Power supply build quality pictorial DISCUSSION
This is a sticky topic.
Re: Power supply build quality pictorial DISCUSSION
Openend up my Dynex PSU while i was puting in my modded CPU cooler.My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™ -
Looks pretty nice on the inside. Those are some big heatsinks. I would just recap it if you can. It is complete, with a good sized transformer and full input filter.Comment
Originally posted by 370forlifeLooks pretty nice on the inside. Those are some big heatsinks. I would just recap it if you can. It is complete, with a good sized transformer and full input filter.My Computer.
2 Terabyte WD Caviar® Black™Comment
Do you mean those 2 really big caps or the smaller ones?
This Dynex is really my third PSU ive had in this computer the Golden Field one woulda bean number 4.Last edited by Phaihn; 08-21-2009, 10:15 PM.My Computer.
What were the last few power supplies in your computer? Were they replaced because you needed more power or did they fail?
That Dynex is nice, a good recap will ensure it will be reliable. The other power supply you recently bought can either be returned or used as a backup PSU, it's your choice.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bitComment
Originally posted by Newbie2What were the last few power supplies in your computer? Were they replaced because you needed more power or did they fail?
That Dynex is nice, a good recap will ensure it will be reliable. The other power supply you recently bought can either be returned or used as a backup PSU, it's your choice.My Computer.
Originally posted by 370forlifeSo essentially, he probalby just bought another 400W dynex.Comment
Originally posted by Phaihnyeah just i dont know if i can do that without wrecking it but i do have a BAck up now lol.
Its a lot easier than you may think with a power supply. The pcb is a single layer (only some high end psu's have more than single layer pcb's), and its a lot harder to ruin the traces because they are huge and they are made of solder. The only thing you have to worry about is the heat of your soldering iron, as those huge traces can suck away the heat so you have to hold it there longer.Last edited by 370forlife; 08-22-2009, 09:40 AM.Comment
Originally posted by 370forlife(only some high end psu's have more than single layer pcb's)Comment
Originally posted by 370forlifeIts a lot easier than you may think with a power supply. The pcb is a single layer (only some high end psu's have more than single layer pcb's), and its a lot harder to ruin the traces because they are huge and they are made of solder. The only thing you have to worry about is the heat of your soldering iron, as those huge traces can suck away the heat so you have to hold it there longer.My Computer.
Soldering on a power supply is much easier than on a motherboard for the reason that 370forlife said before.
If you have a junk power supply, try practice some soldering on that.My gaming PC:
no dont have a junk PSU well not in BC whare i live but its in alberta.
only closest it this dynex or the golden feildMy Computer.
Also I think it might be more difficult to do a recap on that Dynex PSU, it's so cramped inside that there would be little room for removing and installing new capacitors.Last edited by Newbie2; 08-22-2009, 10:57 AM.My gaming PC:
Originally posted by Newbie2Also I think it might be more difficult to do a recap on that Dynex PSU, it's so cramped inside that there would be little round for removing and installing new capacitors.My Computer.
Brb taking back the New PSU.My Computer.
My Computer.
Those are HEC built units. Actually a 300W inside of it, but it will do fine for what you are using it for.Comment
Originally posted by 370forlifeThose are HEC built units. Actually a 300W inside of it, but it will do fine for what you are using it for.My Computer.
I have that Thermaltake too, it's powering an older AMD Duron 1.4GHz (5v-based system). 12v rail is a bit high, but voltages are pretty solid otherwise.
Capacitors are a mix of Teapo/Su'scon for the secondary side and Teapo or CapXon for the primary side. Not exactly great, but not bad either. Should last at least until the warranty expires.
How much did you get yours for? Mine was $40 from Micro Center, but after the rebates it was $25.Comment
$54 $5:60 more then the other one.My Computer.
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by madan1Good day.
I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar... - Loading...
