Macron Power MPT-350P 350W
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i was happy to get a look at one of these today because it is one of the PSUs deemed by the Finland Safety Technology Authority as "unsafe", "potentially hazardous, but not immediately dangerous".
    PSU is bland looking but anyway budget.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Macron Power MPT-350P 350W
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      doesnt look too bad for a 350w
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Fuhjyyu 1000uf is generous but marks lost for Fuhjyyu which has had unreasonable failures recently.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                caps : GL, Pce-Tur, Fuhjyyu
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  looks just like that hec you posted.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      ah thanks. this was in a case which cost case+psu less than the HEC. they must have a book of reference designs. Macron is another OEM company. caps are more shitty here though. yeh the HEC was dissapointing. the macron looks like a good one for a recap.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        what is an output rectifier?
                        • Rainbow
                          • Aug 2005
                          • 1371
                          The DTK here https://www.badcaps.net/forum/showthread.php?t=1069 is Macron OEM. These should be good PSUs.
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            heh i remember DTK PCs my clients had a few, guess they went up your way as well. yeh it looks good for recapping and future service.
                            • linuxguru
                              • Apr 2005
                              • 1564
                              It's well-made - should be good for ~300W after a recap of the secondary and aux supply.
                              • Newbie2
                                • Sep 2005
                                • 885
                                That thing looks good except the caps, which are made by the badcap manufacturers. Looks good for 300W+. A recap with good high-quality caps and it should be fine.
                                Much better than the usual junk L&C stuff we see here.
                                My gaming PC:
                                AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                ASUS M4A77TD AMD 770 AM3 Motherboard
                                PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                ASUS Xonar DG 5.1 Channel PCI sound card
                                Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                Antec Three Hundred Mid-Tower Case
                                Microsoft Windows 10 Pro 64-bit
                                Microsoft Windows 7 Ultimate SP1 64-bit
                                • PeteS in CA
                                  • Aug 2005
                                  • 3579
                                  • USA, Unsure of Planet
                                  Several of the O/P side pics show TO-220 and TO-247 devices attached to the heatsink. Those are the O/P rectifiers.
                                  The heatsinks look good for 300W-350W. Why did the Finnish safety agency call it unsafe? I didn't see any of the easy-to-spot safety standards violations. Wire too small? Transformer pri-sec problems?
                                  PeteS in CA
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    one of the things i spot crap psu with is wiring too light to trip short protection.saw one a while back with 28ga.
                                    a good one i have here has 16.
                                    a good supply should shut down if any one wire is shorted.guess what happens if the wiring is too light?
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3579
                                      AWG #28? Are you sure it was't AWG #20, which would still be too light? 10A-30A through Awg #20 or #28 would be a wire-stripper--bad-smell-generator and either an incandescent light or a slow blowing fuse.
                                      PeteS in CA
                                      • Newbie2
                                        • Sep 2005
                                        • 885
                                        Why did those Finnish guys say this is not safe for use?
                                        Its caps?
                                        My gaming PC:
