Boston Acoustics Soudware Subwoofer PowerSupply
  • jinu_j
    • Feb 2016
    • 90
    • India
    Hi Folks
    I am looking for help to trouble shoot my Boston Acoustics Soundware X subwoofer power PCB. The Circuit diagram is attached. I have checked the voltage across C3 (there is no capacitor as this is 240V board). The voltage i get is about 318V so i am assuming that the circuit behind that is working properly. But now I am not sure how to proceed. The circuit on the Left-hand side of the circuit is on a separate PCB that's soldered onto the board using the connector CN4 shown in the circuit diagram. So its difficult to trouble shoot components on that.
    There are severe burn marks around the zener ZD3. The voltage across the ZD3 is 0.364V, also the capacitor on the mounted PCB looks blown but not sure if its blown or just the glue that changed color. What i am not sure is how to test the circuit post C3 point. There are so many grounds and I cant figure out how the circuit works. Also i cant figure out which ground to use for measuring. It does not look like all the grounds are the same (GND-P, PGND, SGND). Is my assumption correct that the PGND and GND-P is power Ground, where as SGND would be signal ground ?
    Any help in troubleshooting the same would help. My concern is that is the zener and capacitor blown because of some other fault in the circuit or am i looking in the wrong place.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Boston Acoustics Soudware Subwoofer PowerSupply
    It probably died because of the glue: it becomes conductive with age.
    Follow the black burn marks to see how the current traveled to get an idea what got destroyed...
    • jinu_j
      • Feb 2016
      • 90
      • India
      Thats the surprising part, No other components is showing any burn marks. I think the zener got overheated and the glue around it burnt.
      • R_J
        • 9535
        Have you checked if ZD3 is shorted? Check D1 and R7, they supply the initial pvcc for Q2 which is acting as a 15v regulator to supply vcc for U1.
        I suspect either ZD3,c13,c14 are shorted or R7 is open
        PGND = Primary ground
        SGND = Secondary ground
        You must use Primary ground when checking voltages on the primary side such as pvcc
        • jinu_j
          • Feb 2016
          • 90
          • India
          Zd3 broke into half when i desoldered it. So guess thats damaged. The other components D1, R7,C13, C14 and R7 are fine.
          Now await the replacement of ZD3 before i can continue testing.
          • jinu_j
            • Feb 2016
            • 90
            • India
            So finally got the parts. i replaced the Zener ZD3 and C13. Voltage at CN2 is still 0. But i am getting +20V and -20V at CN3
            Voltage across C3 is 315V
            Voltage across ZD3 is 19V
            Voltage at HO is 167V
            Voltage at LO is 6V
            Voltage at VS is 157V
            Voltage at CN2 :
            pin 1 = 0V
            pin 2= -20V
            pin 3 = Grnd
            pin 4 = +20V
            Any advice on how to trouble shoot this further. Thanks
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              What DC voltage do you get when you measure right across C8 and C16?
              I'd find it strange to get 0V there, since +VH1 and -VH1 are coming from the same transformer as +V1 and -V1, which are probably OK, being that they are +20 and -20V respectively.
              • jinu_j
                • Feb 2016
                • 90
                • India
                Finally solved the mystery. It was dry solder on D2. Now getting 32V on CN2
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Good job!
                  It had to be something simple indeed. Just didn't seem reasonable to have proper voltages at CN3 and none at CN2, but all components be OK.
                  Curious: with the PSU taken care of now, did this get the subwoofer fixed?
                  • jinu_j
                    • Feb 2016
                    • 90
                    • India
                    Originally posted by momaka
                    Good job!
                    Yes and No. By doing the subwoofer has started working meaning i can feel the vibrations in the woofer and the vibrations increase and decrease as i lower and increase the volume button in the subwoofer, but the output even at max is very much lower that what it was originally. Earlier in songs with heavy bass i could feel the punch but now its barely there.
                    This is the second time the power board has blown, the first time i took it to a reputed service center and they repaired it. I assumed they had done a good job. This was over 2 years ago. It is now when i opened it for repair that i realized that they replaced the original burnt board with a refurbished Power supply board from another model. My original board was model Boston Acoustics Soundware S. They have replaced with the power board of Boston Acoustics Soundware XS. One difference i noticed was in my original board the connector CN3 is a 3-pin connector whereas in the new board it is a 4-pin connector. So, the pin 1 is not connected to anything in my current setup. I don't know if this is creating the difference.
                    But for now, technically the subwoofer lives, but does not perform the way it should. I dont think i have the capability or equipment to debug audio signals and their amplifications.
                      • 31017
                      check the psu output while playing some regae or other bass oriented stuff
                      i have found with some harmon-cardon crap that the psu can only just supply enough current and as the caps wear the current is restricted and causes the voltage to drop whenever the speaker tries to thump.
                      • jinu_j
                        • Feb 2016
                        • 90
                        • India
                        Can you advice on what and where to check. Are you referring to the voltage at CN3 and CN2 ?
