how long should I trust an L&C?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Just noticed that I have an L&C PSU in a machine I built for someone. I have the machine in because one of the sticks of RAM is dead, and I'm wondering how long these L&C PSU's last? The machine was just built at the beginning of November.
    Ludicrous gibs!
  • Oklahoma Wolf
    • Dec 2005
    • 353
    Re: how long should I trust an L&C?
    They don't last very long usually - I always recommend replacing them immediately when this question gets asked. Mine ran for two years (almost a record for that particular 250W model), but spent a good portion of its final few months killing hard drives before I replaced it. Not even worth wasting one's valuable time replacing the caps in these IMO.
    L&C also goes by the name Deer - there are some other interesting threads here about their units.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      i would say in the range of 2 years also to see some cap bulging. what was the brand of ram that failed?
      better to recommend to upgrade to a different psu. (excuse: the psu might have caused the ram to fail....... ) it will be worse informing them that their pc is nuked later on.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Well... here's the rub- if I decide to replace the PSU, it will be coming out of my own pocket. I built the system 2 months ago, so it's still under warranty by me. I can't force them to change out their PSU just because I should've done it in the first place . So if I do it, it'll be to save myself the possibility of a complete meltdown later on. This person uses their machine heavily for their restaurant business, keeping all their records of the past 20 years in Quickbooks.
        Oh, and the ram that failed was a single stick of OCZ Value Series 256mb PC3200 2.5-4-4-8. The machine had two identical sticks in it, and only one failed. As soon as I isolated the faulty stick, the machine was back up and running 100% with no reload needed. It's currently approved for RMA through Newegg...
        Ludicrous gibs!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          ok how long is the warranty?
          you should try to find some reasonably priced but decent spec case and psu for business builds. like the ISO psu i posted recently. personally i would avoid cheap case and L&C for recent builds especially new hardware which needs more power.
          https://www.badcaps.net/forum/showthread.php?t=1126
          oh gawd i know the feeling. i usually spec only the most reliable for that even if they have to pay more. what is backup strategy? is that on UPS preferably APC.
          what psu can you find? see what you can get. i would upgrade the psu and spread the cost over several servicing charges.
          shitty about the OCZ.
          • Oklahoma Wolf
            • Dec 2005
            • 353
            Here are my suggestions for a good PSU on the cheap:
            5v oriented mainboard (no 12v connector): http://www.directron.com/fsp30060atv.html
            12v oriented board: http://www.directron.com/fsp30060thn.html
            Not being Fortron's cheaper "ATX" models, these should last a while. They're not perfect, but you probably won't find perfection at these prices
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Are Fortron's really good? I thought they were less reliable than some of the bigger names.
              Ludicrous gibs!
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                fortrons are good (they build for major brands including OCZ) it is just that when they use fuhjyuu caps then they are not long lasting?
                how do we know those dont have fuhjyuu?
                personally i use chieftec cases http://www.chieftecusa.com with http://www.highpowersupply.com/ psu for important builds. but it is not gonna be in your budget for only psu.
                any more ideas?
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Well, I had one that lived for about 12-18 months... It was a real pain at the end though, comp would not cold start etc etc...
                  Recapped it today just for fun, 4 Rulycons where leaking so I put TEAPO caps from a dead old Epox 8KHA+ mainboard in their place, it powers on now atleast (did not before) But when I had one 120mm fan and one 80mm fan plus a 50w 12v TEC connected to it the 12v line dropped to 10,6v... Dunno if this is because I'm not loading the 5v and 3,3v lines enough. (that where fine at 3,34 and 5.34v respectivley) But I sure do not want to test it on a real working mainboard...
                  If it where my customer or friend I had built this for I would have atleast recapped the PSU, I would not like to be you when one of the crap caps in that PSU fails miserably and short out the whole PSU which starts a fire and burns his house down... (Ok, maybe I was being a bit dramatic at the end but you get my point)
                  • Oklahoma Wolf
                    • Dec 2005
                    • 353
                    They're a bit less reliable than units like those from Zippy and high watt PC Power and Cooling, but more reliable than most I've seen. My 530W has been going a year and a half of 24/7 use with no sign of capacitor distress, unlike the Channel Well it replaced. Cost me a fair bit though - $160 Canadian shipped.
                    There's a chance low end Fortrons have the occasional Fuhjyyu cap in them, which is why I'm not suggesting the "ATX" named models, but their better units like mine seem to use mostly Teapo. In fact, mine's all Teapo. Still not the greatest caps in the world, but methinks they're not the worst either.
                    Edit - just wanted to point out Topower is the OEM for OCZ, not Fortron
                    Fortron is also found under their Sparkle and Powertech names, as well as Aopen and Nexus.
                    Edit 2 - I also wanted to mention I'm personally not yet sure if all the failing Fuhjyyu caps in Antec units are a result of excessively poor quality or poor cooling. Or both. CWT designs always seem to run hot to me.
