Bestec BPA201S-12V 12V@1.6A wall wart repair
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    110VAC-220VAC
    I had one of these croak on me, was wondering why it died.
    I had been running it on 120VDC (first half of my transistor magic smoke generator, err, inverter) and that was a suspect, turns out it wasn't.
    Cracked it open with a vise, it split up very cleanly. It's a cheap 3-transistor optoisolator feedback design, trimmed by sticking in resistors in a parallel slot.
    noted the output was shorted. Pulled secondary rectifier - short still there. Pulled out zener crowbar... short gone and zener was shorted! Checked switch transistor... okay. Filter caps...okay.
    Replaced zener... working PSU once more.
    What was interesting: it's a 12V PSU that measured 12.2V OCV. It had a 13V 1N4743A crowbar. Not much room for error...
    Now comes the task of gluing the plastic back together. Ugh...
    probably tape + zip tie...
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Bestec BPA201S-12V 12V@1.6A wall wart repair
    Adding a diode in series with that 1N4743A, cathode to cathode, would add a diode drop to that nominal 13V (you could even select the magnitude of the diode drop by choosing a Schottky, ordinary, or ultra-fast rectifier).
    PeteS in CA
      master hoarder
      • May 2008
      • 12170
      What's a 3-transistor design?
      I only know of the 2-transistor self-oscillating (with opto feedback) and single transistor self-oscillating design (with or without opto feedback.)
      Either way, if it's a 2-transistor, check if there is a "critical" cap and replace it. If you've heard about the infamous Bestec ATX-250-12E "motherboard killer" PC PSU, then you should definitely inspect this design, as it's from Bestec as well. In the case of the ATX-250-12E, the 5VSB circuit uses a 2-transistor self-oscillating design with opto feedback and a "critical" startup cap. The reason why that startup cap is called "critical" is because when it failed, it would greatly overshoot the voltage on the output, often killing the attached motherboard on its output. The startup cap is on the primary side - typically rated for 10-47 uF and 25-50V. If it's a crap brand, better replace it now than have a completely dead adapter down the road with possibly burned out attached devices.
      If you're just going to use the adapter yourself in a dry location and not intend to give it to anyone else, you can probably just go with the zip tie method.
      When fixing stuff for myself, I'm too lazy to do even that and usually just wire-tie the case together (i.e. those wire ties you get for bags/bread at the grocery store.) But if I will be giving it to someone else, I glue it together with the proper glue (PVC or super glue, depending on the type of case plastic used.)
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Not sure, I counted two transistors plus mosfet switching, so three transistors. The optoisolator has one more.
        Well, the zener diode probably would protect against the "critical" cap failure as it would clamp the voltage to 13V.
        Oddly enough I don't recall seeing any small electrolytics on the board. Only the main filter cap and a two cap pi filter on the output were electrolytic. Rest of the caps were ceramic or polyester I thought...ugh do I want to reopen this thing...
          master hoarder
          • May 2008
          • 12170
          So 3 discrete transistors on the primary side?
          I don't count the transistor in the opto, since the opto is its own device. Same with the 431 current shunt on the secondary - it does have more than "a few" transistors inside, but I count it as a separate device.
          That's true.
          But then you may be inconvenienced to a blown primary side... unless the PSU somehow has SC protection latching (maybe that 3rd transistor??)
          Yeah, it's possible. I've seen 2-transistor designs done with a larger metal film cap instead of an electrolytic for the startup / pri. side aux. filtering function.
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • jayjr1105
            9v super basic wall wart issue
            by jayjr1105
            This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output....
            03-03-2022, 08:32 AM
          • nev1001
            What zener diode might fix the sound on Maestro Mayhem gaming chair?
            by nev1001
            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
            I think an issue could be a zener diode (or capacitor) which has shorted out.
            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
            04-17-2025, 05:09 PM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
