy to the system
                        bus to help the adapter provide the system power in Turbo mode.
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • flat-earther
                        how to prevent a connected charger from draining battery when not charging?
                        by flat-earther
                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                        So the battery is backfeeding the charger and being drained.
                        How can I prevent...
                        08-07-2025, 01:04 PM
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • Johndill
                        Dell Inspiron 7567 LA-D993P odd charger issue
                        by Johndill
                        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                        Here are the tested scenarios:
                        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                        2. With the laptop off, plug in charger (LED says on) & the front charging...
                        11-16-2022, 10:55 PM
