Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    #161
    Re: Power supply build quality pictorial
    Re the X-Box P/S, looks like they pewed the scrooch and didn't mechanically support the AC connector properly. Some laptops have this kind of problem with the jack where the adapter plugs in, including the Dell Inspiron 1000 I'm using right now. Basically the insertion and extraction force stresses and cracks the solder joint(s), and eventually self-heating breaks down the connection. My daughter had a Sony laptop that succumbed to this. Delta, Dell, and Sony are all decent companies, and I don't understand why they haven't figured this out.
    PeteS in CA
    • Spacedye69
      • Nov 2005
      • 698
      • US
      #162
      I just hot glued connector to pcb. I don't know why they couln't do this in the first place
      • waynewe
        • Aug 2006
        #163
        Rainbow
        Would you have the schematics for either Meico MPS-8804 or Frontier MPS-8831? I'm trying to repair MPS-8804 however found some badly fried resisters I think they were R213 and R215 (a group of 3 near the IC) and can't tell what they are.
        • Rainbow
          • Aug 2005
          • 1374
          #164
          Don't fix it. It's probably the worst PSU ever made. The resistors are fried because there are bad caps in the auxiliary power supply. The TL494 is probably dead too. Just put it in the junk pile. I take transistors, resistors and diodes from them for other PSU repairs.
          • jonnyGURU
            • Feb 2006
            • 244
            Let's take a look at a Hiper Type-R "580W".
            I'm currently reviewing one, but I'm taking my time this time around.
            The power supply is based on the Andyson AD-550 (as in 550W) and it does put out 550W no problem. Efficiency is a mediocre 75% average and there's no PFC.
            I was surprised that Andyson was using Fuhjyyu's!!!!
            There's also a couple JEE's in the mix (you can see one on the right)
            I can't tell what the primary caps are....
            But the navy blue color makes me think of Fuhjyyu's. Am I right?
            The biggest issue the Hiper has, and the primary reason why I got one and took it apart, is the lack of one-to-one connectors on the modular interface:
            Above you can see that 4-pins on the motherboard goes to only 2-pins on the power supply.
            Below is a shot of the PCI-e connector taken apart....
            Even though a PCI-e connector consists of three 12V and three ground, only two conductors on the power supply end of the cable are used! They don't use the third conductor at all.
            And there's only one PCI-e. The other PCI-e is obtained by taking two Molexes and adapting them to one PCI-e:
            Rest in peace BFG. You were... a job...
            • killjoy
              • Jul 2006
              • 20
              #166
              Here's a couple of pictures of Antec TruePower 380SP with covers removed. I've done enough reading and I'm about to begin my recapping career with this. I bought some (500pcs) Nichicon caps, mostly PL(M) series, to begin with so there is more to come
              Edit: Oh yeah, this beast is all-Fuhjyyu as Antecs tend to be.
              Hi-res pictures and more can be seen here:
              http://sourapple.dnsalias.net/photos/?album=60
              • MD Willington
                • Sep 2004
                • 702
                #167
                It's a tight squeeze in there...
                Ya'll think us folk from the country's real funny-like, dontcha?
                The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                • killjoy
                  • Jul 2006
                  • 20
                  #168
                  Here's aopen 300W W/PFC that came with HQ08 case. Big o/p caps were 1 jamicon, 1 fuhjyyu (bulged and leaking) and 3 teapos. Replaced with physically larger Nichicons without much effort. Input caps were teapos (and will be as I dont have replacements for i/p caps).
                  Hi-res pictures and more are available in http://sourapple.dnsalias.net/photos/?album=60 as always.
                  PS. The 380W Antec mentioned above is now working again. Recapped with Nichicons exept for i/p caps.
                  • japlytic
                    • Oct 2005
                    • 2086
                    Touch Electronic T60-9313 (www.bothlandusa.com), made in 1999 for a UMAX Gemini D-16 scanner.
                    Hitachi HP3 150uF 400V and LTEC TK 100uF 25V on primary side.
                    +5V 2.5A rail: LTEC LZG 3300uF 10V and LTEC LZF 1000uF 16V before output inductor, LTEC LZF 1000uF 16V after it.
