Dat P3B-F complaining 'bout mah Bestec
  • Oerg866
    • Nov 2009
    • 61
    Hi
    My recapped bestec is working fine since months but i just connected my ASUS P3B-F to it and it says that -5V is bad... see pic.
    Anything to worry about? the other board, MSI KT6-Delta doesnt complain about it....
    Cheers
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Dat P3B-F complaining 'bout mah Bestec
    many newer power supplies did away with -5.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      More often than not, motherboard voltage sensors are very innacurate. The -5v rail is probably fine, but if you have a multimeter, use that to check it.
      • bigbeark
        • Jan 2010
        • 661
        The -5v is for ISA devices. What ATX version is your PSU? It may not have the -5v connector. Quick way to tell is to look at the 20-pin ATX connector on the PSU. If one hole
        in the connector has no metal piece inside it, it doesn't support -5V, and the reading on your P3B-F is meaningless.
        • Oerg866
          • Nov 2009
          • 61
          It's newer, got -5V etc, ATX 24pin
          • bigbeark
            • Jan 2010
            • 661
            So you are connecting to the P3B-F motherboard with a 24-pin to 20-pin adapter?
            • Oerg866
              • Nov 2009
              • 61
              Not really. I just leave the 4 pins hanging off the side.
              • evilkitty
                When your mom is complaining about her new cheap lights
                by evilkitty
                My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                07-23-2024, 01:27 PM
              • socketa
                Bestec ATX0300F5WA - fast,or slow blow, fuse?
                by socketa
                I bought a dead motherboard, and connected it to this PSU,
                Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                So now i truly got a bang for my bucks, and something else to try and fix.
                The fuse was blowen, and the top was blowen off of a TNY276PN chip
                The glass fuse didn't have any marking to say if it was fast or slow blow
                So i checked the marking on the PCB thinking that that would tell me,
                but it 's got a T/F8A printed on the board
                So should i get a fast blow fuse, or should...
                05-17-2022, 01:22 AM
              • macsoftware
                I need help a bout surface book bios me region
                by macsoftware
                hallo friends my surface book touch screen won't working after me region clean , idon t have the original dump the chip winbond is damaged plz help me
                05-09-2021, 09:33 AM
              • eccerr0r
                Bestec BPA201S-12V 12V@1.6A wall wart repair
                by eccerr0r
                110VAC-220VAC
                I had one of these croak on me, was wondering why it died.
                I had been running it on 120VDC (first half of my transistor magic smoke generator, err, inverter) and that was a suspect, turns out it wasn't.
                Cracked it open with a vise, it split up very cleanly. It's a cheap 3-transistor optoisolator feedback design, trimmed by sticking in resistors in a parallel slot.
                noted the output was shorted. Pulled secondary rectifier - short still there. Pulled out zener crowbar... short gone and zener was shorted! Checked switch transistor......
                09-27-2020, 11:32 PM
              • Gbolahan John o
                DELL 3310 PINEHILLS MLK MAIN BOARD 6L 19717-1
                by Gbolahan John o
                DELL 3310
                PART NO: PINEHILLS MLK MAIN BOARD 6L 19717-1
                SERVICETAG: 6TZZY93
                BIOS TPM COMPLAIN ERROR, PLEASE HELP ME REMOVE TPM COMPLAIN...
                07-19-2024, 09:34 AM
