Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Willawake says : Sorry dood, i edit your post to say that this is the discussion about the psu pictorial thread. if you want to say it, please say it here.
    Ludicrous gibs!
  • cods69
    • Oct 2005
    • 92
    Re: Power supply build quality pictorial
    Originally posted by japlytic
    ABS-6G76 satellite receiver
    MDS STB3110 satellite receiver
    Topfield TFPVR5000t
    Hey japlytic.
    I have had a Topfield TFPVR5000t since March04. (The Toppy is the best toy EVER, IMHO)
    What is your opinion of the PSU and the caps on it, and the caps on the main board for that matter?
    I notice alot of them are "Sam Young", while the big one is a "Sam Wha".
    I open it up regularly for HD removal/quick-transfer (I've got a WD250 in it) and do a quick visual inspection of the caps each time, just for safe measure.
    • japlytic
      • Oct 2005
      • 2086
      Originally posted by cods69
      Hey japlytic.
      I had mine since early 2005. Topfield must have later gone onto the cheaper Samxon capacitors for the mainboard, compared to your earlier one. The components in the power supply were quite decently sized, and has been fine for over a year, despite running a little hot.
      • Rainbow
        • Aug 2005
        • 1375
        I've had bought 300W Maxpower/Everpower PSU as a replacement for SkyHawk 250W - but it was weaker and the voltages were bad - so I promptly bought DTK PTP-3007 and sold that crap.
        • Oklahoma Wolf
          • Dec 2005
          • 353
          my 250W Channel Well CWT-250ATX is approximately 12 years old. This PSU is so old, the 92mm fan blows into the computer case instead of into the PSU.
          Primary caps are 470uf Matsushita, secondary side is a forest of Fuhjyyu... not one appears bad. This PSU was in regular use up until a month ago.
          • Rainbow
            • Aug 2005
            • 1375
            Can't be 12. There was no ATX before 1997 (IIRC). And I see "98" on the transformer.
            • Oklahoma Wolf
              • Dec 2005
              • 353
              I guess '98 would be about right - I only got that unit and a 10gb IMB hard drive a year ago in exchange for a Fujitsu 6.4gb hard drive. It belonged to a friend, who bought the case it came in well before I'd even met him.
              As it turned out, the IBM was DOA so I'm not sure I got the better part of that bargain
              • PeteS in CA
                • Aug 2005
                • 3582
                • USA, Unsure of Planet
                Notice the nice substantial heatsinks on the Deltas (and O/P trannies) and the Sparkle? Ya gotta keep the junction temps on those O/P rectifiers and power MOSFETS (possibly power transistors in the Sparkle) within reason. The power ratings are real on those.
                PeteS in CA
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  Did you also notice what appears to be a large burnt spot on the above Sparkle? I only noticed it after I posted the picture here... As far as I know, the PSU is still operating normally.
                  Ludicrous gibs!
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Was it caused by the larger resistor that's standing up? Because in either a 300W or 350W Fortron/Sparkle, I found that such a resistor was dissipating almost exactly its max power rating, either 5/8W or 1W. Aren't resistors supposed to be rated for at least twice their operating power?
                    • PeteS in CA
                      • Aug 2005
                      • 3582
                      Yes, I did see that. It looks like a 1W or (more likely) 2W. It could be disspating its rated power or a bit more, or it may simply be mounted too close to the PCB. Normal design practice at places I've worked at was to mount resistors 1/2W and higher spaced off the PCB to avoid scorching the board. Good design practice would be to use resistors at ~70% or less than their reated power (taking into account the operating ambient temp. US mil-spec requires 50% max.
                      PeteS in CA
                      • Newbie2
                        • Sep 2005
                        • 885
                        L&C DR-A300ATX, 300w, +5v 30a, +12v 10a, +3.3v 20a. +5v & +3.3v 160w max. 470uf VIVA primaries, secondary side Jun Fu & Rulycon, 2 caps and fan missing due to started recap work...
                        You're going to recap an L&C?
                        Since there is no ugly integrated-into-PSU-case fan grill on that, does it use a removable wire fan grill?
                        Please post the after-the-recap photo of that L&C after you recap it.
                        My gaming PC:
                        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                        ASUS M4A77TD AMD 770 AM3 Motherboard
                        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                        ASUS Xonar DG 5.1 Channel PCI sound card
                        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                        Antec Three Hundred Mid-Tower Case
                        Microsoft Windows 10 Pro 64-bit
                        Microsoft Windows 7 Ultimate SP1 64-bit
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Nahh, it was just for fun... And to have an emergency extra PSU at hand...
                          I already recapped it, See here...
                          The missing fan was because I put a 92mm fan in the bottom of the PSU instead, to reduce noise. And because the 80mm one started to fail and I had a 92mm one just on my bench
                          That PSU came from a real cheap case, has powered a friends comp a few months before he got a real PSU, and after that my brothers till the caps failed and it would no longer turn on...
                          • Newbie2
                            • Sep 2005
                            • 885
                            FSP700-80GLC power supplies as research have shown are 700W power supplies.
                            Maybe they used the board for the FSP700-80GLC but changed the components?
                            My gaming PC:
                            • Oklahoma Wolf
                              • Dec 2005
                              • 353
                              Probably. The protection circuitry board is also marked "FSP700-60GLN." Not that I need the extra power
                              The OST caps worry me a bit though.
                              • PeteS in CA
                                • Aug 2005
                                • 3582
                                The heatsinks in the 300W P/S are larger than the 400W? Puhlease! And there is no fring way those heatsinks in the "600W" unit are good for 600W continuous! 200W continuous might be pushing your luck.
                                PeteS in CA
                                • Oklahoma Wolf
                                  • Dec 2005
                                  • 353
                                  I trust Fortron to rate their units more or less accurately - this one's supposedly 85% efficient, so the sinks wouldn't need to be quite as big as my maybe 65% efficient 530W with monster heatsinks. I've seen Tom's Hardware pull the full 700W from Aopen's version of the FSP700-80GLN too without issues. The sinks in that one are even smaller to allow the 120mm fan. Not sure about the 600W rating myself, but I am quite sure it'll do more than 200W.
                                  Forgot to mention earlier that topmost sink is bolted to the case. I really need a digital camera
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    (referrng to the FSP460-60PFN) Holy packed, man! Does air actually flow through that? Sorry... I just had to comment...
                                    Ludicrous gibs!
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      looks like my fsp300-60gt.
                                      7 years of 24/7/365 and the yec caps are just starting to go.
                                      not bulging or leaking.just more ripple than i like to see.wasnt causing a problem yet but i will recap anyway.found during a routine cleaning and pm .
                                      confirms that bad qc may be the reason for bad caps.yec are well known crap but we have some here with lots of hard hours on them that are just now failing.
                                      btw i see a few fsp psu on sale at 22.00.
                                      i think the store ordered some so expect a full report :-)
                                      • Newbie2
                                        • Sep 2005
                                        • 885
                                        Re: Power supply build quality pictorial DISCUSSION
                                        Enermax EG365AX FMA, 353w, +5v 32a, +12v 26a, +3.3v 32a. +5v & +3.3v 185w max. 220uf Hitachi primary cap, secondary side Pce-Tur, no bulging after years of use...
                                        That's some good 350W power supply, but the pictures were a bit big.
                                        My gaming PC:
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          03-31-2024, 02:12 PM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • madan1
                                          555 based power supply getting too hot
                                          by madan1
                                          Good day.
                                          I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                          The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                          After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                          When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                          06-23-2025, 04:38 PM