                    +/-15V 0.3A rails (each): LTEC TK 220uF 25V befoe output inductor, LTEC TK 100uF 25V after it.
                    +24V 1.6A rail: Nippom Chemi-Con SXE 1000uF 25V (should be 35V) before output inductor, Teapo SX 470uF 35V (bulging ) after it.
                    Leakage between Live/Neutral and Earth was caused by glue on the controller PCB module .
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      #170
                      fsp aurora 350 fsp350-60pn
                      secondary caps are mostly jamicon with a few teapo
                      • yanz
                        • Nov 2004
                        • 910
                        #171
                        Delta DPS-125EB-1 120W PSU
                        (or, DPS-125EP-1 <- on the PCB)
                        thumbnails:
                        • japlytic
                          • Oct 2005
                          • 2086
                          AcBel API-8628 110W
                          Teapo SK 330uF 200V primary units, Rubycon YXG 1000uF 10V on +5VSB, Rubycon YXG 1000uF 6.3V before +3.3V regulator; Rubycon YXG 2200uF 6.3V after it, Nippon Chemi-Con SXE 470uF 16V before and after +12V output inductor, Rubycon YXG 1000uF 6.3V befor and after +5V output inductor, with a number of general purpose Lelon units as well.
                          • jonnyGURU
                            • Feb 2006
                            • 244
                            Originally posted by japlytic
                            AcBel API-8628 110W
                            Wow. That doesn't look like a "AcBel of today."
                            Is that one of those old IBM units?
                            • Tom41
                              • Oct 2005
                              • 336
                              • England
                              #174
                              Viglen AT (not ATX) PSU, used to be in my web server until I got the Compaq Proliant.
                              According to the label an 'own-brand' Viglen PSU - but appears to have Seasonic insides. Input caps are TOSIN, output caps are a mixture - JP CE-TUR, CEHTR (with a sort of EZE logo), and one Rubycon.
                              The PSU had a very long life - in fact, it would still function perfectly now if I were to connect it up! The only reason I stopped using it is because I have no need for a Pentium-75 server any more
                              You know there's something wrong when you open your PC and it has vented Rubycons...
                              • jonnyGURU
                                • Feb 2006
                                • 244
                                Definitely Seasonic.
                                • PeteS in CA
                                  • Aug 2005
                                  • 3581
                                  #176
                                  What was the clue, jG? The word "Seasonic" in the silkscreen of the second pic?
                                  PeteS in CA
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    #177
                                    hell the thing has seasonic logo's all over it.have to be blind to miss them.
                                    • Rainbow
                                      • Aug 2005
                                      • 1374
                                      #178
                                      DTK PTP-3007 (Macron power OEM)
                                      G-Luxon 680uF on primary:
                                      Overall view:
                                      Output caps:
                                      G-Luxon output caps, the small orange one is JPCE-TUR:
                                      Macron-like label:
                                      Is in use since 2002 without any problems:
                                      • Rainbow
                                        • Aug 2005
                                        • 1374
                                        #179
                                        Another DTK - this time PTP-2007 from 2001, works fine:
                                        Nothing wrong, just some dirt:
                                        Unknown 470uF caps on primary side (the same brand is on secondary, along with some JPCONs and JPCE-TUR):
                                        • killjoy
                                          • Jul 2006
                                          • 20
                                          #180
                                          Macron Power MPT-301P
                                          Looks pretty much same as the DTK above. Original caps were same brand except for the input, mine has Fuhjyyu
                                          Recapped output caps with Nichicons while I was at it. Did not have scope or ESR meter to check originals with, but none were visibly at fault.
                                          This one had a bug inside as well. Nicely charred between ip lytic contacts
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                            Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                            by momaka
                                            More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                            02-15-2022, 12:43 AM
                                            Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                            by momaka
                                            Boston Acoustics fans, this thread might not be for you.
                                            A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                            01-30-2022, 11:57 PM
                                            DVR camera recorder switching power supply capacitor failure really
                                            These cheap non brand capacitors at it again
                                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                            Well at least I have the cameras back on line I to try the...
                                            01-22-2022, 06:28 PM
                                            DVR recorder Switching power supply Failure
                                            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                            This...
                                            05-27-2023, 03:03 AM