                        • jinu_j
                          • Feb 2016
                          • 90
                          • India
                          Just measured voltages at CN3 and CN2. There is no material drop in voltage when heavy bass is played. The voltage hovers around 19.7 (CN3) and 31.8 (CN4)
                          • jinu_j
                            • Feb 2016
                            • 90
                            • India
                            Reviving an old thread. I just could not solve the problem of low output on my Sub in spite of keeping gain at max i can barely feel/hear the sub. Just could not crack this problem.
                            Finally, i think i figured out what was wrong. My speaker set model is the Boston Acoustic Soundware S. The subwoofer included in this package is a 10-inch downward firing 200W RMS (Peak power of 300W) sub. Many years back this subwoofer had failed (power supply board had burnt out) and I had taken it to a authorized service center for repair. Sure, enough they did repair it and i thought it was fine. What i did not realize was that they had replaced the power supply board of my sub with one from Boston Acoustic Soundware XS model. The XS series has a 100W RMS sub. So i am guessing the low output on my current sub is because of the under-capacity Power supply board. Would this assumption be correct?
                            There are two outputs from the power supply board one for preamp and one for driver. Power for preamp gives 20V and power for Driver gives 34 Volts. I would like to replace this power supply board with a beefier one in line with the original spec, but I don't have the original board, nor can i find the service manual for the Boston Acoustic Soundware S.
                            1. So does anyone have the service manual or schematic of the Boston Acoustic Soundware S.
                            2. Does anyone know what voltage should be given to the driver in the Boston Acoustic Soundware S Sub. I have to assume it is about 45V. I am assuming this because if i look at the driver Amp board the capacitor right next to the power input is rated at 63V. So I am assuming that the rated DC Input would be 45-50V.
                            Any advice would be appreciated. Thanks
                            • jinu_j
                              • Feb 2016
                              • 90
                              • India
                              HI folks any advice would be appreciated. Just let me know if my theory of the lower power board (100W Power board being used instead of 200W Power board) causing the issue of low output from sub, holds water ??.
                                • Jul 2011
                                • 6039
                                It might if the switching power supply is is shutting down momentarily from being over current situation but I would think if that were the case you would have moments of silence which it does not seem like that is case because you did not mention that in your description of the issue that you are having with it
                                • jinu_j
                                  • Feb 2016
                                  • 90
                                  • India
                                  You are right, there is no period of silence or cutoff. Another suggestion received was to replace all caps on the SMPS board as one or more of the caps could be causing a current limitation leading to low volume.
                                  • staze
                                    Old Boston Acoustics subwoofer repair, BJT alternatives
                                    by staze
                                    Working on an older Boston Acoustics HPS10SE, and while verifying voltages, I noticed one of the PSU BJTs is getting excessively hot and the voltage is dropping out on the 15V rail. Not sure that's actually an issue (I don't have everything plugged in, so maybe something is saturating on the positive end and dragging that rail down and the BJT overheating is cutting out).
                                    But, figure I need to buy some NP capacitors from mouser anyway, so might as well replace these. They're a H669A and H649A. Pretty "meh". They test fine out of circuit, but I can't really put a load on...
                                    06-11-2024, 09:57 AM
                                  • Alimash
                                    op amp circuit function?
                                    by Alimash
                                    I am repairing a ups which doesn't turn on ,it has the following ICs:
                                    SG3525 used to drive inverter mosfets.
                                    couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                    A LM358 and TL074 for control mechanism and of course the uController.
                                    The SG3525 is shutting down every time the ups is turned on.
                                    I want your help to know the function of LM358 and TL074 in the system.
                                    I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                    07-31-2025, 07:45 AM
                                  • jjne
                                    IR21531S odd behaviour
                                    by jjne
                                    I have a Boston Acoustics Soundwave subwoofer that I'm trying to resuscitate. It was blowing fuses and I narrowed the problem down to the main switching power supply which had blown MOSFETs. These are controlled by an IR21531S.
                                    My understanding of these ICs is they work similarly to a 555 timer and provide constant, and opposing-phase frequency to a high and low output, in this case 50KHz.
                                    What I found was that the LO was oscillating normally but the HO was sat at a constant 12v. This apparently was causing the HO-linked FET to fail. OK, it's a blown 21531, these are...
                                    03-19-2024, 07:16 AM
                                  • Durenth
                                    DC detection circuit failure on Subwoofer
                                    by Durenth
                                    First of all sorry for my English and for my poor knowledge in transistor behavior, I'll do my best to be clear…
                                    I have a problem with the DC detection circuit of a Panasonic 40W Subwoofer, model SW-P270.
                                    The relay in the DC detection circuit never turns on thought there is no DC in the audio output signal.
                                    Output signal is ok, controlled with an oscilloscope.
                                    I found the service manual (full board schematic attached to this post) and measured the voltage as shown below, pink is the expected value indicated in the manual, red...
                                    11-27-2020, 10:17 AM
                                  • Astonished
                                    Fixing the Charge Circuit of the Batteries of the DC Motor
                                    by Astonished
                                    Hi friends of electronics
                                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                    Please help me fix this circuit.
                                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                                    01-28-2025, 06:24 AM
