Ps4 Pro long blue light of death
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    I have an NVA-001 Ps4 Pro with long blue light of death, visual inspection looks fine apart from dust and the very dried thermal paste which I cleaned and replaced, I scoped the board around for any shorts on capacitors and there were none, no blown fuses either. Looking under a thermal camera, southbridge gets warm along with APU and phases for the APU. I cannot tell if RAM is too cold? maybe not powered? but RAM chips are all the same temperatures. At this point I removed NOR and enabled UART to diagnose further. The only thing I get from UART is this following message:
    secure loader build: Feb 27 2023 05:19:58
    (r10640:release_branches/release_10.500) [800MHz]
    AGESA: GL&MO.BDK W9313
    at which point it hangs indefinately.
    the only details I found about this was on a russian youtube video and some forums stating that most likely a possible fix would be to reball the RAM chips. I'd like to verify that this is indeed the issue and that the RAM is receiving power as to me it looks like it's slightly too cold. Please see the attached thermal images below.
    I'm basing my comparison agains The Cod3r's video on diagnosing a ps4 pro with long BLOD, although it seems the fault occured for different reasons the ram chips in his video seem to be getting quite hot compared to mine. see his video here
    https://youtu.be/K1-re0bchew?t=435
    Had I somehow corrupted or incorrectly resoldered the NOR IC the Serial data wouldn't be visible correct? Just want to confirm that I did not create this issue.
    Appreciate your time and help.
    Thank you!
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Re: Ps4 Pro long blue light of death
    Update:
    Found blown fuse F5106, seems to be powering some buck circuit.
    Doesn't seem to be fully open and instead measures 440ohms leads me to believe it died on its own, no short to gnd on either side. Should i try just replacing and testing?
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      Replaced fuse, the buck circuit sure enough is Ram power, the Ram heated right up as expected and i got a white light. Hope this might help some others who have the same issue
      • Tomylee
        Nintendo 2DS XL – Orange light, no blue light, signs of overheating
        by Tomylee
        Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
        Here's what I've observed:
        All ribbon cables are properly connected
        Battery is present and in good condition
        No reaction even with screens disconnected
        There's a visible burn mark / overheating sign on the metal shield, right above the CPU
        I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
        06-26-2025, 02:33 PM
      • blind2reply
        proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
        by blind2reply
        proscan 40ld45q
        Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
        After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
        No sound, no picture (used flashlight test).
        No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
        Digital voltmeter;...
        06-06-2021, 01:16 PM
      • icareservicezone
        Synology DS918+ blue light blink
        by icareservicezone
        Synology DS918+
        Model name : GDI41L2
        p/N: 08-06GDI4116
        Version: V1.6
        Problem : blue light blink...
        05-24-2025, 11:53 PM
      • cajoeg
        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
        by cajoeg
        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
        02-10-2025, 04:01 PM
      • dionzarek
        PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
        by dionzarek
        Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
        I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
        When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
        Any help to where should I check on or suggestion would be very appreciated....
        02-08-2025, 11:00 PM
