200W is not the same as 200W
Re: 200W is not the same as 200W
The first one is about 90W-150W max. (since the primary caps are 330uF, I'll concede that it may be at the high end of the range), while the second is real (possibly even under-rated). The general thumb rule that I use is that if there are two fair-sized toroids on the secondary and a few large caps (>=2200uF), it's probably correctly rated. If there's only one toroid and small capacitors (1000uF or lower), it's a fake rating. This crap started with the 200W AT PSUs.Comment
The first one reminds me of an old generic 250W ATX power supply I used to have in my secondary system. The board, two cheap heatsinks, and weak 80MM cooling fan were the same. The only thing that was different was that it had CapXon caps. That thing I used to have is now dead.
My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bitComment
My generic ‘300W' that I'm running this sys on is between the two. I'm kicking myself for getting rid of an ancient AT 250W DTK P/S because I could have used it for fan testing.Comment
This is the same crap as the first one except it's marked 230W. The failure is the same too. I don't repair crap like this - it's a good source of "C945" TO92 transistors (at least 8 in each) for other PSU repairs - they're used a lot by various PSU manufacturers.
I remember that I found real manufacturer of these PSUs some time ago - and this type was marked as 160W or something like that - but I'm unable to find it again now.Comment
This topic shows that this deceptive practice (the thread topic is self-explanatory) is apparantely rife.
Any cases on suppliers being caught in this deceptive practice?My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
That thing has Jun Fu caps instead of HEC caps. But, both of them are crappy. I have the same crap in my basement too but it uses CapXon caps and is on the sticker says it's rated for 250W. When it was still alive I put it in an old ATX system that used a very old Pentium 133 processor and it made a loud high-pitched sound that I can't describe some more and the system always restarted and froze. I took that thing out and put in an old Delta 145W ATX PSU and then it worked perfectly. That tells me those things are total crap.Originally posted by RainbowThis is the same crap as the first one except it's marked 230W. The failure is the same too. I don't repair crap like this - it's a good source of "C945" TO92 transistors (at least 8 in each) for other PSU repairs - they're used a lot by various PSU manufacturers.
I remember that I found real manufacturer of these PSUs some time ago - and this type was marked as 160W or something like that - but I'm unable to find it again now.Last edited by Newbie2; 11-22-2005, 02:01 PM.My gaming PC:
A search for power supplies with misleading ratings revealed the practices in the below links are rife.
http://www.tomshardware.com/howto/20021021/
http://www.pcpowercooling.com/technology/myths/ (at 50C, a so-called "500W" unit's output was halved).
The message: Only buy from manufacturers who make units with reliable output ratings.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Whats the relationship between cap size and power rating? I have a dead ps from PowMax that is rated for 400W. It has 2 330uF/200v on primary side and 2 bulging 2200uF/10v on secondary. All caps are JEE. Luckily, looks like the only thing that poofed was the fuse. Did the bad caps cause the fuse to blow, or too much power usage for crappy ps?Comment
if the fuse blew the choppers are shorted.Originally posted by Spacedye69Whats the relationship between cap size and power rating? I have a dead ps from PowMax that is rated for 400W. It has 2 330uF/200v on primary side and 2 bulging 2200uF/10v on secondary. All caps are JEE. Luckily, looks like the only thing that poofed was the fuse. Did the bad caps cause the fuse to blow, or too much power usage for crappy ps?
powmax is pure crap.aptly named as i see lots of em go pow.
dont waste your time.
these things are worse than junk.
they have no short protection.combine that with the undersized wiring and a short on say +5 you get fire!Comment
Thanks for advice, will toss it in (s)crap pile. What about sizing of caps. Make any difference on output of ps?Comment
2x 330uF is used on cheap 200W PSUs - like the one in the first post. The higher power rating, the bigger capacitance should be used. For example, 300W DTK PTP-3007 (the same type as the 200W one in the second post but higher rating) has two 680uF caps on the primary side...Comment
Re I/P lytics, the output from the bridge rectifier, if unfiltered, would look like an endless line of bactrian camels. The lytics filter this by storing energy during the peaks of the voltage humps and supplying some of that stored energy to the load between the peaks. Thus, the voltage waveform is a sawtooth AC voltage superimposed on a DC level. The amplitude of the sawtooth voltage is determined by the size of the lytic caps and the amount of energy drawn from them between peaks of the power line AC voltage. If the I/P lytics are too small, the voltage to the inverter may be low enough that the PWM cannot fully compensate for the 120Hz (100Hz) ripple - resulting in an elevated 120Hz (100Hz) component in the O/P ripple - or in a brief AC line drop-out, the O/P voltages could briefly drop out of regulation.
On a tangent, the AC I/P current to the circuit described above is basically peaks of high current at the AC voltage peaks, with flatline between the current peaks. When you have lots of computers in a building, those current peaks can clip the AC voltage waveform and also cause high currents in the AC Neutral wire (ideally, if the load on the three phases is balanced, the current in the Neutral wire should be approximately zero), potentially exceeding the capacity of the wire. Power factor correction, passive (large heavy 50Hz/60Hz inductor) or active, is intended to diminish or almost eliminate these problems.PeteS in CA
****************************Comment
WOW! That answers some questions, yet creates so may more! In a few months I will be enrolling in Electronics w/ Computer Hardware emphasis. Then maybe I will be able to understand the other half of what you said. Thanks.Comment
Pete, I do have questions about the load balancing you mentioned, but more in a home environment.
This is off topic but If I've added a substantialy heavy draw to my breaker panel do I understand I may have high current on the nuetral buss?
Don't let out that I wired my own hot tub.JimComment
Is it powered from 110 or 220? If 220, the load will be automatically balanced between the two phases. The problem comes if you load one of the two phases coming into the house more than the other, since the neutral is shared between the two.Comment
This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:44 PM
This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 03:36 PM
This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-12-2024, 03:28 PM
- Loading...
- No more items.