                    • Newbie2
                      • Sep 2005
                      • 885
                      Normally, I've had good experiences with L&C power supplies
                      What the, this guy isn't telling the truth! If he did have good experiences with L&C power supplies, later he must of saw all his L&C power supplies blow up randomly.
                      Source: http://www.atruereview.com/razotech_...uter_case2.php
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
                      • japlytic
                        • Oct 2005
                        • 2086
                        I would never trust them, not even for a few seconds. In a computer store (The Disc Shop) they had a lot of L&C units - what should I do about this??
                        • Newbie2
                          • Sep 2005
                          • 885
                          What happened to that L&C 400W power supply you had?
                          My gaming PC:
                          • japlytic
                            • Oct 2005
                            • 2086
                            As I said elsewhere, I scrapped it.
                            • Daijoubu
                              • Mar 2007
                              • 12
                              My Deer 250W lasted 6 years before one small cap poped
                              • Spacedye69
                                • Nov 2005
                                • 698
                                • US
                                I have a couple cheaper FSP with fujjyyuuuii caps. The only dead Fujjyytyuui I have seen have been in Antecs. I will still be recapping them just to be safe!
                                • starfury1
                                  • May 2006
                                  • 1256
                                  Id replace it regardless, but if its being used in a business Dood id defiantly replace it asap.
                                  I know it to some extend it may leave you out of pocket but if it goes, they arn't going to be too happy with you at all if they lose there data.
                                  (let alone what per said, yeah maybe a bit of the top but its possible I suppose)
                                  The downside is the bad advertising they would give you.
                                  So treat it as money spent building good customer relations and hopefully if they are happy they will give you a good rap to others which my mean more work for you in the long run
                                  Word of mouth is the best advertising I think you can get and really only costs you good service and being friendly to people (ok mostly)
                                  (even marketing companies have finally woken up to this, and will give people goods so long as they plug them....thats a bit of a downside for consumers thought)
                                  Just my thoughts on it....
                                  Cheers all
                                  You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
                                  • dood
                                    Deputy dood
                                    • Mar 2004
                                    • 2462
                                    Well, it's still working after over a year. Guess I'm lucky for now. If I had some extra money, I'd swap them out now. Maybe in a few more months. I'll tell 'em it's a recall by the PSU manufacturer. Wishful thinking, maybe???
                                    Ludicrous gibs!
                                    • toastygoodness
                                      • Jul 2005
                                      • 813
                                      I'm lucky too, I got one from RaidMax (DR-300-ATX) that's actually lasted for more than 3 years. I guess it's because all it's got is a P4 Northwood 2.4Ghz, a POS ECS VIA P4m400 mobo, a Sony CD-RW, a Western Digital 120GB IDE HD, and a Radeon 9200 SE. Actually I'm suprised from all the hardware I have. But the computer isn't doing so well now, probably something's getting screwed up because the voltage fluctuates quite a bit. The Deer is also plugged into a APC UPS, so that's what might be keeping it going.
                                      • Tom41
                                        • Oct 2005
                                        • 336
                                        • England
                                        I had a Kobian Mercury 400W PSU (a rebranded Deer), that didn't even last one year before a cap vented. The PC it was in started rebooting at random, and the PSU would do a high-pitched squeal while in standby mode (after shutting down).
                                        https://www.badcaps.net/forum/attach...achmentid=4383
                                        You know there's something wrong when you open your PC and it has vented Rubycons...
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                        • piernov
                                          Beginner's guidelines
                                          by piernov
                                          You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
                                          There are 2 situations:
                                          1. You just want your laptop fixed
                                          2. You want to learn about fixing laptops
                                          Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
                                          Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
                                          If you are in situation number 2, then please continue and...
                                          09-20-2020, 09:46 AM
                                          Building a Laser / Spindle Engraving Machine very challenging
                                          by sam_sam_sam
                                          I have been trying to build this engraving machine for last few months it has very challenging to get the part together
                                          I had bought a very small engraving machine a few years and it sat in the box it came in because I could not find a reasonable priced laser controller and the same thing about the the motor controller ( plus the table was to small for what I want to do with it )
                                          I have some challenges about the machine controller as well because I want an offline function so I can run the project with out having a computer hooked to machine controller
                                          09-27-2020, 04:43 PM
                                          I just bought a SkyRc MC3000 battery testing machine very interesting device temp
                                          by sam_sam_sam
                                          I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
                                          The charger has four individual temperature sensors for each battery cell
                                          The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
                                          Or test...
                                          09-14-2022, 07:12 PM
                                        • Gjackson
                                          Ps4 Pro long blue light of death
                                          by Gjackson
                                          I have an NVA-001 Ps4 Pro with long blue light of death, visual inspection looks fine apart from dust and the very dried thermal paste which I cleaned and replaced, I scoped the board around for any shorts on capacitors and there were none, no blown fuses either. Looking under a thermal camera, southbridge gets warm along with APU and phases for the APU. I cannot tell if RAM is too cold? maybe not powered? but RAM chips are all the same temperatures. At this point I removed NOR and enabled UART to diagnose further. The only thing I get from UART is this following message:
                                          08-21-2023, 02:41 PM
