Lincoln Electric LE31MP welder not turning on
  • tibimakai
    • Jan 2012
    • 3680
    This is my own welder, that blew up while welding. There is no warranty on it. Purchased it a year ago, sealed box from Craigslist.
    It worked great until now, about a year.
    What I have found is a blown trace next to the main capacitors, it seems like also got damaged the SMPS IC, output MOSFET and a 1 Ohm resistor to the ground from the MOSFET.
    After replacing these components, the relay, fans turn on and it sounds like it's working, but there is no output voltage for the welder, LEDs do not turn on.
    So there are more components that are damaged.
    I'm having a hard time taking measurements, since there are quite a few transformers and I'm not sure from where to get ground at each stage.
    I have never repaired a welder before, only TV/receivers/laptops, etc.
    It seems like the low power supply is working, but nothing after that. Or maybe I still have some bad components in the low power supply.
    The three capacitors next to the blown MOSFET show there value, did not check ESR though.
    Fast diodes on the heatsinks, and IGBTs are not shorted.
    I can't find a service manual either.
    Any help would be appreciated very much.
    Tibor
  • CapLeaker
    Leaking Member
    • 8193
    Re: Lincoln Electric LE31MP welder not turning on
    I can tell you this much that everything is o.k. including the main filter caps. This looks more complicated than one of these Chinese cheap welders. However I'd say they are similar if you compare them. This gives you a little idea on how this thing works.
    https://danyk.cz/svar.png
    https://www.badcaps.net/forum/showth...ghlight=welder
    https://www.youtube.com/watch?v=Mf_dD-Sh1n4&t=10s
    https://www.youtube.com/watch?v=MAg7...CYzYYkTtt9dQ0Q
    here is a plasma cutter that I had repaired:
    https://www.badcaps.net/forum/showth...ghlight=lgk+60
    You can read up on these. There are pretty good clues and misleads (so close and yet so far) in there why something wont work. As for now, I got no clue myself on your unit like this. Could be various reasons and one by one this inverter welder has to be checked for certain things.
    Good luck on reading up on all this!
    • tibimakai
      • Jan 2012
      • 3680
      Thanks for all those links, I will have to read those.
      I have also found this guy on Youtube, that ahs very nice videos about fixing the cheaper welding machines, but the basics should be the same:
      https://www.youtube.com/watch?v=_3D3Enk9ZLs
      This is only one video, but he explains separately each module.
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        d208 dont look happy
        • tibimakai
          • Jan 2012
          • 3680
          I have seen a few this way. It is not from manufacturing?
          I will check it out again, I think that I have checked it out already and it seemed good.
          To me, it seems like I'm not getting the voltage across the transformer. Maybe missing oscillation?
            • 31063
            does the relay bypass the inrush NTC's?
            if it does - is it working?
            • tibimakai
              • Jan 2012
              • 3680
              Yes and yes. I have 14V there for the coil.
              I believe that is all that is working right now, and powering the three fans also.
              I'm not getting the other low voltages, that are powering the "display"(LEDs) and most likely other important sections.
              • tibimakai
                • Jan 2012
                • 3680
                That diode looks good, it shows 0.7V.
                I have found a component(C005) that seems like it was blown off.
                It could have been a capacitor there?
                U201 next to the black heatsink, is a UN3843BN switching controller.
                By the way, the IC that I have changed, is a UN3842BN it's a DC-DC controller.
                https://www.digikey.com/en/products/...3842BNG/920377
                • tibimakai
                  • Jan 2012
                  • 3680
                  Added more info.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Added more info.
                    • CapLeaker
                      Leaking Member
                      • 8193
                      That blown trace… one side is rectified mains and where does the other side connect to?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Here are some pictures to explain where it goes.
                        I'm not in front of the board, so I'm using the pictures and I'm assuming that it goes to the transformer and the other end to that capacitor, goes through a via. Most likely I should replace that, right?
                        • CapLeaker
                          Leaking Member
                          • 8193
                          Something drew a tremendous current to blow up the trace. I just wanna see what else is on this trace that may be open, the via o.k. etc. kind of odd where the trace blew. On the bottom of that trace are 3 resistors in a row. Are those o.k.? Is there something wrong with the X2 cap above the relay?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            That capacitor is installed in a way that I can't read the value but it measures 2.22mF, the gray one behind it is a 2.22uF and measures 2.22uF, the other big yellow is 470nF and it measures 2uF-that one is weird.
                            The three resistors are ok 3x56k. They are going to the pin #7 of the IC, that I have replaced. That same line goes to C007(right lower corner of the IC.
                            Please check the pictures.
                            Eventually it ends up at the octo at the bottom of the board, after going through the big(220uF) cap.
                            Another thing that I have measured that seems a bit off, is one of the big diodes at the bottom D204, one way measures 0.4V and the other way 0.8V. Maybe it is leaky?
                            The D202(same diode-ER20) measures 0.4V and the other way is 2.2V.
                            I did not have time to remove and measure properly.
                            • CapLeaker
                              Leaking Member
                              • 8193
                              any component that does look fishy, take it our or lift a leg and measure again. Then we can look further.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have removed both diodes and the 470nF capacitor, and they are OK.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  There is another SMPS PWM power supply next to the one that I have repaired, that is not powering up.
                                  I have measured 0V at each IC pin(UC3843).
                                  Needs more time to figure out from where it's getting power, in the weekend I will trace it out.
                                  There is a resistor that is getting quite hot(~86C).
                                  • CapLeaker
                                    Leaking Member
                                    • 8193
                                    Lucky U! If it’s gets that hot, there is a short. You should have fairly good going then.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I'm checking with the thermal. I may have to pay more attention to that area, maybe there is another part that is hot, but because this resistor creates so much heat signature, maybe I can't "see" with the Flir the offending part.
                                      • CapLeaker
                                        Leaking Member
                                        • 8193
                                        Use 99% IPA.
                                        • fuzzy4
                                          Swan SP0110N electric tin opener, not turning can.
                                          by fuzzy4
                                          I have this electric tin opener and the part that moves the can round (1st picture), doesn't move, I can hear the motor turning, but no movement, there's something rattling inside, so presume a piece of plastic has broken, or come loose.
                                          Took the bottom plate off, but left with this (3rd picture), any ideas how to get inside?
                                          Thanks....
                                          07-13-2025, 10:47 AM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • spleenharvester
                                          Reverse engineering of DoCreate DHJ567 handheld spot welder
                                          by spleenharvester
                                          Hello everyone
                                          I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                          Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                          05-08-2025, 02:52 PM
                                        • Olles4
                                          Welder not turning on - Learning
                                          by Olles4
                                          Hello people. I trying to repair my welding machine oerlikon citomig 180mp hpf and there is a little board with blown stuff.The problem is i cant identify the value of the blown resistor and diode. Any suggestion?
                                          05-18-2024, 01:22 PM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
