Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • Phaihn
    • Jan 2009
    • 842
    Re: Power supply build quality pictorial DISCUSSION
    Openend up my Dynex PSU while i was puting in my modded CPU cooler.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Looks pretty nice on the inside. Those are some big heatsinks. I would just recap it if you can. It is complete, with a good sized transformer and full input filter.
      • Phaihn
        • Jan 2009
        • 842
        yeah just i dont know if i can do that without wrecking it but i do have a BAck up now lol.
        My Computer.
        • Phaihn
          • Jan 2009
          • 842
          Do you mean those 2 really big caps or the smaller ones?
          This Dynex is really my third PSU ive had in this computer the Golden Field one woulda bean number 4.
          My Computer.
          • Newbie2
            • Sep 2005
            • 885
            What were the last few power supplies in your computer? Were they replaced because you needed more power or did they fail?
            That Dynex is nice, a good recap will ensure it will be reliable. The other power supply you recently bought can either be returned or used as a backup PSU, it's your choice.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • Phaihn
              • Jan 2009
              • 842
              The first one never faild the second one was the reason i had to get this Dynex i came home one day and the system was off andd when i tried to turn it on i just kept hearing a sparking sound and could see one when i openend up the case and i had to replace it thats why i got this one i think it cost me more then 100$ i dont remmeber what the first 2 were for brands but i think they were probley generics.
              My Computer.
              • Oklahoma Wolf
                • Dec 2005
                • 353
                #307
                So essentially, he probalby just bought another 400W dynex.
                Not necessarily - Huntkey's pretty big. Could be another platform entirely. But from looking at the label, I'd say it's overrated like the rest of the Huntkeys.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  Its a lot easier than you may think with a power supply. The pcb is a single layer (only some high end psu's have more than single layer pcb's), and its a lot harder to ruin the traces because they are huge and they are made of solder. The only thing you have to worry about is the heat of your soldering iron, as those huge traces can suck away the heat so you have to hold it there longer.
                  • Oklahoma Wolf
                    • Dec 2005
                    • 353
                    #309
                    I'd say "high power" more than "high end." You get enough power flowing, and you need a dual layer PCB no matter what name it goes by. Topower's a good example... most of their high power units are a far cry from what I'd call high end
                    • Phaihn
                      • Jan 2009
                      • 842
                      ok thanks but its still a complickated matter.
                      My Computer.
                      • Newbie2
                        • Sep 2005
                        • 885
                        Soldering on a power supply is much easier than on a motherboard for the reason that 370forlife said before.
                        If you have a junk power supply, try practice some soldering on that.
                        My gaming PC:
                        • Phaihn
                          • Jan 2009
                          • 842
                          no dont have a junk PSU well not in BC whare i live but its in alberta.
                          only closest it this dynex or the golden feild
                          My Computer.
                          • Newbie2
                            • Sep 2005
                            • 885
                            Also I think it might be more difficult to do a recap on that Dynex PSU, it's so cramped inside that there would be little room for removing and installing new capacitors.
                            My gaming PC:
                            • Phaihn
                              • Jan 2009
                              • 842
                              Also I think it might be more difficult to do a recap on that Dynex PSU, it's so cramped inside that there would be little round for removing and installing new capacitors.
                              agreed
                              My Computer.
                              • Phaihn
                                • Jan 2009
                                • 842
                                Brb taking back the New PSU.
                                My Computer.
                                • Phaihn
                                  • Jan 2009
                                  • 842
                                  Ok got somthing a bit better this time.
                                  My Computer.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    Those are HEC built units. Actually a 300W inside of it, but it will do fine for what you are using it for.
                                    • Phaihn
                                      • Jan 2009
                                      • 842
                                      It just better good for what i am useing it for this ones not going back.
                                      My Computer.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        #319
                                        I have that Thermaltake too, it's powering an older AMD Duron 1.4GHz (5v-based system). 12v rail is a bit high, but voltages are pretty solid otherwise.
                                        Capacitors are a mix of Teapo/Su'scon for the secondary side and Teapo or CapXon for the primary side. Not exactly great, but not bad either. Should last at least until the warranty expires.
                                        How much did you get yours for? Mine was $40 from Micro Center, but after the rebates it was $25.
                                        • Phaihn
                                          • Jan 2009
                                          • 842
                                          $54 $5:60 more then the other one.
                                          My Computer.
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
