Amacrox AX650-GLN Free Earth
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    A very good friend has trouble with his desktop.
    When he presses the button the fans spin but it never boots.
    I checked the voltages with a multimeter and found they were continuously fluctuating, so I tried another power supply and then his computer booted normally.
    The faulty psu is an Amacrox AX650-GLN and the OEM is FSP.
    After I opened it I found 2 bulging capacitors. Here is the capacitor list of the power supply and some photos:
    Capacitor List
    1x470uF 420V Capxon
    1x22uF 50V Teapo
    1x2.2uF 50V Teapo?
    1x100uF 25V Capxon BULGED
    1x47uF 25V Teapo
    5vsb:
    2x2200uF 6.3V Capxon 1 BULGED
    -12V:
    1x1x1000uF 16V Capxon
    3.3V:
    5v:
    2x1000uF 16V Capxon
    12V:
    2X2200uF 16V OST
    1X16V Capxon
    Is that a good psu? Is it able to do 650Watt without ripple going out of specs?
    Do you think the voltage fluctuation is related to the bulging caps?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Amacrox AX650-GLN Free Earth
    Btw what is this thing?
    The last capacitor in my list is placed in there.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Fsp is decent (not great) but they use crap caps. Replace all the capxons and blow it out well with an air compressor. Then it will be a good psu.
      And yes the caps are casuing the voltage fluctuations
      • c_hegge
        • Sep 2009
        • 5219
        Look at that tiny primary heatsink. LOL
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Yeah i always wonderabout faps use of ti yheatsinks but anyway mydead ocz stealthxstream is based of that same design
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Edit: i meant fsps use of tiny heatsinks.
            • japlytic
              • Oct 2005
              • 2086
              Heatsinks appear to be undersized for this wattage, and CapXon and OST electrolytics are known bad units.
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Ok! Someone agreeS that sometimes fsp uses inadequate heatsinks and shit caps! Yay!
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  FSP and Sirtec/Highpower are really good at using undersized heatsinks.
                    • 31046
                    that last cap is obviously on a small circuit board when you replace it you should replace the heatshrink sleeve - it may be used as a heat shield.
                    i'v seen fsp put that over caps a few times.
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Is it reall bad to make the heatsinks so small?
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Yes because less surface area means that the fan has to rev like a jet engine to prevent the silicone overheating.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Is it nice silicone? Lol jk. Yeah thats what i was thiking. But for tue ridiculous price of some of their products, theu should be better
                          Ps: i opened my nearly new fsp atx-300pa it has capxon primaries and a mixture of ost and teapo everywhere else. At least there are no fukyuus
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            Originally posted by goodpsusearch
                            3.3V:
                            5v:
                            2x1000uF 16V Capxon
                            12V:
                            2X2200uF 16V OST
                            Am I the only one who finds these filter caps a little undersized for a 650W psu?
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              No
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Fsp psus ar egetting junkier by the hour. They have undersized heatsinks, crap caps, low capacitance crap caps, and are overpirced. The moral of the story: dont buy them.
                                Ps: my dead ocz stealthxstream looks pretty much exactly the same inside
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  I did a partial recap on that psu:
                                  1x100uF 25V Capxon bulging -> 1x100uF 25V Rubycon YXF
                                  1x2200uF 6.3V Capxon (5vsb) -> 1x1500uF 6.3V Nippon Chemicon KZE (removed from a dead mobo)
                                  My friend wanted to spend no money for that psu to be repaired, so I replaced only the bad caps and used stock caps as replacements.
                                  Voltages after recap:
                                  5vsb: 5.12V stable
                                  -12V: -12.37V - -12.40V
                                  3.3V: 3.36V stable
                                  5V: 5.08V stable
                                  12V: 12.42V - 12.44V
                                  pc config: Athlon 64 X2 5600+, 2x1GB DDR2 667MHZ, MSI K9N Diamond, MSI 8600 GTS, 2x320GB Seagate Sata 7200 HDD, 2xOptiarc DVD-RW, 5xcase fans with leds.
                                  The psu fan is blowing a lot of air outside the power supply. Definitely not a silent psu.
                                  • ipo3nk
                                    • Mar 2011
                                    • 16
                                    i have the same psu from FSP, 60GLN series
                                    but i replace the 100uF/25v with NCC KZE 100uF/35v or NCC KY100uF/25v
                                    and the 2200uF with panasonic FC 2200/6.3v
                                    thats the only caps that i can get in my country
                                    • Rulycat
                                      • Apr 2010
                                      • 724
                                      • United Kingdom
                                      Doesn't Topcat ship to your country?
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Isn't he supposed to add his country info in his profile?
                                        A working TV? How boring!
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • iMic
                                          IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                          by iMic
                                          Hi folks,
                                          I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                          The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                          11-29-2023, 06:44 AM
                                        • petehall347
                                          anyone recommend an earth leakage clamp meter ?
                                          by petehall347
                                          have been looking at earth leakage clamp meters and its like a minefield out there . i wondered if anyone here had bought one that actually works properly ?...
                                          04-17-2024, 01:31 PM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • Dannyx
                                          Connecting Neutral/Earth together
                                          by Dannyx
                                          Good day folks. Recently my company has, in a kinda-sorta-way, nominated me to join the "security systems team" which involves going to various sites to install alarm systems and CCTV cameras...not the best of positions, since I've gravitated pretty far away from my beloved laptop and electronics repair, but at least the pay is adequate (enough....for now) and I'll definitely be moving back to those once my boss decides it's the right time, but I digress.
                                          The reason I'm asking about how mains grounding works is because more often than not, I have to connect up the alarm...
                                          08-22-2019, 12:23 PM
