Re: PC P&C Silencer 420W
The diode D304 and FET (?) Q302 are both shorted.
Also the little diode D303 sitting on the board is shorted as well.
I'm betting the PFC FET, since it would be inline with the PFC coil and would cause it to overheat in a failure, thus the burn mark (assuming a buck-boost configuration).Last edited by Trinite; 01-19-2011, 10:38 PM.Leave a comment:
You have to desolder them (not necessarily remove them) to test correctly. One could be bad and the rest are reading that short.Leave a comment:
Light dimming is not a good sign. I'm betting on the PFC or switcher FETs.
The low ohms on the mains cap -probably- means something nearby is toasted.Leave a comment:
Caps can (and do) vent out the bung without deforming the top, nor blowing the bung out. Also have been know to have pinholes in the can under the plastic wrap.
Check all components from fuse to mains cap and switchers. VISUALLY inspect all the MOSFETS and dual Schottky's for hairline cracks. Get the plastic away from that coil and inspect the coil for burns. Sometimes it's just the glue that has darkened from heat. Be sure to remove and replace all that kind of glue everywhere with silicone caulk. The glue can become conductive when it gets hot and darkens.
Check that F.U. mains cap, especially for open. Should charge up one way on the ohms scale, and read infinite on reverse polarity. If it opens, it will take out the PFC or switcher FETs.
The fuse is a fast acting 7 amp "pigtail" type. Replace the fuse, or temporarily jumper it with a strand or 2 from a piece of stranded wire. Use a table lamp (100 watt) inline with the Line (L) side of the mains. Test leads with alligator clips are useful.
( See: https://www.badcaps.net/forum/showpo...2&postcount=23 )
When you plug the PSU in, the lamp should pulse once or twice and go dark. If it stays illuminated, the input side is shorted and you'll need to find what component(s) is at fault.
If it flashes and goes dark, then try jumpering the PSU on by jumpering Green to Black on the mobo plug. Again, it may pulse and go dark. If it stays on, then the output side is shorted some where.
Report findings please.
ToastLeave a comment:
LOL!
Yeah, my bad. It's a Hitachi. It just made sense to see a FU in with OST's....
The really odd bit is the HP series. It's the same series as Capxon that has failed in the Apple Samsung PSU's at over 90%
>>making a sound like someone opening a beverage can and shutting off.<<
Was it a hiss-pop sound, or just a hiss?
ToastLast edited by Toasty; 01-19-2011, 03:51 PM.Leave a comment:
OST Caps! I expected better from PC P&C, although probably not the cause of the problem
I should clarify; the supply is 2 or 3 years old at this point. It just so happened it failed 20 minutes after I finished recapping the board of the machine it was in.Leave a comment:
This little bastard ran my newly recapped Biostar P4M900 for all of 20 minutes before making a sound like someone opening a beverage can and shutting off.
I opened it up, checked it out, no obvious burning, no open caps.
The fuse is open, so something definitely shorted, though I dont know how or what to test for.
That burned glue on the PFC coil is the only burnt spot Ive found on the entire apparatus. How likely is it that killed it?
http://colt45.ws/misc/silencer3.jpg
http://colt45.ws/misc/silencer4.jpgTags: None
by KYBOSHTrying to a fancy Wine and Can Beverage Cooler which wasnt working.
Model number AWBC242GGFD
Previous owner states that it needs a new motor.
When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
I pulled out the main control board to give a look.
Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
by KemerI bought a SOP8 apparatus for CH341A but zero document. What is this part for and may I use it to read and write to 25 series spi flash bios?...
by nubieI have an old PC Power & Cooling 750w EPS12V SLi power supply with the 80mm fan that is unresponsive except for the 5v Standby.
Green wire has 0.10v on it. Will not start PSU when shorted to ground.
There is an ICE2A0565 running the PSU and a
HY510N 'watchdog'.
Does anyone have schematics or an idea of where to start with this guy.
5VSB is at 5.06v connected to Motherboard. There is a 7805 and a diode running the 5VSB it seems.... -
by harpIt is time to upgrade my system, so I want to extend working surface with second monitor. The graphics card is Asus EN6600LE Silencer with 256MB, and have DVI and VGA output connectors. I try to find pure *.inf drivers (like in old days...), but nothing package beside a hundereds and hundereds MB instead... At last, downloading a last driver (148MB) from https://www.driverscape.com/download...eforce-6600-gt but in it, thre is no readme, install, setup or working inf file... So, nowadays is instalation hardware pass a new level of rocket science or I miss something? Pleas help if you have...
by bpjlHi,
We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...03-16-2025, 09:26 AM - Loading...
