IR21531S odd behaviour
  • jjne
    • Mar 2013
    • 47
    I have a Boston Acoustics Soundwave subwoofer that I'm trying to resuscitate. It was blowing fuses and I narrowed the problem down to the main switching power supply which had blown MOSFETs. These are controlled by an IR21531S.
    My understanding of these ICs is they work similarly to a 555 timer and provide constant, and opposing-phase frequency to a high and low output, in this case 50KHz.
    What I found was that the LO was oscillating normally but the HO was sat at a constant 12v. This apparently was causing the HO-linked FET to fail. OK, it's a blown 21531, these are cheap so I'll replace that. This board has the oscillator on a little daughterboard which makes testing much more straightforward.
    However, the replacements are behaving in exactly the same manner. Now I will confess I bought them from AliExpress because I didn't fancy the £12 shipping fee from DigiKey, however given the original part, and at least two of the replacements are exhibiting exactly the same condition I have a hard time believing the fault is with all three ICs.
    Am I missing something fundamental here? The HO and LO outputs are direct from the chip, and given one is working I think I can discount the rest of the circuit, but this has me baffled.
    Circuit diagram from the service manual attached.
  • jjne
    • Mar 2013
    • 47
    Just to add, the thought had crossed my mind that the reference might be VS rather than ground, however on checking that side of things, although I do see some 50kHz action from VS to HO it doesn't look like a solid signal either, and LO to VS is all over the place.
    I guess it's possible it's behaving correctly but I only have a couple of transistors left (bought from Farnell so I'm fairly sure they're good) and don't really want to start burning through them on the off chance.
    • jjne
      • Mar 2013
      • 47
      Right, so it seems you have to tie VS to ground to test these chips - and the replacement is behaving normally. I think I have no choice but to risk frying another mosfet, as I cannot see anything else wrong with this damned board...
      • Federause
        HP 250 G7 - Battery Issue (Lid behaviour)
        by Federause
        I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
        It has a particular behaviour that I've never seen:
        With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
        09-08-2024, 03:34 AM
      • x_orange90_x
        Samsung UN50KU6300F constant reboot, bad backlights?
        by x_orange90_x
        This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
        02-09-2024, 08:41 PM
      • estabilito
        Acer Nitro AN515-55 weird behaviour on startup
        by estabilito
        Hi, I've just repaired acer nitro an515-55 with specs:
        i7-10750h, rtx2060.
        Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
        After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
        i've tried different bios, different vbios and same behaviour - clean windows install too.
        Do you have any idea?
        Yesterday, 02:52 PM
        Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
        by sam_sam_sam
        I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
        https://www.ebay.com/itm/116497313155?var=416785404161
        Here are some of the description from the eBay seller
        The main parameters:
        1. Product name: High-power non-isolated DC boost module power supply.
        2. Product model: 100A2000W.
        3. Input voltage: DC12V-60V.
        4. Input current: 100A (maximum)....
        05-18-2025, 09:45 AM
      • arashmoayyedizadeh
        A1990 2019 touchbar weird behaviour
        by arashmoayyedizadeh
        Hello to all of you engineers
        i have a macbook pro a1990 in no power condition
        another shop had done some works on it with no success (pm ic was reflowed, a little bit of flux around one of the type c rom ic, changing the charging ic)
        initial state: 5v 0amps on all 4 type c sockets
        after some inspections i realized the charging ic that another shop installed is isl9239
        I changed it with right one (isl9240) and the machine turned on and booted into macos
        weird behaviour:
        Lcd works ok until it boots to os and as soon as you see login page it goes black...
        03-26-2025, 12:02 PM
