It is time to upgrade my system, so I want to extend working surface with second monitor. The graphics card is Asus EN6600LE Silencer with 256MB, and have DVI and VGA output connectors. I try to find pure *.inf drivers (like in old days...), but nothing package beside a hundereds and hundereds MB instead... At last, downloading a last driver (148MB) from https://www.driverscape.com/download...eforce-6600-gt but in it, thre is no readme, install, setup or working inf file... So, nowadays is instalation hardware pass a new level of rocket science or I miss something? Pleas help if you have experiance with that, to speed up thinking process...
					how to install old display driver in win10
 https://www.nvidia.com/en-gb/drivers/details/45780/
 big but bloated with crap - you can deselect the crap with the installer
			by bohabohaHello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encountered an error.
 but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
 any help?-
			by ongobongoHi guys,
 I have a new project, a PowerColor RX6700XT GPU which starts up fine but crashes as soon as some load comes up, the driver install is enough for this. The install won't succeed and the card crashes with ramping fans.
 What I figured out so far:
 As the card starts up, all voltages are there.
 The core rails seem to work fine, all of them run at 500KHz (measured with a normal multimeter as I don't have an oszilloskop at hand).
 That said, I think I have a problem with one of the memory rails. The top two drMOS on the right side (see picture) power the memory....09-15-2023, 12:57 PM
			by osrexHello, this is my first post and im just a beginner, so be easy on me guy. thanks
 i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
 i have no datasheet at all for the LED lights, all i have is its length.
 long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
 as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
			by TraptorHi Guys,
 I have a Gigabyte GV-N960WF2OC-4GD card.
 I got his card in wrong state.
 Windows start normal mode and I got picture but after driver install I got only black screen. The PC is not freezing because I can reboot using keyboard.
 I tested the card with mats/mods and I did not recognize problem.
 for example the ./mats -e 20 got PASS.
 So, where can I find the problem?10-15-2023, 01:43 PM
			by davetheshrewHi
 Got a gigabyte eagle 3090 that had a blown 12v vrm and two fuses so fixed them both, card boots.
 It passes mats mem test no problem but if I run any mods test I get black screen and no response. Same if I put it on windows, install driver, black screen, nothing.
 Any ideas? I checked all resistances and voltages and all seems good, its very confusing.
- Loading...
 It work on both monitor flawless, out of box.
