The Big Fat ESR Table
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    If it is one cap-related thing bothering me atm, it's the lack of a big table that you can go look in and find the nominal ESR of any cap you might stumble upon. So let's make one.
    I'll handle Fuhjyyu, Jamicon and some other obscure companies, maybe someone else can do reputable brands like Nichicon, Panasonic or Chemi-Con. Sure, the good companies have good datasheets as well, but i'd still like a table. So, who's in?
    A working TV? How boring!
    • 31051
    Re: The Big Fat ESR Table
    do you have any idea how big that will get!
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      I get an idea of the size even though i've just barely started it. I started with a crap series from Fuhjyyu that i've never seen before just to get the hang of it, but now i'm just going to start documenting all the caps i have and ignore the others. If everyone adds in the series of caps that they have seen, this will become a great resource.
      There's also goodies such as an ESR calculator from tan delta and frequency, and i'll be making a ripple current calculator based on voltage, ESR and max temperature.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Anyone willing to contribute please post here and they will receive the table to add to it.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I looked at doing such a project a few years ago.
          There are over a thousand capacitor companies [current and gone] and any one of them could have popped out a low ESR series cap at one time or another.
          There are also quite a number that do make low ESR caps but that don't publish any data sheets.
          Such a database would certainly be useful but it will never be complete [or finished].
          Mann-Made Global Warming.
          - Dr Seuss
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Well if everyone measures the caps they come across, that won't matter.
            I agree we aren't going to finish it ourselves but we gotta START somewhere don't you think? If no one wants it i'll simply keep it for personal reference. Will save me from looking for the same datasheets over and over again.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Can't go by measurements except on new caps because the values change as they age.
              Even unused old stock caps drift off their nominal values.
              I 'started somewhere' on that 3 or 4 years ago but I consider what I came up with as copyrighted material [because it is] which is why I don't post it here.
              - Dr Seuss
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                we have rough series equivilants but tracking every oddball maker and series would be insane.some of us have the experience to look at a unit and pick a brand/series even if the caps were already removed.
                a link to show what you are up against.
                http://capacitor.web.fc2.com/
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  I know that site but it tells me nothing about the actual parameters of the caps.
                  Boards don't run with datasheet values, they run with REAL caps with their slew of REAL problems. Don't see why REAL measurements would be a problem. Well, i'll still be testing my caps and using the data for my own reference.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Because, as I said before, you are measuring used and degraded parts.
                    - Dr Seuss
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Everything runs on "used and degraded parts" as soon as they leave the factory. Therefore this is a moot point.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        I understand what you would like to do [faster reference] but that isn't the way to go about it.
                        - Caps in different can sizes don't give a valid comparison between their respective -series- even if the uF is the same. So, you would not only have to have a cap from every series you would need caps in the exact same can size from every series -and- you'd need at least one 8mm and one 10mm example [exact same can size one-each in both diameters] from every series because 8mm & 10mm specs don't follow each other locked-step when comparing same to another series.
                        You are far better off creating a data sheet library on your local PC as a reference tool.
                        - A secondary reason for that is if brand goes away or a series becomes obsolete it's data sheets usually go away too.
                        For example Rubycon has been trying to phase out MBZ for a couple of years and in the 2011 catalog MBZ isn't even mentioned.
                        You have to go here to find the MBZ data sheet now.
                        [Note the -old- in the URL]
                        Interestingly MBZ and MCZ were combined into 1 data sheet in the 2010 catalog.
                        [Which was really just the MCZ data sheet with both MBZ and MCZ written up top.]
                        That data sheet went *poof* and MCZ is not included in their 2011 product list.
                        I can't find a -current- link to the MCZ data sheet at Rubycon at all.
                        - Which suggests they may be dropping MCZ soon as well.
                        LOT of things going on in the cap industry.
                        - Sanyo sold their lytics interests/production to the subsidiary that was actually making them which is now an independent company. [Suncon.]
                        - Fujitsu sold their FPCAP interests/production to Nichicon.
                        - LTEC opened a plant in the USA. [WTF is up with that? - I think it was LTEC, one of the crap brands anyway..]
                        Probably 100's of similar things going on in the crap cap brands that one never hears about...
                        Right now your time would be better spent building a reference library by being a mad-man data sheet collector.
                        - Get them while they are still there!
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          No, it's not a moot point.
                          Only a clueless wonder would say that and actually believe it and I don't think you are clueless.
                          Caps that just left the factory are going to be within their advertised specs.
                          You will have NO IDEA -NONE- if used caps or caps past their shelf life are even close to their advertised specs -> unless you have the data sheet to check you readings against.
                          Your choices are:
                          - generate random data with no validation and no level of confidence.
                          - use data sheets.
                          Your chart will mean NOTHING without data sheet validation.
                          Since you have to have data sheets for validation anyway why don't you make the damned chart from data sheets in the first place?
                          Trust me, there are enough data sheets available [I have over 1000 on file now] to make just that a HUGE job.
                          - Dr Seuss
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Um, that's what i've been doing. Duh! But when i can't find datasheets, i have to improvise.
                            • Nagy Daniel
                              Lowest possible resistance on laptop motherboard rail - Guide Table request
                              by Nagy Daniel
                              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                              So, I generated a table with AI so I can...
                              03-04-2025, 08:24 AM
                            • TimSinger
                              MacBook Pro M4 16" A3403 on the table with water damage
                              by TimSinger
                              Hi guys,
                              I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
                              I attached a photo of the missing cap. It's on the bottom side of the logicbard.
                              I am very thankful for your replys.
                              Thanks in advanced and best regards from Hamburg Germany...
                              07-13-2025, 11:12 AM
                            • keldeo
                              Obscure Pentium laptop, sudden short?
                              by keldeo
                              I've purchased this weird (and might add appears to have had a fairly rough life) laptop a while ago for $1 at a yard sale. It powered up one time, (saw a POST screen!) Then, never powered again. I've since thrown it in some dark corner, BUT, I've decided to look at it again. First, this seems like a very obscure laptop, mine just has the name "BIT" on it and nothing else. Very similar (same?) can be seen here https://www.vogons.org/viewtopic.php?t=54655.
                              At first, I had gotten the weird mini display on the lower part of the laptop to display a few icons, but if I attempted...
                              01-02-2025, 03:22 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • gjgib
                              ASUS Zenbook UX334FAC (UX334FL REV2.0) - No Display. Fell off the table.
                              by gjgib
                              Hi again!
                              -Laptop fell from the table.
                              -Motherboard -seems- intact.
                              -It turns on kinda normal but NO DISPLAY, NO BACKLIGHT.
                              I'm not too familiar with ASUS laptops yet. I'm using a similar laptop model Boardview. (UX333FN REV2.0)
                              I feel there might be something wrong with these coil impedance values yet the voltage values go normal.
                              COIL = VOLTAGES (adapter powered) = IMPEDANCE TO GND (off and unplugged)
                              +VCCSA = 1.0V = 22ohm
                              +VCCCORE1 = 0.8V = 3.5ohm
                              +VCCCORE2 = 0.8V = 3.5ohm
                              +1.05VSUS = 1.05V...
                              06-26-2024, 11:44 AM
