Connecting an isolation to mains earth
  • Nevillet
    • Sep 2019
    • 272
    Hi All,
    I have acquired a hefty isolation transformer for use on(under) the bench and have a question about earth bonding.
    Apart from the live & neutral connections, should the transformer itself be connected to mains earth?
    If so, should the device under test, powered by the IT also be connected to the transformer earth?
    Many thanks in advance.
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: Connecting an isolation to mains earth
    Originally posted by Nevillet
    Apart from the live & neutral connections, should the transformer itself be connected to mains earth? If so, should the device under test, powered by the IT also be connected to the transformer earth? Many thanks in advance.
    What exactly you will connect to mains earth?
    Secondary winding?
    The core of the transformer?
    The secondary of an insulation transformer must not be connected in any way to mains, because having galvanic connection defeats the whole effect of having insulation transformer in a first place. What makes one conductor Phase and one Neutral in the Mains socket is the fact, that the middle lead of the transformer is connected to Earth in the substation. There is no neutral until the last stage of power transmission. And this is why you can be electrocuted in a first place. Because you can close the connection between Phase/Line and ground anywhere. Because Neutral is usually connected to ground, unless you deal with system with insulated neutral, where it is not connected to the ground.
    Most power distribution systems use grounded neutral.
    Also, all the equipment that is connected together via interface cables must be connected to the insulation transformer. You cant plug your PC after it and then connect your monitor to the mains, instead to the transformer. This will potentially lead to undesired connection of the secondary winding to the mains and equalization of potentials, which has the power to burn and damage stuff.
    If you connect two devises on different mains sockets, that are on different phases, again the equalization of potentials of potentials can burn something. Or if one of the devices has poor ground connection, it will equalize its potential via the one that has good ground connection, via the ground of the interface cables and again this can burn something.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • Nevillet
      • Sep 2019
      • 272
      Many thanks,
      The transformer looks like a 'normal' transformer with 2 wires into the primary & 2 wires out of the secondary.
      The laminated former is bolted together and I can easily connect it to the supply earth so if a fault develops in the primary winding and it touches the earthed chassis of the transformer it will trip the RCD/GFI.
      I will not connect the earthed transformer to the earth of the device under test.
      I see that connecting the device under test to the earth is in effect connecting it to the neutral line.
      Have I interpreted this correctly?
        You can connect the transformer body to safety ground incase the primary winding is shorted to transformer core, the output winding wires will NOT be connected to any thing but the load so the output will not be reference to safety ground, the ground terminal of the outlet can be connected to safety ground.
        That is what we use in our lab and in my test bench.
        • madan1
          Connecting a transformer
          by madan1
          Good day.
          Just a quick question - I have the following toroidal transformer:
          PRI: 2x 0-115 Blue-Grey Violet-black
          SEC: 12v Red-Black
          SEC: 12v Yellow-Orange
          How should I wire it to get 230 on Primary and 24-0-24 on SEC if it is even possible?
          Will 220 to single PRI winding and then Red-black_yellow-Orange do the work, or probably 220 on both PRI in parallel?
          Both SEC are rated to 6.7A, so I guess if I you double the V on PRI, the rated amperage should be divided by 2?
          Also, does it matter which ends of the wirings of the SEC are used...
          03-07-2025, 09:57 AM
        • repair-it
          Need advice testing a samsung power supply board with scope
          by repair-it
          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
          07-12-2025, 11:00 AM
        • harp
          isolation transformer from two 240/12, wiring?
          by harp
          When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
          So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
          11-25-2022, 05:11 PM
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
