Power supply build quality pictorial.closed.use part 2
This topic is closed.
This is a sticky topic.
Re: Power supply build quality pictorial
Touch SP9627 (50W)
Has overvoltage (SCR crowbar) and overtemperature protection (made in 1997 with no +3.3V rail).
Tosin LG2 Series 400V 100uF main capacitor with the rest being Jamicon TK Series.
3300uF 10V and 1000uF 16V before +5V output inductor wint 1000uF 16V after it.
1000uF 16V before +12V output inductor with 220uF 25V after it
100uF 25V before and after -12V and -12V regulators.
220uF 25V before +5VSB regulator and 100uF 25V after it.
Delta cooling fan.
Unbranded 200W AT unit (UNNA-230A on PCB, made in 1993)
220uF 200V primary JP CE-TUR capacitors; the rest are GPE units (Anyone else seen GPE units?).
1000uF 16V on +12V rail
1000uF 10V x2 on +5V rail
220uF 16V Jamicon TK each on -5V and -12V rails
Non-approved capacitors used as X and Y class units
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Enermax Eg365p-ve
ENERMAX EG365P-VE
Not sure if this one has been posted before, think some thing similar may have
This Supply replaced the Macase PSU and has been in service for aprox 5 years.
(probably really due for recap)
I have known this thing to hold the computer (AMD socket A GB recapped MB) for about a second when the mains dies and come back on
(think they are switching phases)
Mains DC filter caps are
Hatachi 820 uF 200 Volt
(forgot to write down if it was 85C or 105 C doh!)
The rest are CE-TUR
bit hard to tell but think the following values, didn't really try and tell which rails
3300 uf 16V x1
3300 uF 10V x2
2200uF 10V x2
1000 uF 10V x2
330 uf 16V x2
100 uf 16 x1
Few misc caps of course
chip UC 3842 hiding under mains wires (near fan) do pdf search on it if you want to know more
LM 339 I think was there somewhere too.
whats on the heat sinks a bit hard to tell
Dood great idea this post Thanks
Hope this helps someone further down the track , Cheers all
Last edited by starfury1; 12-01-2006, 07:51 AM.You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
Kobian Mercury ATX PSU, model KOB AP4400XA.
HEC caps on the input, "F" (planet logo) caps on the output.
Died after 8 months of service - note the vented cap by the fan.
PC it was in kept rebooting occasionally, sometimes doing a 'bad memory' error beep code from the BIOS, and made a high-pitched squeal (like a CRT TV) when in standby mode.
I've also enclosed the best picture I could get of the F-Planet logo; did we ever identify these?
Also, I disconnected the PFC (mounted to the top case) to take these photos, rest assured it DID originally have one
You know there's something wrong when you open your PC and it has vented Rubycons...Comment
Here is the Minebea SMPS PSU: SPW1562
1. The case
2. The AC inlet
3. The internal view
4. The Output LPF
5. The ASIC controller
6. The reservoir Cap (input)
7. The line filter X-Cap (Panasonic)
This is perhaps made by LiteOn (OEM), as the LiteOn logo is seen on the PCB (picture 7).Comment
Built in July of 1999. If that's an NMB fan, that'll probably put out its full rated 200W for a long time. Appropriately sized heatsinks and O/P transformer and nice beefy bridge rectifier and O/P rectifiers (Lite On brand perchance?).
Heavy metal is goodness.
PeteS in CA
****************************Comment
Good eye, gonzo. The switch devices are also in TO-3P packages, much better thermally than TO-220 devices. Of the O/P rectifiers, the one nearest the camera in the one pic is a TO-3P, the center one is TO-247 (thermally similar to TO-3P), and the far one is a TO-220 device (probably the +12V rectifier).
PeteS in CA
It's been a while since I contributed to this thread, but here's a 560W Silverstone ST56ZF, aka Etasis EPAP-560. Caps are Nichicon, Rubycon, and Teapo. Very heavy PSU.
Teapos on the secondary for 3.3v and 5v.
One of three identical primary Nichicon main filter caps.
Rubycon for the 12v, hidden too far in there to make out which series.Last edited by Oklahoma Wolf; 01-05-2007, 07:34 PM.Comment
Trans-Am TA-300 (can anyone identify its wattage?) from the late 80s.
Non-approved X and Y class units.
Rubycon 220uF 200V CEW primaries.
Rubycon 1000uF 16V CEW on +12V rail.
Rubycon 2200uF 10V YK before and after output inductor on +5V rail.
Small value capacitors have brands Sowa, TMC, Huder and NKL.
+5V rectifier is 15A, with the +12V rectifier having a current rating of 3A
MJE13008 primary switching transistors.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Astec's custom built TEC power unit. Looks pretty solid. Full of UCC/NCC and Nichion caps.
Q6700 @ 3.6 GHz
Zippy GSM-6600P
Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
Abit IP35Pro
ATi HD4870Comment
Guess which unit we have here?
Q6700 @ 3.6 GHz
Zippy GSM-6600P
Abit IP35Pro
ATi HD4870Comment
Is it a 450-500W Antec SmartPower?Originally posted by Super NadeGuess which unit we have here?
TGR 250W PSU Model No. FV-250N26
Lead Year/TigerPower manufacturer.
circa 2002 build date, been powering a Micron PC w/ 1.1 GHz Tualatin core.
All caps are Fuhjyyu! None appear leaking, and unit working. Been running for 4 years at a state health department! The fan is relatively high CFM and noisy.
Lived in a well ventilated case.
Maybe that's why the crap caps haven't 'jiffy-popped' yet.
“We the willing, led by the unknowing, are doing the impossible for the ungrateful.
We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”Comment
InWin/PowerMan (Fortron) FSP250-60GTA.
I believe there are also identical PSU's sold under the Sparkle and AOpen brands with the same model number.
I have 4 of these, this one I suppose is the worst because it's putting out -16V on the -12V line. This one has 3 leaking YEC 3300uF 10V caps, so I'll probably replace those. The others also have some bulged caps, only 1 of them appears to be perfect, but I didn't actually open it.
Weight including the cables and the whole casing is 3# 1-1/8oz. That should be 1.39kg if I did the conversion right.
I have 2 of these on Asus P2B-F's, and 1 crammed into a Gateway 433c with Intel FJ440ZX motherboard. The other has been used for random testing and apparently the -12V line got hurt somehow.Comment
Hey, I have the same Powerman 250W. All 4 of the YEC caps in mine leaked. I believe the fact that the fan is thermistor controlled might have added to the problem. It must have overheated the caps when the fan is barely turning.
Mine came from an Inwin S500 midtower.
Deciding whether to toss it or recap it. Must source the small YEC cap equivalent.“We the willing, led by the unknowing, are doing the impossible for the ungrateful.
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
